Old Nov 11, 2007, 07:55 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Originally Posted by Maybz
Controls are elevons, throttle and sweep (4ch)
Are you using the trim on ch 4 to sweep the wings or are you holding the stick over?
leadfeather is online now Find More Posts by leadfeather
Old Nov 11, 2007, 09:31 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Too cool . You guys are killing me with these awesome designs. There's just not enough time in the day... week.... year!!!
Chad
chalmrast is offline Find More Posts by chalmrast
Old Nov 11, 2007, 10:01 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
i know how you feel Chad....
now gotta get some rediboard at $tree so i can do one.....fff has way too many waves...
smkn951 is offline Find More Posts by smkn951
Old Nov 11, 2007, 10:13 PM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
Left stick = throttle
Right stick = Aile, Elev (delta mix)
3 position flap switch = wing sweep
On my DX7 I use the top left flap switch for the sweep. That being said, the idea of using the rudder channel (left stick) for sweep is kinda intriguing.. might have to try it.
I'm used to flying with flight modes on my EVO9 which are also on a switch on the left side of the TX so this is very natural for me.
Maybz is offline Find More Posts by Maybz
Old Nov 12, 2007, 07:05 AM
wohenzhuce is offline
Find More Posts by wohenzhuce
China, Yunnan, Honghe
Joined Jul 2006
here is a bug i found from the plan.
wohenzhuce is offline Find More Posts by wohenzhuce
Old Nov 12, 2007, 10:02 AM
MicroHeli-Nut is offline
Find More Posts by MicroHeli-Nut
The Rave.
Singapore Paya Lebar, Singapore
Joined Aug 2003
beautiful plans. Your build looks beautiful
MicroHeli-Nut is offline Find More Posts by MicroHeli-Nut
Old Nov 14, 2007, 12:35 PM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
got one built. this plane looks nice. though i didn't care much for the tabs as they're a PITA to cut.
i got the wings to swing but i'm having trouble with it closing or opening all the way. do i need to fabricate a longer servo arm?
right now it's set for mid open/close on ch4. when i turn the stick to the left it opens but there's still room for fully open, like wise with the swept version.
would the fc2408-05 with a 5 inch prop with a 3s?
not really looking for the 100mph barrier.
BTW, built as is, i gave it a toss with the elevators up acouple of mm and it went a good 30 ft.
awesome plane.
Thanks.
Old Nov 14, 2007, 01:28 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Glad to hear!
If you want to increase the range of swing then you will need to lengthen the servo arm. I use the Hitec arm that is listed in the manual but you could easily make one from 1/16 ply and simply bolt it onto a shorter stock arm. 50mm between hole centers is ideal.
I'm not familiar with that motor so I can't comment on it. You want a motor with more torque and less speed , i.e lower KV. The ideal motor is something with a 22mm stator that is 8~12mm in length and has a 1200~1500kv rating. This plane is an aerobatic plane so what you are really after is vertical acceleration and the best way to get that is with a larger prop. You will get better performance from a 7" prop with less pitch than you will from a 5" prop with more pitch.
There are lots of motors that would work well, here are a few:
-AXI 2208-26
-Emax CF2212 (cheapest)
-X-motor 2826CA-12T
-Eskay 400XT
-Little Screamers Purple Peril
-Grayson GH2212-10 (combo w/esc is only $33!)
Old Nov 14, 2007, 01:32 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I guess I'll need to order some more foam and I guess a higher powered
servo. About how much torque do you think is needed for wing sweep servo?
How much flight time are you getting from the TP1320's?
Excellent looking plane!
rmgmag is offline Find More Posts by rmgmag
Old Nov 14, 2007, 01:55 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
I'm getting 6~10 minute flights from my 1320 packs depending on how hard I push the plane. Lots of vertical climb outs = less flight time. My TP packs are warm after a flight - my green Evolite packs run cooler. My current setup with LSPP and APC 6x4 is pulling 12A WOT static.
Old Nov 14, 2007, 02:05 PM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I'm getting 6~10 minute flights from my 1320 packs depending on how hard I push the plane. Lots of vertical climb outs means less flight time. My TP packs are warm after a flight - my green Evolite packs run cooler. My current setup with LSPP and APC 6x4 is pulling 12A WOT static.
Hmmm, I get over 7 minutes with my LSPP's turning a GWS 8x4 DD with some cheapo 20C Hobby City 800mah 3 cells. I would have expected longer flight times with the 1320's. But I guess it does depend on how much juice you're giving it.
Old Nov 14, 2007, 02:22 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
You may be right.. I tend to run my packs on the conservative side to prolong life.
I fixed the bug in the plans and reposted - also added grids for easier alignments of tiles.
Old Nov 14, 2007, 04:31 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Could you send the DXF export of the fixed plans please.
Mark
kram242 is offline Find More Posts by kram242
Old Nov 14, 2007, 04:36 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
DXF files? Are you planning to laser cut?
Old Nov 14, 2007, 04:38 PM
kram242 is offline
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
I have a homemade cnc router that I want to cut them out on.
When I finished building the router, I started cutting planes out on that, it makes all the tab cutting so much nicer
Mark
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
