I started my build a couple of weeks ago after following this thread for a long time. I have not been in any great rush as I have a half dozen planes to fly and don't really have room for more, but I really like this model. (My son finished his several weeks ago [post 1549] and I have flown it a couple of times.)
This evening I finished what i consider to be the hardest part of the build, the wings and sweep setup. Whoohoo! Now on to complete the build and the second hardest part... which squadron scheme to apply. Pictures later. Ted |
Finis!
I just piddled and took a long time to build, but I finally finished today!
Like most, I made a few minor changes along the way. I changed the contour of the nose for a more scale tapered to a point look, and made the aft portion of the bottom fuselage a hinged access panel to the receiver and ESC instead of gluing it closed. That was about all since this is such a well designed model, THANX Maybz! The wing sweep is not as free as I would like. Was fine until I closed it up, so I think the top deck is pinching the wing some. Probably due to the paint. I'm counting on it freeing up some after several flights. Finished weight is 405 g or 14.3 oz (no battery). I really liked GG's sunset decal scheme as being unique as well as eye catching. A BZ (bravo zulu is the signal for 'well done') to GG for his great work on the graphics. Next is the fun of flying this puppy! Cheers, Ted |
Thanx. Although I have yet to maiden this one, I can make a comparison based on the one my son built a couple of months ago. Both of these models are great flyers, but are as different in flying as they are in looks. The F-14 requires a bit more attention than the Mig especially with the wing at full sweep while the Mig is more nimble at slow speeds. If you watch Maybz's and Tomhe's videos at the beginning of each respective thread you will get a sense of what I am trying to describe. The F-14 is a more involved build which is obvious as well. The unique thing about the Tomcat is that it flies differently at each wing sweep position. 3 models in one for the typical sweep setup. ![]() I think anyone with a modicum of flying skills and a little patience in building would be happy with either model. Even happier with both! Your Mig is a beautiful example of those skills! There is not much that can be done to mod the F-14 (mostly resizing), but anyone building the Mig should add ailerons to get the most out of it (hint, hint) and maybe consider the battery box / intake mod I did on mine.Cheers, Ted |
Hampton, VA
Joined Mar 2009
Excuse the question, but outside of the vid and pics of a smaller scale bird (page 18), has anyone posted plans for a scaled down version of Maybz's Tomcat??? I've been searching and can not find any. I'd like to to try a 3/4 to 1/2 smaller scale. I have some 3mm foam in need of rebirth.
If no plans are posted, outside of resizing the tabs and slots, any other advice??? |
Ted, Thanks for your thoughts on the comparison between the two. I need to get those ailerons linked up on the Mig and build one of these too. Looks like a fun airplane. Ben |
Hampton, VA
Joined Mar 2009
Thanks Birdofplay for the info. The plan is to start with a couple of straight forward builds (f22, f15, etc). Then do the f14. I'm looking at overall length's to be in the neighborhood of 16 - 18 inches max, with corresponding wing spans. Challenges will be power plant weight to thrust, servo vs actuator usage, and battery weight/size. I'll keep you posted as I hope to start this weekend sometime.
Mine is just about ready for it's maiden. Gotta finish up paint, adjust control throws (may need longer servo arms), add a strap for the battery, and magnets for the battery hatch. Then it's just adjust CG and give her a toss.
Could someone please post a photo of their battery installation? Preferably a 1800-2200 mah one. I would like to see the hold down method you used as well as the actual location of the battery when installed. |
| Thread Tools | |
| Update for F-14 EDF plan buyers. | bipeflyer | Electric Ducted Fan Jet Talk | 6 | Feb 11, 2005 01:10 AM |
| F-14 Scale EDF Whos kit is it ??? | F900 | Electric Ducted Fan Jet Talk | 6 | Dec 07, 2001 08:26 AM |
| F-14 Tomcat EDF,pictures and questions | bipeflyer | Electric Ducted Fan Jet Talk | 13 | Jul 14, 2001 06:10 PM |
| Great Plane F-14 and Learjet conversions | sbarrow | Sport Planes | 1 | Jun 24, 2001 08:00 PM |
| f-14 center of gravity verus center of lift | tony houk | Power Systems | 5 | May 14, 2001 01:48 PM |
