Old Feb 18, 2008, 08:43 AM
jfv is offline
jfv
Find More Posts by jfv
jfv
jfv's Avatar
Bridgewater, NJ
Joined Aug 2004
The flair in the ply is not a problem. That will correct itself when the rear tab on the crutch is fit into the slot in the fuse sides. When you put the sides on make sure the rear portion of the two sides match exactly and the top edges are even. That should take care of any slight twist.
jfv is offline Find More Posts by jfv
Old Feb 18, 2008, 10:20 AM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Thanks for the advice.
Originally Posted by jfv
... make sure the rear portion of the two sides match exactly and the top edges are even. That should take care of any slight twist.
What do you mean, "match exactly"?
I took another look this morning and dry-fitted the sides. I wasn't really happy with how it looked, and didn't relish the though of trying to straighten out the fuse when gluing the sides on.
Looking down the crutch at the long ply pieces, I noticed that right at the last depron piece, the ply bulged up slightly on one side. Still no idea what happened, but I slid my knife under the depron, squeezed it together again, and reglued. I ended up doing the same sort of thing with the tail to straighten that a little. It looks much better now. Pics in a few minutes.
Bigster is offline Find More Posts by Bigster
Old Feb 18, 2008, 10:22 AM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
Originally Posted by bighead93
I want to try the side force generators on the Extra...how did you make yours?
many ways to make it
i made mine out of the wood scraps after building the extra (little triangles from the side frame) but i later moved on to a fuller SFG, cut out from $1 foam at dollartree, it's simple, just a triangle that extends from the leading edge of the wing to the root of the wing (aileron) on the tip. mine is about 3.5 inches high and it worked so well, you could go big with it, but i think it's gonna ruin the look of the extra
brian94066 is offline Find More Posts by brian94066
Old Feb 18, 2008, 12:23 PM
aviatordave is offline
Find More Posts by aviatordave
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
FuryFlyer2 (Paul?)
On the front page of your website you have this picture that shows a stick mount motor attached to the firewall.
I've googled. I've looked......where did they get this motor mount from?
TIA,
Dave
[EDIT - found them here http://www.horizonhobby.com/Products...rodID=EFLM1916
it would be cool if you carried these to cater for more motor options, although I'm sure you cant carry everything everyone wants..]
aviatordave is offline Find More Posts by aviatordave
Old Feb 18, 2008, 01:27 PM
aflipz is offline
Find More Posts by aflipz
aflipz's Avatar
all up in your grill
Joined Aug 2006
Originally Posted by aviatordave
FuryFlyer2 (Paul?)
...although I'm sure you cant carry everything everyone wants..]
Don't tell the man what he can and can't do
Just kidding bud...
It's amazing the progress Paul's business has made in the past 2 years, started from scratch now he has a HUUUUGE array of products and it's growing all the time.
aflipz is offline Find More Posts by aflipz
Old Feb 18, 2008, 01:30 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
I am going to try one of these mounts on one of my Foilz...just have to figure out which one!
bighead93 is offline Find More Posts by bighead93
Old Feb 18, 2008, 03:45 PM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
This looks better.
More dumb questions from the newbie, if you don't mind.
Step 11 has me "glue the crutch to one skin assembly from the nose to just behind the wing opening". Then, "glue the skin to the lower crutch member from the wing opening to the rear tab".
Then I repeat steps 10 and 11.
Step 12 is, "Glue the top rear edges of the fuselage together..."
When do I glue the skin to the top crutch member? And to the depron support piece?
Oh, and I've run out of kicker. I'm going to look it up, but I think I can use baking soda in water.
Old Feb 18, 2008, 03:58 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Originally Posted by Sundoggy
This looks better.
No problem! You are only going to glue the fuse skin on right now...take your time on this step to make sure that the foam doublers are lined up correctly on the ply crutch. Apply the fuse skin from the motor mount back...work slowly since this is your first...I liked to apply a bead of CA and hit it with kicker...keep doing this moving toward the tail. Hope that helps...as far as the support pieces...I didn't glue those on until the fuse sides were completed
Old Feb 18, 2008, 04:37 PM
jfv is offline
jfv
jfv
jfv's Avatar
Bridgewater, NJ
Joined Aug 2004
<When do I glue the skin to the top crutch member? And to the depron support piece?>
No need to glue the rear of the top crutch to the skin.
Old Feb 18, 2008, 04:42 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
I forgot...jfv is right...one you apply the top of the fuse...the depron support pieces are just that....support!
Old Feb 18, 2008, 05:10 PM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
I've run a bead of CA along most of the edges between the upper and lower crutch pieces and the fuse skin from the wing forward.
From the wing back, I've glued the lower crutch to the skin similarly, with a bead of CA (should I do top and bottom?). You're saying I don't need to glue the top crutch piece to the skin? Or to the depron support? Wow. I don't think I would have realized that.
Though No need to glue the rear of the top crutch to the skin. is pretty clear.
If the rearmost part of the upper crutch is not even with the horizontal stab hole, should I try to align it to the top of the hole? Of course, if I'm not gluing it, it doesn't matter.
Old Feb 18, 2008, 07:52 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
That is perfect! Don't go crazy with the CA...don't want to add a bunch of unessary wait The foam doublers should align with the ply crutch...test fit before you glue...and yes the horizontal stab should fit cleanly on both sides...
Old Feb 18, 2008, 08:55 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
By the way...was out flying again today and I am confident in saying that the Extra 260 is the best all around Airfoilz Plane (heck all around plane that I have ever flown ) that has come out so far...I was pulling off high alpha knife edges at less that a foot off the ground...spins like my Edge...hovers like my Bipe...harriers are rock solid once you get it all balanced out. We are working on video still...coming soon!!
Old Feb 19, 2008, 01:44 PM
kakisd is offline
Find More Posts by kakisd
W00t - The eagle has landed!
took awhile, but i got mine today!
Everything looks nice and minty
the scorpion 3008-32 should pull like a mother on a 12x6
kakisd is offline Find More Posts by kakisd
Old Feb 19, 2008, 02:52 PM
jfv is offline
jfv
jfv
jfv's Avatar
Bridgewater, NJ
Joined Aug 2004
<If the rearmost part of the upper crutch is not even with the horizontal stab hole, should I try to align it to the top of the hole? Of course, if I'm not gluing it, it doesn't matter.>
As long as it doesn't interfere with the stab you can leave it alone. If it protrudes down into the slot for the stab, push it up, out of the way. You can tack it in place with some CA if you want.
Discussion Hyperion 40e Extra 260 Build Thread Mopar92 3D Flying 1108 Jul 13, 2011 10:22 AM
E*Star 3D Cap, Extra, and Sukhoi Build Thread Bill K. 3D Flying 310 Oct 05, 2009 12:44 AM
Discussion Airfoilz Edge 540 - Build Thread by: Woody king160woody 3D Flying 72 Jun 03, 2009 11:40 PM
Discussion Eflite extra 260 build thread!!!!!!! Clayton Wheaton 3D Flying 508 Apr 07, 2009 07:03 AM
Build Log Bill Higgins Carden 260 Build Thread bill_higgins Giant Scale Airplanes 0 Nov 27, 2006 01:13 AM
