Old Nov 25, 2012, 11:01 AM
tripn4days is offline
Find More Posts by tripn4days
All Thumbs
Joined Jun 2012
Originally Posted by rayonnair View Post
I'm not sure how your futaba radio is set up, but on the DX6i which is a 6 channel radio with only 2 position switches I set up a mix that did something like the following:
Code:
SW1:      OFF OFF ON
SW2:      OFF ON  ON
POSITION: 1   2    3
Thank you for the tip! I'm running an older Futaba 6XA and wound up running the wings off of the CH6 "trainer" switch/knob. I set the ATV b/t full open and full close and then use the dial to open anywhere inbetween. It works out really nice and allows for an "infinite" number of settings
Wing Sweep (0 min 25 sec)
Now how easy it will be to twist knob while in the air has yet to be seen. All I have left is to install rudders (which seem like the weakest point on this plane; I may try to re-engineer something) and attach the elevators and motor.
tripn4days is offline Find More Posts by tripn4days
Old Nov 25, 2012, 11:12 AM
All Thumbs
Joined Jun 2012
Originally Posted by Poporbit View Post
tripn4days Strip off the paper from the foam and cover the foam with clear packing tape. This is stronger, lighter and more durable than the paper.
Sounds like a lot of work... Doesnt the foam get get warped? I would have a hard time applying even pressure across the 100+ strips of packing tape.
Old Nov 25, 2012, 11:32 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I tried Knobs on my older Polks Trakker III synth tx. ( 72Mhz )
it was difficult to locate and manipulate so I ended up using 3 posn switch.
Alternately, My new Futaba 8FG Super has a slider under each side of the tx.
So, 8FG owners should be able to make Wing Swing setup with infinite possibilities.
Best
Bob
birdofplay is offline Find More Posts by birdofplay
Old Nov 25, 2012, 11:49 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Anyone looking for the Build Manual can f9ind it at
http://www.rcgroups.com/forums/showp...&postcount=510
Thanks again Walt Haden for putting it together for the group.
Best,
Bob
Hoosier Cutout Service
Old Nov 25, 2012, 12:51 PM
my_names_nobody is offline
Find More Posts by my_names_nobody
full throttle flyer
Joined Nov 2012
Originally Posted by birdofplay View Post
Cant remember right off but I did a search using 125% and came up with these
http://www.rcgroups.com/forums/showp...postcount=2865
http://www.rcgroups.com/forums/showp...postcount=1178
I never finished my 125% although I see several other have had success.
Best
Bob
got it thanks for the link 58inch wingspan . thats a decent size
my_names_nobody is offline Find More Posts by my_names_nobody
Old Nov 25, 2012, 02:38 PM
All Thumbs
Joined Jun 2012
Wow great build manual! Unfortunately I didnt see it prior to building, but managed to print off pretty much all the same pictures
Old Nov 25, 2012, 05:45 PM
rayonnair is offline
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
http://youtu.be/NMe617h_aHw
Rudders are tricky. My mod worked but not too well due to massive coupling. For normal flying they are unnecessary... I just wanted to do knife edges and spins!
rayonnair is offline Find More Posts by rayonnair
Old Nov 25, 2012, 06:53 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Knife edges should be doable with all that Rudder and Fin area !
about a month ago I saw some guys at a local club with those
little foamy flying wings and was very surprised at how tightly they could get their
plans to spin INVERTED !
That's be a nice rick for the swing wing to be able to do.
Bob
Old Nov 25, 2012, 07:19 PM
All Thumbs
Joined Jun 2012
Yeah after tinkering a bit, I also programmed the landing gear switch. I figure I switch it at the field if the knob is too cumbersome
Old Nov 26, 2012, 12:47 PM
southwesterntech is offline
Find More Posts by southwesterntech
United States, MI, Sodus Township
Joined Aug 2004
the 939mg is supposed to be good for 5.5 lbs of torque - AKA 2.5 Kgm
If the model not built slippery enough to accommodate that much force
then there is a problem.
Oh it is slippery. I have coated the wings and fuse with packing tape, an also cut out a couple of "bushing plates" from clear plastic sheet protectors that will go between the wings and the fuse. Then I will dust everything with graphite before final assembly of the top plate.
Sheeez , coming up from old mainframe type of computers then Unix workstations
then PC came of age and now everybody is a computer expert.
So I get a CNC machine 15 yrs ago and AND ONCE AGAIN, seems like everyone has access to one now.lately...
I am an IT engineer, but have an extensive background in mechanical engineering as well as manufacturing and machining. My son is taking an advanced course at the local college where they have a fabrication laboratory with both a ShopBot and a laser cutter. Believe me, I would love to have my own CNC table in my garage. Maybe someday.
Bird, we are not that far apart. I live in southwest Michigan, about 4 hours from you. Maybe when I am heading your way, I will drop you a line and we can meet.
Brian
southwesterntech is offline Find More Posts by southwesterntech
Old Nov 26, 2012, 04:20 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I grew up in Greenville Mich,
used to Live near Niles and have flown Full sized Gliders
near Gregory Mich at Sand Hill Soaring ! ( The Blanik )
C U L8r
Bob
Old Nov 26, 2012, 07:46 PM
Joined Aug 2004
I live in Sodus, which is a small farming town just outside Benton Harbor, about 20 minutes from Niles. The fabrication class that my son is taking is at the Lake Michigan College campus in Niles. Small world, huh?
Old Nov 27, 2012, 08:05 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Sodus ! been there done that :-)
Used to Leave EKM in my PA-28 and go do T&Gs at area airports like,
Niles, Berrien Springs, Cold water et al
Seems like I remember the BH RC club did Glider contests.
Also flown RC Gliders at the Dunes.
L8r
Bob
Old Nov 27, 2012, 01:30 PM
Joined Aug 2004
I just about grew up at the Berrien Springs Airpark (C20). My dad owned a Navion that we kept hangared there, and later in life he and I build a Rutan Vari-Eze that we also kept there. I did some of my flight training at C20 as well. Many fond memories of that place. I only live about 10 minutes from there.
Old Nov 27, 2012, 04:31 PM
Borstenhorst is offline
Find More Posts by Borstenhorst
Germany, HE, Oberursel
Joined Nov 2012
So,
I build my very first plane and decided to choose this one. Maybe not the easiest but I liked the design so much !!
Because depron is so expenive here (5 per sheet) i build it out of cheaper material which has a profile I also modified the design a little since the foam is just 4-5mm thick. I use some wood for the stability.
So this is a video of my second try, its kind of the maiden flight since the first try was a bit ... destructive.
The reason why it was not flying properly was that I made a small mistake in the firmware.
Firmware?
I use this foamy to integrate some microcontrolling stuff. Like v-mix, auto-stabilsation, a flycam which is stabilized by a servo , some lights, also a GPS module is here but Im afraid that it will be to heavy.
Also this is the first plane I ever build and the first time i controlled one, for that Im satisfied.
Talked enough, here is the video!
Foamy Test2 v1.0 (1 min 33 sec)
and some pictures:
Borstenhorst is offline Find More Posts by Borstenhorst
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
