Old Dec 11, 2007, 08:05 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Maybz,
Outstanding piece of work. One of the best build logs I have seen. Just very good documentation on an inspiring model.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Dec 11, 2007, 11:45 AM
fall666 is offline
Find More Posts by fall666
To me, every day is Saturday
fall666's Avatar
DAL/FTW
Joined Jul 2006
Please let me know if/when you have kits available.
fall666 is offline Find More Posts by fall666
Old Dec 11, 2007, 02:05 PM
bigbadbob2003 is offline
Find More Posts by bigbadbob2003
bigbadbob2003's Avatar
Joined Nov 2007
Hi people heres an idea for auto sweeping wings on the f-14 using a spektrum dx7 which should b adaptable to other transmitters
1. Set the model type to a heli
2. Set the swash plate type to 1 servo norm
auto sweep:
3. for throttle curve norm, st-1 and st-2 use a linear gradient 0 to 100%
4. for pitch curve norm use a flat line at 0% (wings no sweep)
5. for pitch curve st-1 use a flat line at 100% (wings at full sweep)
6. for pitch curve st-2 create a curve so that as you start to get near the top end of the throttle then it starts to climb (see pic)
Elevon mixing:
7.in "prog mix 1" use the following
AILE->ELEV ON
RATE: +100%
+100%
SW:ON
OFFSET: 0
8.in "prog mix 2" use the following
ELEV->AILE ON
RATE: -100%
-100%
SW:ON
OFFSET: 0
ive attached pictures of the dx-7 screens to give you an idea on my setup sorry about the quality.
on my st-1 mode i have the wings opening if the throttle gets to nearly off.
This setup means in normal mode and st-1 you can sweep like on maybz' setup but on st-2 you can have a dynamically changing wing sweep like on the real f-14
wing servo is on the aux1/pitch/flaps channel
hope all that makes sense
bigbadbob2003 is offline Find More Posts by bigbadbob2003
Old Dec 11, 2007, 02:50 PM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
Mk2 maiden video
Here's a quick vid from yesterday's test flight. We only had a 10 minute window to film so it's a bit hurried...
MDC F-14 Mk2 test video (3 min 48 sec)
I'm gonna have to try Bigbadbob's autosweep setup now... what a great idea.
Kit info will be announced in a few days when they are ready. First run of 10 kits will be white, if there is enough interest I will do a run a grey also (assuming Birdofplay is up to the task).
Maybz is offline Find More Posts by Maybz
Old Dec 11, 2007, 03:02 PM
fall666 is offline
fall666's Avatar
DAL/FTW
Joined Jul 2006
Maybz, well done.
Looks COLD.
Old Dec 11, 2007, 03:03 PM
mac2286 is online now
Find More Posts by mac2286
USA, IN, Commiskey
Joined Oct 2007
Maybz, that is one great video. Now I've got to have one. It just got moved to the top of the pile. Great Work on a great plane.
mac2286 is online now Find More Posts by mac2286
Old Dec 11, 2007, 03:14 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I'm not usually attracted to park jets, but this one is just too cool - and so acrobatic. It's officially on my "to do" list.
warhead_71 is offline Find More Posts by warhead_71
Old Dec 11, 2007, 04:15 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Maybz,
What motor/prop combo did you select for the Mk2?
I can build one, but that pizza box of parts looked mighty nice. I want my kit in grey, but would take white if its available.
Ken
Old Dec 11, 2007, 04:54 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
I used a 150watt, 1500kv Dualsky motor with an APC 7x5 prop on this build... this is the same power unit that Yardbird recommends for their F-22. Performance seems similar to the LS purple peril motor with same prop as used on the Mk1.
Old Dec 11, 2007, 06:49 PM
stvmike is offline
Find More Posts by stvmike
stvmike's Avatar
manchester,N.H.
Joined Dec 2006
f-14
That is so cool!!!! I would like to be put on the list to purchase a kit from you...
thanks,Mike
stvmike is offline Find More Posts by stvmike
Old Dec 11, 2007, 07:51 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Bigbadbob.. I just finished programming a new heli profile for the Mk2 per your instructions. I deviated slightly from your setup and did this:
ST2= open wings
ST1= auto wings
Norm= swept wings
Another nice side effect of using the Heli flight modes is that there are independent trims for each position now - Nice!
Now I just have to wait patiently for the snow to stop falling....
Old Dec 11, 2007, 07:57 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Gotcha covered dz1sfb !
I'm using a Trakker III from Polks !
and only a Berg 4 ch RX in my F-14. but ...
I get the wings to work on the Rudder channel Ch4 !
I mixed a programmable 3 position switch ( CH5)
With CH4 and Killed the stick input.
A cheapo way around the problem !
I was about to go test/maiden it when I realized that I had NOT
hooked up the Elevons yet !!! What was I thinking ? duh ???
Maybe tomorrow ! wheeew !
You got Snow ! ! !
We HAve SERIOUS Mud Slides !
Check out CNN for Oregon Mudslides !
It closed the only road on the OTHER side of my Valley
so all the traffic is over HERE NOW ! ! !
birdofplay is offline Find More Posts by birdofplay
Old Dec 11, 2007, 08:48 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Maybz/birdofprey - Put me down for a white kit. I prefer white.
Rick
rampman is online now Find More Posts by rampman
Old Dec 12, 2007, 10:01 AM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
flew again last night. i'm seriously thinking of changing the motor. right now it has a UH fc2508 6 in prop.
would an eflite 370 outrunner on 3s 1000 mah 20c work.
with the current set up it.s slow and hard to turn left. both throws are equal.
would ailerons work on a fixed open wing?
tia
smkn951 is offline Find More Posts by smkn951
Old Dec 12, 2007, 10:14 AM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Do you mean FC 28-05? If so then you are way underpowered. The FC 28-12 would be a great choice however... I have one of these in my Yardbird F-22 and it is fantastic. I would upgrade the motor before you add ailerons because you are going to need more power with the fixed open wings. You will probably find that ailerons aren't needed with more power. Also make sure your elevon throws are correct. They should almost touch the vertical fins with full left or right stick input.
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
