Old Jan 14, 2013, 02:54 AM
eagle14 is offline
Find More Posts by eagle14
France, Basse-Normandie, Balleroy
Joined Jan 2013
Looking for reports of a larger F-14 MDC with simple profile
Hello.
I would like to know if someone has ever built and flown a F-14 MDC with swing wings at a larger scale than the original?
I am interested in building one, but I don't know up to where it could be worth to enlarge the size while keeping the simple profile and good flying characteristics...
I thank you in advance for your help.
Best regards.
Jean-Luc
eagle14 is offline Find More Posts by eagle14
Old Jan 16, 2013, 05:44 PM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
Guys,
can you please help on deciding on a power system for my bird?
I have the choice of the following motors:
Emax 2210 1200kv 16a
Emax 2812 1650kv 15a
turnigy aerodrive 2826/10 1400kv 21a
any help would be great! im thinking a 25a esc if the turnigy would be the motor of choice, not sure on the battery though
rhysduk is offline Find More Posts by rhysduk
Old Jan 16, 2013, 07:17 PM
AlfaXray1 is offline
Find More Posts by AlfaXray1
AlfaXray1's Avatar
Joined May 2011
Eagle 14 I built mine at 125% it has 42" length and 42" spread wing span. I use a Turnigy 3536/1300 with a 8.5"x6" APC Prop. Unlimited vertical and nice comfortable speed and flies great. I made it a semi scale full cockpit to hide the battery.
AlfaXray1 is offline Find More Posts by AlfaXray1
Old Jan 17, 2013, 08:24 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Nice shots.
That motor ought to move it along Nicely !
Now we need some shots of the canopy ?
Bob
Hoosier Cutout Service
with 50% , 75% , 100%, 125% MDC-F14
birdofplay is online now Find More Posts by birdofplay
Old Jan 17, 2013, 08:42 AM
AlfaXray1's Avatar
Joined May 2011
The canopy is the ugliest part. I am going to do a remod to make it more scale. But I'll try to post some shots later.
Old Jan 17, 2013, 01:41 PM
AlfaXray1's Avatar
Joined May 2011
Here is my ugly canopy. Like I say I plan on a complete re-do shortly. I used the template for the profile version and made two and used them as sides and pulled them together at the top. then just traced out a top on a sheet of depron and fit it in the gaps. so it is triange shaped.
I want to do a complet top removal with a scale canopy similar to my Skyray.
Old Jan 17, 2013, 08:35 PM
ids911 is offline
Find More Posts by ids911
ids911
ids911's Avatar
GA
Joined Jan 2009
eagle14
I have the 100 & 125% size and for me the 125% flys much better, the extra wing area seems to be more stable in the air. Pictures and details are a few pages back
Ian
Originally Posted by eagle14 View Post
Hello.
Best regards.
Jean-Luc
ids911 is offline Find More Posts by ids911
Old Jan 20, 2013, 03:29 PM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
She looks great in the air!! Very nice!!
electriceye is offline Find More Posts by electriceye
Old Jan 20, 2013, 05:44 PM
AlfaXray1's Avatar
Joined May 2011
At our club meeting yesterday I was the only one who would fly. Everyone else was scared of the 15 kt crosswinds. But the F-14 hardly knew it was there. Very stable and fun to fly even in high winds. Makes for really slow landings. (vertical).
Old Jan 21, 2013, 04:53 PM
rhysduk is offline
Joined Feb 2007
can someone please help with this:
would this motor:
http://www.electriflite.co.uk/store1...26-101400.html
be much different to this suppo:
http://www.allelectricrc.co.uk/a22126-782-p.asp
im not after super speed, just good vertical and good all round performance.
sorry but have no idea on motors
Old Jan 21, 2013, 06:50 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
The 1st one looks OK and more than enough power.
2212 will scream
Mine was only 12-14 OZ depending on pak and so the rule of thumb
of 100watts per lb applys.
So a smaller one would be good too.
Old Jan 22, 2013, 05:04 AM
rhysduk is offline
Joined Feb 2007
Thanks birdofplay, very much appreciated!
I already have the Turnigy in the first link so was hoping it would be ok without buying another!
So the Turnigy coupled with a 25a esc and a 9x4/4.7 prop would be ok on 2s? And a smaller prop on 3s... I'll see what 3cell Lipos I have and do some weighing tonight of her and see what she weighs.
Am i right in thinking that the only advantage over the 3cell to the 2cell is the flying time?
Old Jan 22, 2013, 05:55 AM
Iflyrc_vic is online now
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
rhysduk, there are many factors that go into choosing the battery for a model. Generally, the choice of how many cells is based on the "voltage" required for the system (kv rating of the motor, propeller and rpm). The flight time is a result how many amps the power system draws and the milliamp (mah) rating of the battery. These two factors are interrelated to give you the power (watts) used by your system.
To get the same power from a 2S battery as a 3S battery, you will draw more amps. In the case where you have the same milliamp rating for each battery (e.g. 1300 mah), the 2S battery will result in shorter flying time than the 3S battery if you draw/use the same power (watts).
Iflyrc_vic is online now Find More Posts by Iflyrc_vic
Old Jan 22, 2013, 07:55 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
You also have another limiting factor on this plane, the size of the prop canyon. You will not be able to use anything larger than a 7" prop, and that's cutting it very close. The best setup for this plane is the motor in your second link with an APC 6X4E prop on 3S and a 30A ESC.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 22, 2013, 08:22 AM
southwesterntech is offline
Find More Posts by southwesterntech
United States, MI, Sodus Township
Joined Aug 2004
Pat
I disagree. The recommended prop for that 1400kv motor on 3S is a 7x4 prop. The same prop that I use on a 1450kv motor, and it works great.
southwesterntech is offline Find More Posts by southwesterntech
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
