Old Nov 09, 2007, 11:53 PM
mauiguy99 is offline
Find More Posts by mauiguy99
mauiguy99's Avatar
Kahului, Hawaii, United States
Joined Jul 2003
How do I make a tight z-bend?
My latest Arrow is almost ready to go. I just have to make the aileron linkages. After putting together a dozen or so DLG's I have learned many tricks and have come to obsess about tight slop free linkages.
I still have yet to make an aileron linkage with zero slop. I want to make some really tight z-bends but havn't been able to figure out a way to make the center length of the Z small enough. I want 2 sharp 90 degree bends with only 1-2 mm in between. Does anyone know a good way to bend such small Z bends?
mauiguy99 is offline Find More Posts by mauiguy99
Old Nov 10, 2007, 03:01 AM
MGerstgrasser is offline
Find More Posts by MGerstgrasser
Austria
Joined Oct 2003
Hi,
Could not get slop free Z-Bends either. A "secured" L-Bend works better for me.
Regards,
Matthias
MGerstgrasser is offline Find More Posts by MGerstgrasser
Old Nov 10, 2007, 03:18 AM
charlie hepler is offline
Find More Posts by charlie hepler
Newbie but not too new!!
Lexington NC
Joined Dec 2004
Z-Bend Pliars?
charlie hepler is offline Find More Posts by charlie hepler
Old Nov 10, 2007, 09:06 AM
Wazmo is offline
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
If the pushrod is metal, you can put a tiny drop of medium/thick CA on the control horn hole after the pushrod is inserted. After the CA cures (maybe use a tiny bit of accelerator), move the pushrod to break it free from the CA. Linkage should be slop-free.
Note that this will make it very difficult to remove the pushrod.
Don't do this with a carbon pushrod, or any other material that the CA will stick to.
Because of the geometry (cross-section of 90 degree bend is wider than cross-section of straight wire), it's nearly impossible to make a Z-bend that is both removeable and slop-free.
Wazmo is offline Find More Posts by Wazmo
Old Nov 10, 2007, 09:55 AM
mauiguy99's Avatar
Joined Jul 2003
Matthias, I like you system. what are you using to bend the wire?
Old Nov 10, 2007, 10:14 AM
Austria
Joined Oct 2003
Just normal (narrow) pliers.
Matthias
Old Nov 10, 2007, 10:46 AM
dougmontgomery is online now
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
another option
this is what I have been doing and really simple.
bend your L bend on one side
slide a piece of small heat shrink about that is about full length
1/4" from each end
bend your control arm side L bend
then slide a piece of 1mm carbon through the heat shrink
Ca on drip so it runs down the heat shrink inside against the wires
heat
Doug
dougmontgomery is online now Find More Posts by dougmontgomery
Old Nov 10, 2007, 04:39 PM
Shaper Dave is offline
Find More Posts by Shaper Dave
Shaper Dave's Avatar
Oahu Hawaii
Joined Aug 2004
Pete,
Don't use Z bends. Just do the 90 bend and add a small piece of the pushrod tubing on the outside with a drop of CA. Zero slop and cleaner set up.
Dave
Shaper Dave is offline Find More Posts by Shaper Dave
Old Nov 10, 2007, 05:13 PM
jfrickmann is offline
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
You can also use this or that.
jfrickmann is offline Find More Posts by jfrickmann
Old Nov 10, 2007, 06:23 PM
David Forbes is offline
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Us Dave's are going to stick together, no Z bends.
Dave
David Forbes is offline Find More Posts by David Forbes
Old Nov 10, 2007, 06:40 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
What Matthias or Dave said. I use both/either.
If use use the L bend with a tube keeper, then be certain to point the L bend to the outside of your launch, so that if you loose the tube, the L bend might stay in.
Z bends aren't slop free.
GaryO is offline Find More Posts by GaryO
Old Nov 10, 2007, 08:46 PM
Ninjak2k is offline
Find More Posts by Ninjak2k
United States, VA, Warrenton
Joined Apr 2001
Dave F., how do you get the perfect length? Even with extremely careful measurement, it seems like you might end up slightly off with the bends and then you'd have to offset the servo arm a bit to compensate.
~Dan
Ninjak2k is offline Find More Posts by Ninjak2k
Old Nov 11, 2007, 06:49 AM
Joined Dec 2005
It's not as hard as it looks, plus you have a little adjustment available with the angle at the end of the long straight part. Wire is cheap ,they're quick to make, and with a little practice you'll get it. This method was from the Encore build instructions.
Dave
Old Nov 11, 2007, 07:49 AM
Vulture is offline
Find More Posts by Vulture
Looking for lift...
Milford, NJ
Joined Mar 2005
Dave,
What size wire are you using?
Doug
Vulture is offline Find More Posts by Vulture
How do I make Carbon Fiber Parts? gns30 Electric Plane Talk 1 Jun 16, 2001 11:02 AM
How do I make a wing bolt on? luv2fly Electric Plane Talk 5 May 31, 2001 11:23 AM
How do I make Dean's come apart??? windsurfer Electric Plane Talk 46 May 16, 2001 12:08 AM
How do I make up a Bungee system sbarrow Electric Ducted Fan Jet Talk 1 May 07, 2001 06:56 AM
How do i make my own hot wire rig? PunkerTFC Electric Plane Talk 21 Apr 22, 2001 09:50 PM
