Old Nov 09, 2007, 07:19 AM
arukum17 is offline
Find More Posts by arukum17
London, UK
Joined Aug 2005
How to build an IC power pod with throttle linkages for a 3m glider
I am a glider flyer and have reasonable building experience. I currently fly a 3m woodie glider (Paragon). Can someone point me to directions/"build thread" for building an IC power pod for this as well as how to set up the throttle linkages.
Requirements:
- should be large enough to take a .10 or .25 engine
- should be capable of being rubber banded on the wing (wing is three piece, with a solid center section which is rubber banded on the fuse)
I am particularly a newbie when it come to setting up throttle linkages to the servo, fuel tank placement etc. Basically making sure the puppy will work!
I have used IC engines before but these have been in RTFs and on a GP power pod/0.49 which has no throttle/external fuel tank.
For the purposes of this thread I am not looking at an electrics solution.
arukum17 is offline Find More Posts by arukum17
Old Nov 09, 2007, 11:33 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Link regarding incidence from rc groups thread:
http://www.rcuniverse.com/forum/m_65...tm.htm#6587706
Sig makes a 2 meter one for .049 engines.
http://www.sigmfg.com/IndexText/SIGSH660.html
This side view should give you an idea of what you need to do. I dont think you need to worry about the incidence to much since this can be adjusted via shims. Notice the large plate on the bottom for rubber band hold down. Should be wide enough to extend past both sides of the rubber band foot print. Be sure to cross the rubber on each side of the pod as well. For throttle I think you would need to mount a micro servo to the pod itself other wise your fiddling with connections each time you assemble the craft. Just my thoughts.
Thermalin is offline Find More Posts by Thermalin
Old Nov 12, 2007, 08:00 AM
arukum17 is offline
London, UK
Joined Aug 2005
Thanks Mike - most likely I will be going down the DIY route you suggested, just have to wait to source the right engine...
Regarding materials I assume lite plywood sheet (fuel proofed) should do the trick. How does one mount the micro servo and fuel tanks onto wood of the power pod?...I have never found it easy to cut square spaces (for the servos/fuel tank) into plywood.
Tremendously and proudly a nitro newbie
Old Nov 13, 2007, 03:07 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
Having learned on a glider with a Medalian .049 on a power pod, I wonder what the value of the throttle is. The plastic tank mount for the Medalian gave a motor run of about 4-5 minutes which would get 1000-1500 feet altitude on that heavy, clunky model.
I question the need for a throttle. A slow spinning prop creates more drag than a stopped one, so your performance is going to be better with the motor dead. If all you're going to do with the servo is kill the motor, you should be able to control run time with fuel load and not need the servo.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Nov 18, 2007, 09:40 AM
arukum17 is offline
London, UK
Joined Aug 2005
Have bought a 2 sheets of plywood:
3.2x300x300mm plywood (for the base)
6.4x300x300mm lite plywood (for a the arm and backwall)
K&B 20 Sportster engine (on order)
debating whether to use a 2oz tank or a 4oz tank?
Old Nov 21, 2007, 07:42 AM
arukum17 is offline
London, UK
Joined Aug 2005
Current parts on order
2 oz dubro fuel tank
10x4 master airscrew glass fibre prop
micro servo mounts
futaba servo extension leads
micro clevis
Old Nov 21, 2007, 09:13 AM
arukum17 is offline
London, UK
Joined Aug 2005
...oh and nylon ties to strap the fuel tank to the pod
Old Nov 30, 2007, 01:53 PM
arukum17 is offline
London, UK
Joined Aug 2005
anyone have any links showing how to connect the fuel tank to the engine etc please let me know....
update I found it
How to build an F5B Wing....the video... soholingo Composites Fabrication 158 Jan 22, 2008 12:53 AM
Discussion IC power pod for 3m woodie glider arukum17 Fuel Plane Talk 0 Aug 30, 2007 07:56 AM
How to modify an ATX power supply spudboy Batteries and Chargers 2 Jan 26, 2005 12:11 PM
How to build accurate ailerons on a wing with washout Brian Koester Slope 13 Apr 16, 2004 07:58 PM
How to build an ET-1200 3S Pack? Neil Stainton Batteries and Chargers 7 Mar 09, 2004 10:17 PM
