Old Feb 06, 2013, 12:40 PM
c0ngit is offline
Find More Posts by c0ngit
Joined Feb 2013
that is amazing. verry good
c0ngit is offline Find More Posts by c0ngit
Old Feb 10, 2013, 09:16 AM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
She flew! Kinda.
MDC F-14 Maiden Flight (0 min 49 sec)
rhysduk is offline Find More Posts by rhysduk
Old Feb 14, 2013, 03:30 AM
eagle14 is offline
Find More Posts by eagle14
France, Basse-Normandie, Balleroy
Joined Jan 2013
Originally Posted by AlfaXray1 View Post
Eagle 14 I built mine at 125% it has 42" length and 42" spread wing span. I use a Turnigy 3536/1300 with a 8.5"x6" APC Prop. Unlimited vertical and nice comfortable speed and flies great. I made it a semi scale full cockpit to hide the battery.
. Thank you very much for your message and your information. Can you tell me if you have made some particular changes with the original plans according to the carbon reinforcement parts for this larger F-14? Also, what servo do you use to moove the wings?
eagle14 is offline Find More Posts by eagle14
Old Feb 14, 2013, 03:34 AM
eagle14 is offline
Joined Jan 2013
Originally Posted by ids911 View Post
eagle14
I have the 100 & 125% size and for me the 125% flys much better, the extra wing area seems to be more stable in the air. Pictures and details are a few pages back
Ian
Old Feb 14, 2013, 11:10 AM
AlfaXray1 is offline
Find More Posts by AlfaXray1
AlfaXray1's Avatar
Joined May 2011
I used the square 3/16" carbon for the wings, and I originally used a 40 ozin MG servo but it would not swing in flight under load. So I put a 85 ozin servo in it still needs to be unloaded for it to swing. So the problem is the big 2" disc that the wing pivots on, giving only about 1" of leverage to push on. There is a modification shown in this forum of using a smaller diameter pivot. If I build another I would use that. It will give greater leverage ( about 2.5" )for the servo to push on. But if I roll knife edge and have the nose up (no rudders) it will swing in flight and looks cool at the same time.
AlfaXray1 is offline Find More Posts by AlfaXray1
Old Feb 14, 2013, 08:14 PM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
My lightly built version had lots of packing tape for SLICKING UP
ALL of the insides of the wing pivot surfaces. Top and Bottom fuse and wings too
It was 12-14 oz depending on Pak used. N)O BIG Motor and therefore no big ESC either.
It moved the wings fairly well under all but pulling G's loads.
Also agree with the More leverage mods being favorable.
Or put one pivot servo in EACH wing as another option.
I'm still available for cutting these kits.
Bob
Hoosier Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Feb 16, 2013, 12:11 AM
Rpotter90 is offline
Find More Posts by Rpotter90
USA, FL, Gulf Breeze-Harold
Joined Aug 2008
And he does an excellent job cutting these kits!!! I just finished mine and I love it! Thanks everyone for the great plane and all 200 some pages of knowledge.
Rpotter90 is offline Find More Posts by Rpotter90
Old Feb 16, 2013, 09:30 AM
Iflyrc_vic is offline
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Airplane?
Alfaxray1, what is the plane in your avatar - blue and white low wing twin?
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Feb 16, 2013, 10:08 AM
birdofplay's Avatar
Joined Dec 2005
If you are looking for a twin
The Twins is a great stable easily built Airdrop sized vehicle
capable of aerobatics too.
It's in Scratchbuilt Foamys
http://www.rcgroups.com/forums/showthread.php?t=1124466
Bob
Old Feb 16, 2013, 10:11 AM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Thanks Bob, I already have the twin foamy - you cut it for me....
Old Mar 02, 2013, 10:32 AM
Coot83 is offline
Find More Posts by Coot83
You haz hurricane?
Coot83's Avatar
United States, VA, Alexandria
Joined Jun 2012
I just built three of these for me and my wingmen...any tips before maiden? I plan to launch them by holding onto the canopy with wings fully extended out. I have them set up with 20 amp esc's with eflite park 370s and 3s 1300s.
Coot
Coot83 is offline Find More Posts by Coot83
Old Mar 02, 2013, 10:38 AM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Coot
Have fun . That's how I launched mine and it works great . Before I lost it in a lake it was my go to flier for bad weather or just fun . Used to fly it by low and slow above the road and let my son throw rocks at it , great fun for both of us
Wilfor is online now Find More Posts by Wilfor
Old Mar 02, 2013, 11:20 AM
Gazzaxr4x4 is offline
Find More Posts by Gazzaxr4x4
Uk Leicester
Joined Dec 2008
Originally Posted by DamonH View Post
I have finished it. I have had two attempted maidens that didn't work out too well. Both flights were short due to lack of speed...just wont accelerate enough to stay airborn. Last attempt lasted longer but speed was so slow that there wasn't enough air flow over tailerons to turn All the plane will do is a nose up high alpha...lol. I know that getting the nose down will help to increase speed but I cant even get enough altitude to get the nose down. I dont really understand what the problem is because thrust is close to 1:1 if I remember correctly. Hmmmmmm, could it possibly just be too tail heavy? If thats the case, I dont have any more room to move batt forward. When I checked cg it seemed to be fine according to the measurements provided in thread. Any suggestions?
Hmm sorry not been around due to ill health but I can only state that motors fans and lipo's is a MUST. . you must use hyperion ys22 6000kv wemotec fans and 3s 4000mah lipo as per my video this set up works a treat for twin ducted fans any thing else don't bother as you can see no power etc but just to prove the point Video attached
F14 MDC Maiden convert to twin EDF (4 min 11 sec)
Gazzaxr4x4 is offline Find More Posts by Gazzaxr4x4
Old Mar 10, 2013, 04:53 PM
Coot83 is offline
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
power setup/belly landing?
Hey guys,
I just maidened my MDC F-14 today and it was set up with an eflite park 370 motor with a 20 amp esc with a prop size of 7x6 I think. Anyway it seemed really SLOW. I would love to get a good motor esc combo for this bird that can zip around pretty good. Also my buddy maidened his first and we realized that we have to catch ours to make sure we dont bust off the prop on the back. Has anyone found a decent landing gear that these could use or some rendition on the bottom of the plane so that I can belly land it instead of having to catch it every time? Any help is greatly appreciated!
Coot
Old Mar 10, 2013, 05:00 PM
AlfaXray1's Avatar
Joined May 2011
Mine flies sl slowly into any wind that it has never caused any damage from belly landing. Maybe try to slow it to stall speed and flare about 1-1.5 feet off ground then let it plop onto the belly mine does this easily.
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 02:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 09:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 07:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 09:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 02:48 PM
