I just wondered, without ploughing through the whole thread (again), as the hardware spec was originally posted by Maybz for his excellent design as:
Motor - LS Purple Peril (AXI 2208/26 would also be a good choice) Prop - APC 7x4 ESC - CC 18 Batt - TP1320 3s Servos - two HS-55 and one HS-45HB or similar for the sweep Any unpdates/upgrades/improvements as far as hardware that have come to light now several of this excellent model have been built? I appreciate all componants are replaceable, I just wondered what combinations have worked for you guys that are enjoying flying this model? Wouldn't a motor like a Grayson Hobbies Parjet 2212 with smaller dia prop be better, less torque? |
Thanks again for suggestions |
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
10/4...the secret to successfull electric flight is to keep it lightweight with sufficient power....
..14 oz seems to be the weight... ..140 watts minimum seems to be the power goal .... ..7/4 prop seems to be the decent prop for both torque and speed.. ..a strong (20C) 1320 or 1800 mah lipo seems to be a suitable pack, (although many probably use the heavier 2100 pack.) Bill |
Motor: Emax 2812 a LSPP will work fine too
ESC: some cheapo Hong Kong 18amp no name Prop: APC 7x5E Battery: Loong 1300 3S 20C Servos: HS-81MG for the wings, HS-55's for the tail Great looking plane and a great flying plane with the wings swept or partially swept, with the wings out, rolls are pretty sluggish (for me). I built mine very heavy (16 oz) and it still flies very well. Slows down nicely, flies pretty fast too. Right now, out of the 4 prop-jets that I've built, this one is still my favorite. |
Mableton, GA USA
Joined Nov 2005
I actually got my DX6 back from being serviced and just tried the programming mixes I mentioned before and it seems to work pretty good on the bench tests I've done. With the Throttle to gear mix off I can use the gear switch for manual selection of two sweep positions, full unswept and full swept back. Then with the Throttle to gear(wing sweep) mix on I have the wings just starting to sweep back at just under half throttle with full back sweep by the time I get to full throttle. It's nice and smooth! I've also figured out a way to get a manual four position wing sweep instead just the two positions that the gear switch allows. I've set up Mix B to mix gear to gear for dual rates using the elevator D/R switch in combination with the gear switch. Here is how I did it. The below assumes that your wing sweep is set to the gear channel and not reversed. Also that when the gear switch is pulled towards you the wings are in its furthest swept forward position and with with the gear switch pushed away from you the wings move to its furthest swept back position. 1. Press the SCROLL and INCREASE buttons simultaneously to enter function mode. 2. Press the SCROLL button until mix “B11” appears at the top right corner of the screen. 3. Press CHANNEL button until mix "Bch" appears at the top right corner of the screen 4. Press the INCREASE button until 5 (gear) appears on the screen as the master channel. 5. Press the DECREASE button until 5 (gear) appears on the screen as the slave channel. 6. Press CHANNEL button until mix "BSW" appears at the top right corner of the screen and set this to "E" using the INCREASE/DECREASE button. 7. Press CHANNEL button until mix "B55" appears at the top right corner of the screen and set the Elevator D/R switch to the on position. 8. Move the gear switch toward you and press the INCREASE or DECREASE button to set your desired value (mine is set at -60 %). Make sure the Elevator D/R switch is set to on position while doing this. 9. Move the gear switch in the opposite direction to adjust that direction’s value. (mine is set to -97 %) So essentially what this mix does is it allows you to lower the travel rate of your gear switch when the mix is on. So the steps to operate the sweep in this mode goes like this. 1. Gear switch towards you and Elevator D/R switch off = fully unswept. 2. Gear switch towards you and Elevator D/R switch on = 1/4 swept back 3. Gear switch away from you and Elev. D/R switch on = 3/4 swept back 4. Gear switch away from you and Elev. D/R switch off = Fully swept back Hope that helps some one out there. Paul Barros |
Mableton, GA USA
Joined Nov 2005
And here are the step by step instructions for setting up the Throttle to Gear/Sweep mix on a Spektrum DX6 that I mentioned previosly. Same assumptions as before. That you have the wing sweep servo using the Gear channel and that with the gear switch towards you gives fully un-swept wings.
1. Turn on the transmitter and flip the gear switch to the fully un-swept position. Do not touch the gear switch further while setting up or using the below mix!!!! 2. Press the SCROLL and INCREASE buttons simultaneously to enter the Function mode. 3. Press the SCROLL button until “MIX A11” appears at the top right corner of the screen. This is Program Mix A. 4. Press the channel button twice until “MIX Ach” appears on the screen 5. Press the INCREASE button until 1 (throttle) appears on the screen as the master channel. 6. Press the DECREASE button until 5 (gear) appears on the screen as the slave channel. 7. Press CHANNEL button until mix "ASW" appears at the top right corner of the screen and set this to "F1" using the INCREASE/DECREASE button so you can turn this mix on and off with the flap switch 8. Press CHANNEL button until MIX OFFSET "A15" appears at the top right corner of the screen. Make sure Flap switch is in the on position. 9. Set throttle stick to a little below half throttle and press the INCREASE/DECREASE button one time. I got a value of -47 at the throttle position I selected. What you are doing here is essentially setting were on the throttle stick range the mix will start sweeping the wings back. 10. Press CHANNEL button until MIX "A15" appears at the top right corner of the screen. Make sure flap switch is still set to mix on position. 11. Press the INCREASE button until you get a value of 125% so you get the full range of sweep. You may have to go back to step 9 and adjust the offset for different offset positions of the throttle stick until you find a good position that gives you full sweep with the throttle just below half. One word of warning though. Make sure you DO NOT flip the gear(wing sweep) switch to it's full swept back position while using this Mix!!! Severe servo binding is the result! Also make sure the Wing Sweep Dual Rate mix I just posted above is also off. Hopefully tomorrow I get to try some real world tests of these two mixes in the air and see if they are worth it! ![]() Paul Barros |
Philippines, NCR, Manila
Joined Oct 2007
Hi guys! This F14 is a gift from heaven! I'm planning to start building it this coming summer and try to knock my friends out with this design. I keep on dreaming building it and flying it for over 1 week now and my wife hears me talk in my sleep
Anyway, I was planning to build one with landing wheels but since it is powered with a prop, i was foreseeing that it will be a disturbance in taking of and landing. My questions are: - Is it possible to upgrade this one with a ducted fan? Any ideas which specs should i use? -where will be the CG located? -are there any plans where we could install the landing wheels? ( im planning to install another servo in front of the nose fuse. This will serve as steering on the rudder channel.) Here are some of my electronics that i used on my GWS Zero for my servos, im only using cheapos: - Tower pro servos 8g (im going to use one in the wing retract) - e sky servo 9g -dual sky 1300 16c 3s -arrowind outrunner 2010 -cheapo china esc 40amp Im using a Futaba 6EXFASST 6channel. http://2.4gigahertz.com/systems/futk6900.html Just bought it last January and i don't have any clue on how to program the elevons. Thank you for the genius who design this. Mike from Manila |
build
BOB payment sent for a white one and thanks Maybz for the design..will be first on my list when i get back home to North Carolina from Saudi Arabia. as i have 3 more weeks to work, it should be waiting on my workbench when i get home.. just have to look in the thread on the best wing servo to use and get it ordered. then, YA HOO i'm home for 5 weeks to play,
| Thread Tools | |
| Update for F-14 EDF plan buyers. | bipeflyer | Electric Ducted Fan Jet Talk | 6 | Feb 11, 2005 01:10 AM |
| F-14 Scale EDF Whos kit is it ??? | F900 | Electric Ducted Fan Jet Talk | 6 | Dec 07, 2001 08:26 AM |
| F-14 Tomcat EDF,pictures and questions | bipeflyer | Electric Ducted Fan Jet Talk | 13 | Jul 14, 2001 06:10 PM |
| Great Plane F-14 and Learjet conversions | sbarrow | Sport Planes | 1 | Jun 24, 2001 08:00 PM |
| f-14 center of gravity verus center of lift | tony houk | Power Systems | 5 | May 14, 2001 01:48 PM |
