Old Nov 22, 2007, 10:51 AM
king160woody is offline
Find More Posts by king160woody
Jordan "Woody" King
king160woody's Avatar
Joined Jan 2006
My scheme came yesterday in the mail and got it cut out today.. This thing looks BadAss!! I can't wait to see it all finished on the plane!
Woody
king160woody is offline Find More Posts by king160woody
Old Nov 22, 2007, 06:44 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
wow that is really nice, woody
brian94066 is offline Find More Posts by brian94066
Old Nov 23, 2007, 03:40 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
guys, does Lowes carry micro balloons (the one mentioned in the manual)
i've never heard of that, is it required or can i just use lightweight spacklings
Old Nov 23, 2007, 04:38 PM
skyhiflyhigh is offline
Find More Posts by skyhiflyhigh
los angeles
Joined Mar 2004
the micro balloons are finer powder but the spackling would work. anybody get up to the elavator yet? in the plans the elavator is cut different than what i got, looks like it's setup to notch the fuse so it can move. in the plans where the elavator joins is much narrower. how far have u gotten to brian?
skyhiflyhigh is offline Find More Posts by skyhiflyhigh
Old Nov 23, 2007, 04:45 PM
Jordan "Woody" King
Joined Jan 2006
I just looked at the elevator also... Im not sure about this one... I will talk with paul in a little bit but im sure there is an easy answer.
Woody
jfv is offline
jfv
Find More Posts by jfv
jfv
jfv's Avatar
Bridgewater, NJ
Joined Aug 2004
You get micro balloons from your hobby shop or on line http://www3.towerhobbies.com/cgi-bin...lons&search=Go
Micro balloons are VERY small hollow glass spheres that are used as a filler. When mixed with epoxy they help reduce the weight. In the manual the fillet of epoxy and micro balloons is used to attached the wing to the fuselage. It provides a very strong and light weight joint. Spackle is just a filler and has NO strength. If you can't get the micro balloons just use a small fillet of epoxy.
jfv is offline Find More Posts by jfv
Old Nov 23, 2007, 04:54 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
skyhiflyhigh:
im done with the wings, and almost done with the fuselage, though i am worry about the elevator also, i can't figure out a way to slide the horizontal stabilizer and the elevator in without having to cut a notch so it would slide on like the profile airfoilz
jfv:
ok thank you, so i guess i'd be using 12 mins epoxy to make a tiny fillet to hold the wings on
Old Nov 23, 2007, 05:38 PM
los angeles
Joined Mar 2004
brian u can't slide the elavator and stabilzer in to the fuse as one piece already hinged. u will either have to cut the elavator down like on the plans or cut a notch in the fuse so the elavator can move
Old Nov 23, 2007, 07:49 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
i didnt hinge the elevator, im just wondering if anyone did cut a notch for it to slide in, i guess i'll do that
Old Nov 23, 2007, 08:43 PM
los angeles
Joined Mar 2004
oh... i thought u meant to cut a notch in the rear so u could slide it in from the rear instead of sliding it in from the side. the notch i'm talking about would be sorta a d shaped notch so that the elavator could move up and down
Old Nov 23, 2007, 08:52 PM
jfv is offline
jfv
jfv
jfv's Avatar
Bridgewater, NJ
Joined Aug 2004
The sequence is to add the carbon fiber elevator joiner then cut the bridge between the elevator halves out leaving only the carbon fiber rod between the elevator halves. Then cut the hinge slots in both the elevator and the stab, but don't glue the hinges in place. Slip the elevator through the slot, then slip the stab in the slot. Glue the stab in place. When the glue is dry, hinge the elevator to the stab. The only thing on the elevator going through the slot is the carbon fiber rod.
Old Nov 23, 2007, 08:55 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
OHHHH!!!! that's what u were talking about
well you dont have to, thats why airfoilz include the CF rod to hold the elevator while you cut the foam part in the middle, either way it still works
Old Nov 23, 2007, 09:23 PM
los angeles
Joined Mar 2004
actually now that i think about it if u notch the fuse u'll have to cut through the plywood former to get up elevator to get down elevator just through the dupron. yeah we'll see what paul sez but i'm thinking about redoing the elevator, cut it down like on the plans, loose the cabon rod joiner and go with 1/4 in. balsa triangle stock on the leading edge of the elevator full lenght with a wire joiner for extra support. on the trailing edge of the stab go with 1/8th or maybe 1/16th by 1/4 in. balsa or .007 cabon fiber but u would have to be able to cut a slit in it for the hinges
Old Nov 23, 2007, 10:01 PM
jfv is offline
jfv
jfv
jfv's Avatar
Bridgewater, NJ
Joined Aug 2004
I have built 5 of the prototypes with just the carbon fiber rod between the elevator halves and get 45 deg + throw on the elevator. Keep the hinge gap tight and just follow the manual and there will be no problems.
Old Nov 23, 2007, 11:30 PM
los angeles
Joined Mar 2004
i'm sure u can get plenty of throw with just the carbon joiner... i think i can get it alittle stiffer torsionally with a wire joiner by going with 1/4 in. square balsa in place of the cabon tube ( not full length of the elevator like i was saying before) with the leading edge sanded round and the wire joiner recessed into it. if i could just drill a couple of holes through the carbon tube and pin it with toothpicks or carbon rod i would do it that way
Discussion Hyperion 40e Extra 260 Build Thread Mopar92 3D Flying 1108 Jul 13, 2011 10:22 AM
E*Star 3D Cap, Extra, and Sukhoi Build Thread Bill K. 3D Flying 310 Oct 05, 2009 12:44 AM
Discussion Airfoilz Edge 540 - Build Thread by: Woody king160woody 3D Flying 72 Jun 03, 2009 11:40 PM
Discussion Eflite extra 260 build thread!!!!!!! Clayton Wheaton 3D Flying 508 Apr 07, 2009 07:03 AM
Build Log Bill Higgins Carden 260 Build Thread bill_higgins Giant Scale Airplanes 0 Nov 27, 2006 01:13 AM
