Well, due to customer orders and an upcoming vacation back home to Florida, my mini-me has been put on hold until mid-June. I'll come back and give an update once I get back to it again. I'd like to have them up on the website by July.
Pat |
Latest blog entry: Nico Hobbies
Way back up the thread you will find that the designer did not use a any thing
across the top deck. I did not on mine either. It started showing up because guys just couldnt believe that the top deck would hold up with just the bonding at the boss's. A heavy built version might be a problem but when lightly built the F-14 should not need it at all. Bob http://www.balsabuddies.com/cutouts/bbshop.htm |
Servo slower
I got mine from this company. http://www.robotmarketplace.com/store.html It's in the RC Gear section.
It works great. Price was $15.99 plus shipping. It's called the DigiSlower servo slower and it is programmable. You can adjust the travel amounts and the speed. As it came out of the package the speed was slowed down enough that I didn't have to mess with that function but I did have to adjust my travel throws cause I already had the servo in there and fuly adjusted and the top pieces of the fuselage glued on. No way to get in there to mechanically adjust anything so I tried it on an extra servo I had on the bench to see if the throws matched what was in the plane swing wing setup. It was a little off so I adjusted it usuing that external servo, got it to match my burried internal servo, then plugged it into the model. It worked perfectly. Tom |
Ted |
Yea, if your are still building, wait to get the digislower before setting up the swing wing servo throws. I did it the hard way, but it worked out OK in the end. I had read where you couldn't slow down a retract servo, so I went ahead and finished the model. Then I realized, this aint a retract servo, it's s regular servo (HS65) simply working off of the retract switch. So, I odered the digislower and the rest is history. Tom
Ted ps - you can see pics of my build in post #1700 |
http://www.rcgroups.com/forums/showp...postcount=1729 I have some Mods as you can see the top cover can be removed to do repairs...... and a better sweep wing attachment
Manila
Joined Aug 2006
Fanally managed to get some vid on the 75% last weekend.
Here's it is, with my crappy flying
UK, Sussex
Joined Jan 2009
Had the first couple of flights on mine (100% version), using a 120W power setup with 6x5.5 prop. I haven't sanded any leading/trailing edges yet. It seemed slightly underpowered, so I've swapped the prop for a 7x5 which should produce 140W. Will be interesting to see how it performs with this. I also plan to do some edge sanding.
The wings didn't like coming back fully forward unless I slowed right down, despite having used tape and spacers as per this thread. Perhaps my spacers (card) weren't really thick enough. It was pretty sensitive with linear controls. A bit of expo and dual rates calmed things down. It was fairly windy, but I found that there were occasional uncontrolled roll movements. Is this just the way this model gets blown around when it's windy? I'm used to seeing a little more yaw and less roll. It is fun
| Thread Tools | |
| Update for F-14 EDF plan buyers. | bipeflyer | Electric Ducted Fan Jet Talk | 6 | Feb 11, 2005 01:10 AM |
| F-14 Scale EDF Whos kit is it ??? | F900 | Electric Ducted Fan Jet Talk | 6 | Dec 07, 2001 08:26 AM |
| F-14 Tomcat EDF,pictures and questions | bipeflyer | Electric Ducted Fan Jet Talk | 13 | Jul 14, 2001 06:10 PM |
| Great Plane F-14 and Learjet conversions | sbarrow | Sport Planes | 1 | Jun 24, 2001 08:00 PM |
| f-14 center of gravity verus center of lift | tony houk | Power Systems | 5 | May 14, 2001 01:48 PM |
