wing loading
All of mine 6 but one has been in the 19 to 24 oz weight with very hot motors and 2100 3 cells and 2200 4 cell packs..i have found that building these in the 20 oz range. and useing the good servos ie HS85mg ..even putting the plastic on the wing bosses as BirdOfPlay has said and i use the very very slick UHMW tape . you can find at lowis or home depo..with the design of the pivot area, you will still have to unload the wing a bit with a touch of down elev for the wings to sweep forward in high speed flight..i have also found that you need a very small amount up & down play at the wing root. just what works for me...
check out http://www.rcgroups.com/forums/showt...0#post10937366 |
Joined Sep 2007
Mine moves very freely with the top deck glued down. I used CA so no foaming going on. The wings moved very well with the Corona's on the ground. I even got the smacking sound as they closed against the rear foam pieces. The issue definitely is from wing loading since it works perfectly fine (and fast) in the air when I do a maneuver to remove the load from the wings. It really wasn't a speed issue either. I could do a full speed loop and at the top I could open/close the wings.
I've got the Futaba S3102 servo in and with the 57oz I shouldn't have any issues based on your S3003 working. Still, I'm heading to Westlake's to get some UHMW tape. I'm going to do all I can to reduce friction so hopefully it will have no problem operating in the air. |
still at work
BirdOfPlay
i'm still over here in Saudi intill the 15th..think i will spend my time home this time to finish my CNC. getting tired cutting things out by hand..LOL..I have a lot more done on it than the pictures show.the pictures are a month old..ready for the steppers and getting it all dialed in..spending my spare time over here converting my stuff to g code to be ready..my stepper package should be waitting on me when i get home..all ready got the plans for the next one..the Joe's 4 x 4..this one was a great learning tool..and another habit to pick up..but my wife thinks it's cool. so that helps sgf323.. going to be very hard to do a refit with the tape if you are flying it now..you did make poster board templates of all the parts before you assembled the bird..Right??..so you could cut out another one.LOL. for the tape to help it needs to be top and bottom on the wing and under the top plate..in everyone of the one's i have done. you had to unload the wing to get a good forward sweep in flight..but still way too cool in flight..the 58" wing span one is freaky cool, it wows everyone everytime i fly it. big as it is a gentle hand toss and she is off.. |
Joined Sep 2007
Are you kidding? Of course I didn't take time to trace anything! I figure if I need to I'll have kinkos print me up the PDF.
I had no problems opening up the top though. I just used a thin metal ruler to break the glue joints by sliding it between the wing and the deck. I also used wood spacers which made it easier. I'm putting poly tape on top and bottom decks as well as on the top and bottom of the wings. If it can't open and close without unloading I'll be ok with it, I just want to do everything I can along with going to the stronger servo. |
tape
sounds like you have it well under control..one other thing i do is i always run a external BEC .. even thro it's a small plane, the reason is i can program it to suppy 6 volts to the servos..most speed controls only supply around 4.8..you can almost double your servos torque..like on the HS85MG that i love in this bird.. that 7 oz makes a world of diff..my 2 cents anyway
4.8 volts is 42 oz of torque 6.0 volts is 49 oz of torque On the pdf file my local Kinkos has a large format printer that will print right on heavy posterboard..really nice saves spray glueing the print and sticking it on your self.. they charge like $ 2.25 more to print on posterboard to me it's worth it.. but in a month with my CNC finished, just load the foam and hit start..LOL..going to love it.. enjoy the bird, like others in here you will be building a lot more and souping them up..so far the fastest has been the one with the JustGoFly 450TH...4.5 X 4.5 prop and 2400 4 cell pack..got to fly to beleave..so fast and at the same time goes so slow in high Alfa with a nice breeze..i try to keep mine in the 19 to 22 oz range works for me.. |
Joined Sep 2007
Yeah, I bought several HXT UBEC's from HC last year and finally have a reason to use one! I put it in and ended up burning up one of my Corona DS929MG's because I left the switch in the open position and it only opened mid-way. I kept it like that for the whole flight and when it got down it was dead.
I replaced it from the bottom with another 929 which worked well after I learned the unloading tip. Next time I go out it will be with the 57oz S3102 and the poly tape so hopefully it's at least a little easier! Less friction and nearly twice the torque has got to get me somewhere! |
Looking good Randy !
My original Shopbot was on a wooden table. I eventually went to a metal Fab shop and simply had them cut for me. Then I converted teh Cable drive to Rack and Pinion and , well ... So far so good :-))) If I wanted stronger capability I could upgrade the Steppers. I have some BIG Nema34's but since I mostly do Foam now, it hardly seems worth it. Especially when Speeds and Feeds for foam are in my current capability. I'm already way over kill for foam with a 3.25Hp router. Practice a bunch with CAD, Conversions and on screen simulations. Then just go for it :-) ----- Oh and IF I hadnt bent TWO (2ea) 5mm shafts already on another bigbird I might consider getting my BIG F-14 out of the closet and finishing it. Sorry if I already asked but, Whats your AUW on that BigBoy ? |
| Thread Tools | |
| Update for F-14 EDF plan buyers. | bipeflyer | Electric Ducted Fan Jet Talk | 6 | Feb 11, 2005 01:10 AM |
| F-14 Scale EDF Whos kit is it ??? | F900 | Electric Ducted Fan Jet Talk | 6 | Dec 07, 2001 08:26 AM |
| F-14 Tomcat EDF,pictures and questions | bipeflyer | Electric Ducted Fan Jet Talk | 13 | Jul 14, 2001 06:10 PM |
| Great Plane F-14 and Learjet conversions | sbarrow | Sport Planes | 1 | Jun 24, 2001 08:00 PM |
| f-14 center of gravity verus center of lift | tony houk | Power Systems | 5 | May 14, 2001 01:48 PM |
