Old May 15, 2011, 05:26 PM
American since 1947
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I put a massive 68MM fan in a simple Eliworm F-15.
It pulled 60-80 amps and it flew LIKE A BRICK !
Sounded like a Kirby Vacuum on Steroids and was kinda scary
but
I only had one good flight when I forgot WHAT SIZE lipos I'd been using
and put some nice small and light ones in it.
Snappy performance but SHORT Flight as BOTH 2s1p paks
BLEW UP like AIR mattresses !
OK I'll got see whats up in that forum.
birdofplay is offline Find More Posts by birdofplay
Old May 15, 2011, 05:56 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Parts are cut and assembly has begun. I should be finished up this coming week and maiden next weekend.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old May 15, 2011, 09:30 PM
Shut up and talk to me!!
Manila
Joined Aug 2006
Pat
Looking forward...
My build is stalled, waiting for parts....
deanc338 is offline Find More Posts by deanc338
Old May 18, 2011, 08:39 PM
Memphis Tennessee
Joined Apr 2010
great plane, thanks for the plans.
hs-85mg on the wing swing
grayson hobby 30amp esc
grayson hobby microjet V3
1500mah 25C lipo
AUW 13oz
Mk2 F14 (1 min 22 sec)
afitz87 is offline Find More Posts by afitz87
Old May 21, 2011, 08:12 AM
Manila
Joined Aug 2006
Maidened the 75% this aftenoon and it was a blast. Since I used dollar three boards the vertical stab flutters during high speed flight. I'll put some CF rods to stiffen it a bit.
The HXT900 for the swing wing seems to hold up, but also feels like it is struggling sometimes. Anyways, like other comments rolls are slow when the wings are out.
Old May 21, 2011, 04:16 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
My vertical stabs are 3mm depron. Maybe I'll add come CF strip in them to help them hold up. Haven't put them on yet, so I'll do it before installation.
Pat
Old May 21, 2011, 09:27 PM
Hampton, VA
Joined Mar 2009
Crxmanpat,
You do need CF flat or rod in the vert stabs. A trick I stumbled on, split a 3mm CF flat down the middle with an exacto knife. Then I dremel a slot 2mm deep. Works like a charm and you use half the CF.
Ksqm
ksqm is offline Find More Posts by ksqm
Old May 21, 2011, 09:57 PM
Manila
Joined Aug 2006
I just put a 1mm slit on the foam and slide a 3mmx1mm flat CF on it. Very similar to Pat's method of putting spars on his 18" profile jets. Quick and easy.
Old May 21, 2011, 09:59 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I'll just use my normal 1mmx3mm flat stick and cut a 2mm slot in the foam.
I think my tails are going to wind up solid black anyway, so you won't be able to see them.
Pat
Old May 24, 2011, 04:47 AM
UK, Sussex
Joined Jan 2009
Finally started on my build last night. Only had time to glue a few bits together, but everything fits very nicely - nice job birdofplay! I'm planning to use a paint scheme a little bit like this, for visibility:
Davee1 is offline Find More Posts by Davee1
Old May 25, 2011, 12:16 AM
So many planes, So little foam
gearhead351's Avatar
USA, CA, Vista
Joined Jan 2011
I just have to say what a great plane this is! I can't wait to build one. just one question... I've read this thread all the way through and am gearing up to build one. while ordering servos from Grayson, I ran across the super mega jet motor combo. I ordered it (thinking that it was closer to a supersonic) but now im wondering if it is too big for the 100% version of this plane. if so, how big do you guys think id have to scale it?
http://www.graysonhobby.com/catalog/...2ce94117a3c6d5
above is the link to the combo. thanks to all, especially Maybz and BoP for all the hard work.
GH
gearhead351 is offline Find More Posts by gearhead351
Old May 25, 2011, 12:58 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
With that motor you could go 125% on this plane.
Pat
Old May 25, 2011, 06:48 AM
USA, CA, Vista
Joined Jan 2011
thanks Pat, for the quick reply. you say I could, but do I have too? I usually like to keep em smaller. (I drive a car) that motor is pretty heavy so im wondering how that would affect balancing the cg. by the way, I just did the sr-71 you posted at 75% with DS foam. came out great. ill post video in that thread when I maiden it. thanks again for all the help.
GH
Old May 25, 2011, 07:25 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
No, you could stay at the normal size. But that motor is overkill. Still OK though.
Pat
Old May 25, 2011, 09:24 AM
American since 1947
birdofplay's Avatar
Joined Dec 2005
Thanks for the comps DAVEE1 !
I think yours was delivered faster than my poor Canadian customers.
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
