rack system
Good idea there BirdOfPlay..you know to get the 2.8 " of travel there are many small hi torque boat winch servos on the market that wound fit. they turn 2 or 3 times would have to have like a long arm and use the end points in the radio to program the servo to only move in a certin range. or a small retract servo .. seems hobby lobby has some flat push / pull servos..
http://www.advantagehobby.com/produc...cat=321&page=1 or chain drive..LOL http://www.servocity.com/html/servo_...s___chain.html and for the heavy duty power http://www.servocity.com/html/heavy_...vo__25__l.html sorry could'nt help myself Bird.. the dual servos sound like the plan... Randy |
wing sweep
You know we really don't need to redesign anything.. even on the 150% bird one servo works just fine..i have never had any problum once i set it up right.. but hey ,, our hobby is all about trying new things.. myself i will stick with has worked fine for me..getting ready to cut out 150% #2 this one will be heavly modded. hotwired foam wing cores.airfoil.sheeted w/ailerons.full fuse...retracts...will spend sometime on this one .. will be going with a e-flite power 90 on this one.fins will be 4 inches farther apart so i can run a larger prop.
Joined Sep 2007
Wouldn't it work relatively easily to have one servo in the current location, maybe a bit further back, then a second directly in front of it facing the opposite direction? It could be setup to basically operate similar to how the one large horn pulls the wing wires to opposite sides and you could then easily adjust wing positions, which for me was the biggest headache.
Even without any wing modding though, this plane flies incredibly well with a good servo once you get it setup and the rudder is something that I think everyone should do! |
Joined Feb 2009
Joined Sep 2007
I had my battery door open up today while doing a super fast roll with the wings swept! Luckily the piece of wood I have on the front of the door is tight enough with the front of the battery that it didn't come off and the battery didn't fall out.
On my first landing attempt I dropped throttle as usual but the door was acting like a brake and I almost went in to some trees! I recovered it and this time brought it in hot since my stall speed had increased from the door. Once I got it low enough I killed the engines to land it but it glid further than I thought it would and hit a small tree! The trunk of the tree smashed the right portion next to the cockpit enough to break the glue joint but not enough to warrant any repairs. It was a very small tree, like the size of my wrist around or so. One of the wires attached to the tree sliced off a portion of one wing tip. I glued the wing back together, added some velcro straps to the middle of the battery door so that wouldn't happen again and went out for 2 more flights. Still flies great! |
I'm in the process of building mine - it is my first depron build ever, so we'll see how it goes. I have most of the fuse done, and the wings are together (although a little ugly).
I am using an HS82MG for the wing sweep and I have a quick question - should I cut the mount tabs off of the servo or just open the hole up in the depron mount piece? Thanks UJ |
Joined Sep 2007
Neither. You glue those two pieces of foam together then, making sure to have the servo orientation correct you drop it down into the square whole (which you can enlarge if it doesn't fit your servo). When you glue this to the fuse you are basically sandwiching the servo mounting tabs between the fuse and the two foam pieces you just glued together.
I'm a bit confused. Does this work even with the HS-82? It looks different from the picture from the build. It seems that this would be up too high for the top deck... |
Joined Sep 2007
You can countersink the servo a bit in the foam if you need to so the top is the same, or you can add some foam strips next to the servo so that when you install it the top of it comes up like in the pictures.
IIRC, when I retrofitted my S3102 servo into the plane I added some foam spacers on either side of the servo so that it didn't stick up too high above the deck. |
| Thread Tools | |
| Update for F-14 EDF plan buyers. | bipeflyer | Electric Ducted Fan Jet Talk | 6 | Feb 11, 2005 01:10 AM |
| F-14 Scale EDF Whos kit is it ??? | F900 | Electric Ducted Fan Jet Talk | 6 | Dec 07, 2001 08:26 AM |
| F-14 Tomcat EDF,pictures and questions | bipeflyer | Electric Ducted Fan Jet Talk | 13 | Jul 14, 2001 06:10 PM |
| Great Plane F-14 and Learjet conversions | sbarrow | Sport Planes | 1 | Jun 24, 2001 08:00 PM |
| f-14 center of gravity verus center of lift | tony houk | Power Systems | 5 | May 14, 2001 01:48 PM |
