But but but......it's a dry heat!
![]() Pat |
Latest blog entry: Nico Hobbies
It was cold here this morning (down to 40°, brrrrr), and it's only got to 64° so far today!
![]() And BTW, this plane seems to have gotten popular again all of a sudden. It moved way up on the Parkjets Top 10 downloaded plans for November. It didn't even make the list in October! http://www.parkjets.com/home/2012/12...-november.html Pat |
C' mon guys !!!!
Taking paper off of inferior foam is so ...last decade !!! Depron is available at http://RCFOAM.COM and Modelplane Foam is available at http://www.modelplanefoam.com/ If it's too much $$$ then get together with some buds and share a pile of foam. Or buy a kit from me and I'll sell some blank foam sheets with the kit. 13" x 39" x 6mm only. Bob Hoosier Cutout Service |
United States, MI, Sodus Township
Joined Aug 2004
I hear you about the foam, Bob. I like $Tree foam because I can stop by the store, look through the box and find the nicest sheets, pay $1 each for them, and not have to pay shipping and wait. Also, I use it for all kinds of hobby and craft projects, not just planes. The paper makes a good protector until I get ready to make something, and it peels off easily with no messing around.
Enough about foam. I was working on my plane last night after the not-so-pretty maiden flight, and I found that the wing must have hit one of the cars on the way down, and now my "metal-gear" servo is making a lot of noise when it moves. I have a feeling this is one of those "metal-gear" servos that doesn't use all metal gears. It still works for now, but I know I am going to have to replace it. I also was having some range issues with my radio, and I suspected it was being caused by the "repaired" antenna lead on my receiver. I searched around and found an excellent article regarding FM/PCM receiver antennas and what to do and what NOT to do with them. http://www.rc-cam.com/ant_exp.htm After reading this, I immediately grabbed a 40" section of small gauge stranded wire and replaced the entire antenna lead. I did a range test in my front yard last night and was able to walk about 200' away with the transmitter antenna collapsed before the plane no longer responded. That was the ticket! I then proceeded to route the antenna through the nacelle and out to the root of the wing. I tacked it several places with glue, and ran the antenna wire along the LE of the wing to keep it from getting shortened by the pusher prop. One other thing I realized while reviewing the flight video, was that I think, similar to tripn4days maiden flight, I have the CG too far aft. Even though it is correct per the plans, it was acting like a tail heavy plane. I am going to shift the battery forward farther and see how it does on the "next maiden" if there is such a thing. I will let you know what happens! |
Go online print out a Hobby Lobby (Not the internaional one but just plain Hobby Lobby) coupon for 40% off and they sell Midwest 5mm depron you get 2 sheets of 11.5"x47" for about $7.00 with the coupon. That is where I have been getting all my foam and it is fine for the same application as 6mm. Usually it takes 2 packages for most planes. So they are $14 airplanes.
| Thread Tools | |
| Update for F-14 EDF plan buyers. | bipeflyer | Electric Ducted Fan Jet Talk | 6 | Feb 11, 2005 01:10 AM |
| F-14 Scale EDF Whos kit is it ??? | F900 | Electric Ducted Fan Jet Talk | 6 | Dec 07, 2001 08:26 AM |
| F-14 Tomcat EDF,pictures and questions | bipeflyer | Electric Ducted Fan Jet Talk | 13 | Jul 14, 2001 06:10 PM |
| Great Plane F-14 and Learjet conversions | sbarrow | Sport Planes | 1 | Jun 24, 2001 08:00 PM |
| f-14 center of gravity verus center of lift | tony houk | Power Systems | 5 | May 14, 2001 01:48 PM |
