Old Dec 28, 2007, 12:28 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Originally Posted by choza
I just have to sand it and paint it,
You know you've got the Air Force logo on a Navy aircraft, right?
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Dec 28, 2007, 01:18 AM
birdofplay is offline
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Yeah, but he crashed ... so who gets the blame ? :-)
birdofplay is offline Find More Posts by birdofplay
Old Dec 28, 2007, 01:22 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Welll.... good question.. If it'd been painted with Navy on it, it would not have crashed..
Old Dec 28, 2007, 01:28 AM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
yeahhh man, i have new nose, tomorrow will be the re-maiden, jojo again i have my MDC f-14 (by the way what is MDC?? )
Glad to see you back in the air so quick.
MDC = Maybz Design Co
Maybz is offline Find More Posts by Maybz
Old Dec 28, 2007, 01:46 AM
choza is offline
Find More Posts by choza
Colombia, Caldas, Manizales
Joined Oct 2007
the true is that i didn't know LOL, i'm from Colombia and i don't know which plane is from the navy and which not, i just searched a good logo to paint, but it wasn't finished yet, i was going to paint the stars on the wings, the skulls in the rudders (i don't know the name but you understand what i mean with the rudders LOL), and i was going to write navy on one of the inlets and F-14 on the other, maybe for you is a mixing of logos and maybe is an insult to the navy or to the us force or i don't know, but i just wanted it to be bautiful LOL.
thx for the answer Maybz
choza is offline Find More Posts by choza
Old Dec 28, 2007, 02:06 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Choza,
If you are looking for some VERY good decals, try here: http://www.rcgroups.com/forums/member.php?u=89637
chewy
chewytm is offline Find More Posts by chewytm
Old Dec 28, 2007, 02:16 AM
DaniSaez is offline
Find More Posts by DaniSaez
CeNeCe PRO rules!
DaniSaez's Avatar
Barcelona
Joined Jan 2005
Hi birdofplay,
the kerf I get when cutting depends on the hurry I have.
If I need a quick cut, that is, fast cutting speed and higher temperature, the kerf tends to be around 1mm to 1.5mm.
If I've got time to stare at the machine, or I want a more precise cut, the kerf decreases to 0.3mm to 1mm.
It also depends on the material you're cutting, but with depron, you can get very accurate cutting.
BTW, I use tungstene wire with a diameter of 0.09mm, it's thiner than a hair!
happy landings!
Dani
DaniSaez is offline Find More Posts by DaniSaez
Old Dec 28, 2007, 03:07 AM
birdofplay's Avatar
Joined Dec 2005
Thanks Dani !
Good info to have and compare other data with.
Wow that is SMALL wire !
Very interesting !
I cut at .5 to 1 inch per second
thats 12 to 25 mm per second my rapid is 3 times that
I use a .125" bit ( ~ 3mm) so I have a large kerf !
Stay out of the trees !
bob
Old Dec 28, 2007, 09:26 AM
choza is offline
Joined Oct 2007
Originally Posted by chewytm
Choza,
chewy
thx for the link man
Old Dec 28, 2007, 05:05 PM
DaniSaez is offline
CeNeCe PRO rules!
DaniSaez's Avatar
Barcelona
Joined Jan 2005
hi birdofplay,
I usually do my cuts at 3mm/sec, I know, it's a bit slow, but this way I get perfect cuts with square corners, and very accurate profiling.
A little trick I also use, is the following:
when I have to cut pieces that must fit together, I do a little scaling to slightly reduce all drawing by .3mm aprox. This way pieces fit perfectly without even moving.
when I finish the kerf calculation for any shape in the CeNeCe PRO, this won't be necessary anymore, as the program will compensate the kerf automatically.
Happy Landings,
Dani
Old Dec 28, 2007, 06:30 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
Going to start building mine this week. what's the best servo you guys have come up with for the wing sweep. Heres some I've found.
DS-929MG
HD-2213MG
HGD-250 carbon gear
HGD-250MG
Spec.
Speed: .17sec/60deg
Torque: 4.7kg
Weight: 21g
This last one has a ton of torgue
davecrash is offline Find More Posts by davecrash
Old Dec 28, 2007, 06:45 PM
birdofplay's Avatar
Joined Dec 2005
Dani,
Kerf is easy for me.
I use the Rule: " offset by 1/2 the Bit Width"
Parts fit nice and tight at High or low cut speeds - Ask Mike :-)
I do all the offeseting in CAD before going to CNC.
In Profili Stephano does it that way also.
To do it in CNC the program would have to "know "
what is a HOLE and What is a PART.
IN OTHER NEWS:
My order from Hobby City arrived TODAY !
totaly unbelievable - I ordered it Dec 19 thats 9 days from HK ! ! !
The metal gear servo looks a bit small for the job :-(
I'll wait until the current servo fails and then decide what to try next.
Also got a 25A ESC and some Lipos and lots of 3.5MM connectors so
I'll be at the Soldering station for the next hour !
Plus I have to FLIP all my balance tabs to match my charger , sigh ... 8-(
And the Foam has made it to Utah ! according to the tracking :-)
Old Dec 29, 2007, 02:12 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I ordered the eagle tree V3 from them on the 19th and got it on the 24th.
It's amazing how fast you can get some things from such a great distance.
I want to get the wing servo right the first time, It looks to be a bit of a pain to change later. I just found a HXT9230MG 180 I had bought awhile ago for something else and just realized it's not proportional.
Old Dec 29, 2007, 08:02 PM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
How are you guys getting your orders so fast? I put in an order from UH on the 16 they didn't ship till the 27 and all the parts were in stock! I'm still waiting to get the order
Well I am cutting out the F-14 on my new hot wire foam cutter I got for Christmas, this thing is soooo cool.
Anyway on the plans the main body is cut in half with the engine compartment as one side. MAYBZ, Why do that? Shouldn't that part be made from a single sheet of foam?
Dak...
Dakrat is offline Find More Posts by Dakrat
Old Dec 29, 2007, 08:10 PM
protarget88 is offline
Find More Posts by protarget88
Pocatello Idaho
Joined Jan 2007
[QUOTE= I use tungstene wire with a diameter of 0.09mm, it's thiner than a hair![/QUOTE]
Is the Tungsten wire stronger than nichrome wire? I'am setting up my foam cutter and if the tungsten is a better route to go then I will have to get some.
protarget88 is offline Find More Posts by protarget88
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 02:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 09:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 07:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 09:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 02:48 PM
