Old Dec 13, 2012, 01:31 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I never fail to be amazed by the creativity found in the model airplane hobby.
If I was on a tighter budget I'd be doing exactly the same shopping.
Not braggin, I just get my depron at a slight discount and I have lots of it around.
Plus, I used to live 30 miles from "shopping" and now that I am closer to many outlets,
it's a traffic nightmare to head to town.
Merry Christmas,
Bob
Hoosier Cutout Service.
birdofplay is offline Find More Posts by birdofplay
Old Dec 13, 2012, 06:20 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Originally Posted by AlfaXray1 View Post
Go online print out a Hobby Lobby (Not the internaional one but just plain Hobby Lobby) coupon for 40% off and they sell Midwest 5mm depron you get 2 sheets of 11.5"x47" for about $7.00 with the coupon. That is where I have been getting all my foam and it is fine for the same application as 6mm. Usually it takes 2 packages for most planes. So they are $14 airplanes.
you can make the same plane out of Modelplanefoam for around $4.00 .
16 sheets for $65 shipped and there 24X48 . Thats 3 airplanes for the price of 1 ... your gonna need more motors
Wilfor is offline Find More Posts by Wilfor
Old Dec 16, 2012, 06:38 PM
Poporbit is offline
Find More Posts by Poporbit
Poporbit's Avatar
United States, CA, Aptos
Joined Sep 2012
Thanks birdofplay..I could not find a reasonable cost source for depron until you posted your source's. Shipping was a major killer. RCFOAM charged more for shipping than the foam itself. I'm definately trying modelplanefoam.
Poporbit is offline Find More Posts by Poporbit
Old Dec 16, 2012, 07:26 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I buy in QTYs so my shipping is not so bad.
You will like that stuff :-)
Bob
Old Dec 17, 2012, 10:50 AM
southwesterntech is offline
Find More Posts by southwesterntech
United States, MI, Sodus Township
Joined Aug 2004
Well, it was rainy and cold over the weekend, so I decided to spend some time making it look nicer. I decided the use the decals and templates for the VF-84 Jolly Ranchers squadron. I wasn't going for absolute scale markings, I just wanted it to look better than plain white foam, and it does.
This morning was 40 degrees, overcast, and just a hint of breeze, so I gave in and decided to try the second maiden flight (if that's possible).
F 14 successful maiden flight (0 min 55 sec)
The video is of the initial flight which was short. I flew two more flights that were much longer, checking flight characteristics, stall, high-alpha, wing sweep, etc. I am very happy with the way this plane flies now that I have the CG farther forward!
I plan to build another one of these after I get some other projects out of the way, and I have some ideas for redesigning the swing-wing linkage so that it is more solid yet forgiving in the event you bump a wing.
I'mahappywingnut!
southwesterntech is offline Find More Posts by southwesterntech
Old Dec 17, 2012, 11:14 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Agreed re crappy Weather !
OK OK OK :-)))
Where IS your LIKE IT CG @ ?
Try measuring also from the TOP Inlets back as
everybody's NOSE may not be the same length anymore ;-}
we just wanna know :-)
Bob
Old Dec 17, 2012, 12:20 PM
Joined Aug 2004
I will measure it tonight when I get home and let you know the exact CG, but it is about 1" - 1.5" in front of the spar across the top cover.
Old Dec 17, 2012, 01:50 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Ok that's another good reference point too !
Also re Wing Swing.
There is a good bit of room IN the nacelles for a servo..
With all the NEW MG servos that have come out since 2007
when this thing was initially designed,
I've been meaning to try putting ONE servo on EACH wing
right under the Pivot point and program a MIX to get them
to work in tandem. NO mechanical linkage at all.
Has anyone tried this yet ?
Bob
Old Dec 17, 2012, 01:58 PM
Poporbit is offline
Poporbit's Avatar
Joined Sep 2012
I'm currently building Schumans F22, and finished his F15 last week. The F15 flys better than the F14's but doesn't have the high alpha capability of the F14's. The F-22 is being modified to twin ducted fan's so were getting a lot of experience building.
The weather is too crappy to fly so building is the primary experience at the moment.
Old Dec 17, 2012, 02:13 PM
Joined Aug 2004
Originally Posted by birdofplay View Post
Also re Wing Swing.
Bob
I thought about that too, but my bigger concern is hitting a wing on something, even grabbing the grass on landing with the wings open. This puts a tremendous amount of torque directly back to the servo, and even the strongest metal gear servo would probably not take the punishment for long. This happened to me on the first maiden flight. One wing bumped one of the vehicles and stripped the servo gear. I admit it was not the highest quality servo, but it was metal-geared.
My thoughts were to linkage the wings together so they moved in sync, then drive one of the wings with some kind of elastic pull-pull set up from the servo. If one (or both) wings bumped something, they would both retract from the impact, but would only add a little strain to the servo through the elastic pull-pull system, thus saving the servo, and allowing the wing to move out of the way of the offending object, saving the wing as well.
I'll play with the idea when I get time, but if someone else wants to take the idea and run with it, feel free.
Old Dec 17, 2012, 02:53 PM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
I found that this lands so nice and slow that catching a wing really shouldnt be a concern . Worst case the wings out full elevator power off landing is an easy default . I would think the 2 servo idea would work well .
Old Dec 17, 2012, 03:19 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
It does do a nice wings out Harrier or Pancake.
Bob
Old Dec 17, 2012, 11:28 PM
AirBornOne is offline
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
BTW Bob,
Do I understand you recently relocated to Indianapolis IN. ?
Wanted to ask, what's a Hoosier?
And do you know what Gary IN. is like?
Skies
Jay.
P.S. Just gave your link to some 'Sonic Liner' fanatics re: cutting some parts/kits. Keep us informed.
AirBornOne is offline Find More Posts by AirBornOne
Old Dec 18, 2012, 05:22 AM
Iflyrc_vic is online now
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Hoosier
Originally Posted by AirBornOne View Post
BTW Bob,
Skies
Jay.
Hoosier is a person who lives in Indiana. Most states just use their name (Georgian, Virginian, Texan, etc.) but Indiana uses Hoosier. Just a little trivia.
Iflyrc_vic is online now Find More Posts by Iflyrc_vic
Old Dec 18, 2012, 07:30 AM
AlfaXray1 is offline
Find More Posts by AlfaXray1
AlfaXray1's Avatar
Joined May 2011
From what I have seen of Gary, IN driving through a few times. It is a very poor, industrial looking area. I was not impressed. Defenantly NOT the cute little song from the "Music Man".
AlfaXray1 is offline Find More Posts by AlfaXray1
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
