Old Sep 07, 2012, 03:22 AM
rayonnair is offline
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Robrotor, that's what the bend in one of the wires is meant to do? Try adjusting that first!
rayonnair is offline Find More Posts by rayonnair
Old Sep 07, 2012, 07:32 AM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
That might work. I've had to adjust the distance of the hole for the push rod from the center of the pivot.
alpea 41 is offline Find More Posts by alpea 41
Old Sep 07, 2012, 11:02 AM
Robrotor is offline
Find More Posts by Robrotor
United States, AZ, Chandler
Joined Feb 2012
The bend will adjust it but then it's off for the other swing positions. Probably need to do what Alpea41 did and change the position of one of the pushrods on the arm. Just adjusting the bend will change all three positions which is the problem I'm having. Robert
Robrotor is offline Find More Posts by Robrotor
Old Sep 07, 2012, 11:13 AM
rayonnair's Avatar
Joined Jun 2012
Ah, OK. Yeah probably the quickest way is to have a different push rod entry point on one. Good luck
Old Sep 07, 2012, 05:59 PM
Son of Alpea41 is offline
Find More Posts by Son of Alpea41
Son of Alpea41's Avatar
Joined Apr 2010
I have a HS-65 Mg to swing the wings on my F-14.
Son of Alpea41 is offline Find More Posts by Son of Alpea41
Old Sep 07, 2012, 09:09 PM
Robrotor is offline
Joined Feb 2012
What do you need a servo for? I never saw the wings sweep in your vid. LOL Robert
Old Sep 08, 2012, 12:00 AM
Robrotor is offline
Joined Feb 2012
Figured out the uneven swing problem...I had drilled the holes on the servo plywood arm at different lenghts from the center. Made a new arm and CAREFULLY measured and drilled the holes and BINGO, even swing at all positions. Robert
Old Sep 09, 2012, 07:14 AM
rayonnair's Avatar
Joined Jun 2012
There you go! Make sure you give us those purty pictures =)
Old Sep 12, 2012, 12:43 PM
rayonnair's Avatar
Joined Jun 2012
Rudders
Banged the rudders together in a few hours. Pics as attached, with comments.
I used these ultra-thin servos from Hobby King. They're about 9mm thick.
I put a 6mmx0.5mm carbon fibre piece on the vertical stab to make it stiffer. It goes all the way along the vertical stab, through the deck, and continues down on the nacelles - see the pics.
The video shows the added stiffness from the CF and the rudders working.
MDC-F14 Rudder Installation (0 min 17 sec)
The MDC F-14 has become one of my most reliable flyers. Hopefully with the rudders I'll be able to do fun things with it. Test flight is this weekend. Hope I can co-opt a camera man. I'll let you guys know how it goes.
Edit: last picture has words cut off. It should end "so the z-bend in the wire fits and there is no slop".
Edit 2: Forgot to add, additional weight is about 31g.
Old Sep 13, 2012, 12:19 PM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
I've added rudders to a tohme F-22 and found they were real helpfull in slow speed hi alpha flight.
Old Sep 13, 2012, 11:10 PM
rayonnair's Avatar
Joined Jun 2012
Yeah, I hope to do more interesting things with the MDC F-14 with the rudders. Even an ugly flat spin and a simple knife edge would be so great. Being able to steer while harriering is something I'd have to do once I learn how to harrier .
Depending on how it performs, I will then re-build the entire thing while trying to make it as light as possible. It wallows at over 600g. I want it about 100g lighter.
Old Sep 14, 2012, 10:46 AM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
12 -14 oz is easily done - even I did it.
But you may have to give up the larger motor that a lot of guys use .
Of course at that weight it wont need to be so large and the lipo too.
Back in 2007-08 when we started this Mike and I were quite happy with the lighter built versions.
birdofplay is online now Find More Posts by birdofplay
Old Sep 15, 2012, 01:43 AM
rayonnair's Avatar
Joined Jun 2012
Welp, rudders induce so much roll coupling that I can barrel roll the F-14 almost as fast as I can aileron roll it with the wings swept back. My knife edge dreams are shattered. The coupling was so fast and severe that I'd spin out and couldn't hold the edge. Maybe someone with lots more experience and a good computer Tx mix.
Roll direction is in the direction of the rudder turn.
The only new thing it can do now is a wide flat "spin". Not exactly a spin because it's just corkscrewing in a flat attitude, but looks pretty interesting. Imagine the parachute maneouvre but instead of flying straight you are turning in a lazy corkscrew. Takes forever to come down.
The glide slope from the added weight was noticeably sharper.
Anyone have any ideas on Tx mixing?
Old Sep 15, 2012, 06:02 AM
AlfaXray1 is offline
Find More Posts by AlfaXray1
AlfaXray1's Avatar
Joined May 2011
It appears from your video that you have too much rudder movement. Take out about half of that and try pulling up to a 45 deg climb angle then roll into the knife edge and see just how much rudder will try to hold the nose up. It may take very little and that will induce less roll coupling, easier to adjust for with aileron. Just something to try.
AlfaXray1 is offline Find More Posts by AlfaXray1
Old Sep 15, 2012, 01:51 PM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
The rotation over on it's back from knife edge is too much rudder input and is common with both flat foamies and balsa 3 ders .. In my experience ... A tohme F-22 and now a Twist 480 . The rudder turns it as if it were aileron.
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 02:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 09:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 07:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 09:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 02:48 PM
