Old Dec 25, 2007, 10:43 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Maybz - where in AZ are you? Want to borrow something to fly? I am in Gilbert and have an extra just about everything laying around but no MDC F-14 yet.
SS and bird dog with lights, Sunday, Samba, BL Electristar, 63" Cadet... Just let me know. I am sending a PM with my cell #.
(man must fly in weather like this)
Rick
rampman is offline Find More Posts by rampman
Old Dec 26, 2007, 01:42 PM
coolice is offline
Find More Posts by coolice
RobbeUK & Midland Helicopters
United Kingdom, Rushden
Joined Dec 2005
Hey All,
For my wing pivots I used cut sections of an aerosol can lid, specifically I cut rings from the butane gas soldering iron refill cans lid to make bushes with.
They only need to be 5mm high and then I epoxied them around the circular wing pivot pieces, the hard plastic seems to act as a very nice bearing so far.
I didn't take any pictures to post here but hopefully you get the idea I used.
For wing lubrication I sanded both the wings and the areas on the various decking parts which would touch before I added clear selotape as a bearing material. This increased the tolerancing between wing and panels slightly so as not to add any excess drag to the system.
Originally I wasn't going to add the tape, but some experiments without & with showed it does help make the wing sweep a lot smoother.
This being my first depron plane I wanted to make sure it was good from the start, but at the same time finish it to go have a play ;-)
It is a super model and looks great in the air.
Ian
coolice is offline Find More Posts by coolice
Old Dec 26, 2007, 05:20 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Got in a quick flight today. There was about a 5-10mph breeze, but it handled it easily. Definitely a fun plane. I think cut out another set of parts so that I can have a spare....just in case.
Here's some video of the flight.
http://www.rcgroups.com/forums/showa...mentid=1630104
rmgmag is offline Find More Posts by rmgmag
Old Dec 27, 2007, 08:49 AM
choza is offline
Find More Posts by choza
Colombia, Caldas, Manizales
Joined Oct 2007
choza is offline Find More Posts by choza
Old Dec 27, 2007, 04:33 PM
DaniSaez is offline
Find More Posts by DaniSaez
CeNeCe PRO rules!
DaniSaez's Avatar
Barcelona
Joined Jan 2005
Hi all,
I couldn't help it!! Maybz, that is an impressive design indeed!! my very sincere congratulations.
When you look at that design, so clean, so nicely fitting, mmmm... to those who haven't tried to design/draw plans for a beast like this it may seem so easy; but my friends, don't you be mistaken, behind this F-14, there are many hours of tough work! Once again nice work, keep it up!
Anyway, as I said, I couldnt help it, had to have it!
So here are a couple of pics of the cutting process in my cnc hot wire cutter driven by the CeNeCe PRO 1.10:
as you can see, pieces can be placed very close to one another, there are places with 1mm or less spacing!
This is what you get after a couple of hours of doing something else or staring at the cutter :-)
Can't wait to start building!
happy landings!
Dani
ps:choza, what happened to yours??
DaniSaez is offline Find More Posts by DaniSaez
Old Dec 27, 2007, 05:15 PM
choza is offline
Joined Oct 2007
i accidentally switch the dual rate when going at full speed and when i pull back the stick my F-14 just keep falling at full speed and crashes into the ground
Old Dec 27, 2007, 06:02 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Interesting CNC approach !
What is the expected Kerf, in mm, when using a Hot wire ?
Choza - tuff luck :-( !
Ahh ... foamys fix easy too ! you'll be back soon
birdofplay is offline Find More Posts by birdofplay
Old Dec 27, 2007, 06:09 PM
totalywicked is offline
Find More Posts by totalywicked
Insert comment here:
totalywicked's Avatar
Placentia, CA
Joined Feb 2006
I just found this thread this bird looks amazing….
I only have one thing to say “WOW”
I just few questions what program did you use to design this F-14?
Are you going to sell this as a kit or should I go out and buy laser cutter?
totalywicked is offline Find More Posts by totalywicked
Old Dec 27, 2007, 06:54 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Totaly: PM sent :-)
Old Dec 27, 2007, 07:32 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I finally got a few pic of the Vac table jig I made for doing Mike's YF-23.
It'll come in handy for other things as well.
I'm simply powering with my shopvac for the time being.
It's made from 1/4" Sintra PVC sheet and 2" Blue Foam !
I grooved the blue foam to 1 1/2" depth plus an port to
manifold to all the grooves.
I made a single set of YF-23 parts with it and they came out pretty nice.
The idea that MIke had was to place grooves part way thru the depron
right where the bend lines are in his design.
I needed to be able to hold the sheet down FLAT ( all over) , to do this,
hence the VAC fixture.
This will be another great design by maybz for DF or pusher prop !
The bad thing is that it'll require twice the operations to do this since
my machine does NOT have an automatic tool changer.
That'd be ME ! ( ol automatic bob )
So I'll have to cut the sheets then change bits and then
do the grooves.
Old Dec 27, 2007, 07:47 PM
Stephen Shioi is offline
Find More Posts by Stephen Shioi
Glitch
kauai, Hawaii
Joined Aug 2006
Jeez! I would kill for a cutter like that....but then I'd haffta learn how to use it wouldn't I? I'll just keep cutting mund the old fashioned way, lotsa patience and alotta X-Acto blades. Its no secret I love this plane.
SS
Stephen Shioi is offline Find More Posts by Stephen Shioi
Old Dec 27, 2007, 09:01 PM
xwingnut is offline
Find More Posts by xwingnut
xwingnut's Avatar
The Great NorthWest
Joined May 2007
Hey Maybz,
A very greatful Thank You for sharing this project with us. I appreciate all the work you've done. You couldn't have made it easier for someone to understand and build. Only took a day to cut and assemble. Woulda been faster with one of those awesome CNC cutters, those things are neat!
The finish weight of mine is currently at 13.6oz w/TP 1320 11.1v and one of those H/L XT400 Esskay motors. If that doesn't push it then she'll get a Jet Screamers on her back. It's just about ready for paint and that'll push the weight up an Oz.
I cut enough parts for a second build and that one is goin' to get fans and maybe ailerons.
Thanks again and Happy New Year!!
xwingnut is offline Find More Posts by xwingnut
Old Dec 27, 2007, 09:53 PM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
What fans are you thinking? Very interested to see how it flies.
Maybz is offline Find More Posts by Maybz
Old Dec 27, 2007, 10:31 PM
choza is offline
Joined Oct 2007
yeahhh man, i have new nose, tomorrow will be the re-maiden, jojo again i have my MDC f-14 (by the way what is MDC?? )
i just have to sand it and paint it, i made the canopy and the fuselage in one piece, but i'm going to paint the canopy silver or something like that
Old Dec 27, 2007, 11:25 PM
xwingnut is offline
xwingnut's Avatar
The Great NorthWest
Joined May 2007
I have a couple of the small GWS fans. Think they are 40mm? They just about slide into the ducts so it shouldn't take much moddin'.
I just picked up two 5300kv 12mm BL motors and if the fans give at least 7oz of thrust each (which should be easy enough) then I'll be in business. Seems I remember runnin' up one of those fans on a smaller Kv motor and got close to that amount of thrust.
Xwingnut
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
