Old Jun 01, 2008, 03:55 PM
PimPiNo3o7 is offline
Find More Posts by PimPiNo3o7
PimPiNo3o7's Avatar
Los Angeles,CA
Joined Apr 2007
Got in my 1800 X-Cite batteries and put a few flights on the Extra. My A.U.W is now 24.70 oz, the batteries are pulling 330 watts at 28 amps, which is about 218 watts per pound Oh ya motor is Scorpion 3008-28 with Xoar 10x5 prop.
The plane has good pull with the Xoar 10x5 but its even better with an APC 11x5.5, but thats pushing it a little bit so I like the 10x5 better as it keeps the amps down.The plane balances fine at 3 3/4 and I can move the battery back about 1-2 inches if I ever need to but the plane is flying good now and hovers with little effort.
PimPiNo3o7 is offline Find More Posts by PimPiNo3o7
Old Jun 01, 2008, 05:14 PM
I.C.O.N. is offline
Find More Posts by I.C.O.N.
I.C.O.N.'s Avatar
Twin Cities, MN
Joined Feb 2006
leblanc, I am not sure why it's off.
Your motor is .5 ounces more then mine. So .5 ounces in the tail might make sense.
do you have any spinners on the front?
What are you using for batts and servos?
Are you using LG? Does it make a difference with it on and off?
Andy
I.C.O.N. is offline Find More Posts by I.C.O.N.
Old Jun 01, 2008, 05:26 PM
dwojno is offline
Find More Posts by dwojno
New Jersey
Joined May 2008
How many threaded push rods should I have gotten I only see two? Do you cut one in half for the wings?
dwojno is offline Find More Posts by dwojno
Old Jun 01, 2008, 05:35 PM
leblanc is offline
Find More Posts by leblanc
Fly low or go home!
Joined Apr 2006
ICON,
No I am not using any spinner on my motor. Running HS-45`s on ailerons, and hs 65`s on the tail. The LG is on and is going to stay there too.
I just put the rudder servo in the tail. Now with the battery as far back as I can get it, it touches around 4.25in. I ll try it like that and hopefully will be plenty.
LB
leblanc is offline Find More Posts by leblanc
Old Jun 01, 2008, 07:08 PM
I.C.O.N. is offline
I.C.O.N.'s Avatar
Twin Cities, MN
Joined Feb 2006
leblanc, sounds perfect to me.
I would like the LG on too for ROG, but the tall grass I land in makes it pretty much pointless.
Good luck! Let us know how it goes.
Andy
Old Jun 01, 2008, 10:39 PM
Paul Jamerson is offline
Find More Posts by Paul Jamerson
Paul Jamerson's Avatar
St Peters, MO
Joined Nov 2005
I tossed it all [ heavy ] and used carbon fiber rod glued to the clevis at one end and lashed and glued to piano wire at the other end with quick connects at the servo arms. Good luck and enjoy.
Paul Jamerson is offline Find More Posts by Paul Jamerson
Old Jun 01, 2008, 10:56 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
yes 2 is right
cut one in half for the ailerons and trim the other one for the elevator
brian94066 is offline Find More Posts by brian94066
Old Jun 03, 2008, 08:00 AM
aflipz is offline
Find More Posts by aflipz
aflipz's Avatar
all up in your grill
Joined Aug 2006
Hey Paul, are you not getting my emails??
aflipz is offline Find More Posts by aflipz
Old Jun 03, 2008, 09:48 AM
leblanc is offline
Fly low or go home!
Joined Apr 2006
Hey guys,
I ve been wondering, how does everyone do their hinges? How do you glue them, align, and which glue do you use? My hinging skills are terrible, and at full deflection the servos struggle alot to keep it there.
So, how do YOU hinge?
Will most likely be using the best method on my bipe thats coming in soon.
LB
Old Jun 03, 2008, 09:58 AM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Originally Posted by leblanc
Hey guys,
LB
I use 30 minute epoxy. Test fit the hinge....apply it (not to much) slide into the hinge slot and wipe away any glue that gets pushed out. You should be able to move the hinge at full deflection at this point. When you are happy with it...let it cure. Once it has cured...move the hinges again to make sure you still have full deflection. Does that make sense?
bighead93 is offline Find More Posts by bighead93
Old Jun 03, 2008, 10:57 AM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
i use 15 minute epoxy, and i use 1" wide clear packing tape to seal the control surfaces
Old Jun 03, 2008, 11:35 AM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
I've heard of using vaseline at the hinge line so the epoxy won't cure there. It's something I should have done (but didn't) so my elevator hinges are a bit stiff which is reducing the throw. Keep those hinges clean!
Bigster is offline Find More Posts by Bigster
Old Jun 03, 2008, 11:43 AM
aflipz is offline
aflipz's Avatar
Joined Aug 2006
I just buy dubro micro pinned hinges, i bevel the surfaces and recess the hinge by cutting "slots" for them so the tip of the bevelled surface just touches the trailing edge of the stabs and or wings. This gives me a sealed surface with no tape and the most friction free operation you can get.
Old Jun 03, 2008, 11:50 AM
msprygada is offline
Find More Posts by msprygada
msprygada's Avatar
Bay City, Michigan
Joined Sep 2006
Bigster, make sure that your carbon bar is not hitting the fuse. I know that you are supposed to be able to have it where the carbon bar is supposed to not move any higher or lower than the horizontal stab but I had to do this on all my Airfoilz planes. See attached picture.
msprygada is offline Find More Posts by msprygada
Old Jun 03, 2008, 11:56 AM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
I forgot about that, Matt. I'll check it. Thanks for reminding me!
Discussion Hyperion 40e Extra 260 Build Thread Mopar92 3D Flying 1108 Jul 13, 2011 10:22 AM
E*Star 3D Cap, Extra, and Sukhoi Build Thread Bill K. 3D Flying 310 Oct 05, 2009 12:44 AM
Discussion Airfoilz Edge 540 - Build Thread by: Woody king160woody 3D Flying 72 Jun 03, 2009 11:40 PM
Discussion Eflite extra 260 build thread!!!!!!! Clayton Wheaton 3D Flying 508 Apr 07, 2009 07:03 AM
Build Log Bill Higgins Carden 260 Build Thread bill_higgins Giant Scale Airplanes 0 Nov 27, 2006 01:13 AM
