Old Nov 08, 2007, 05:31 AM
kakao is offline
Find More Posts by kakao
Fly cheap-gliders arr :)
kakao's Avatar
Bratislava - Europe
Joined May 2007
Help!
Home made RC TX
Hi.. i am searching for some info about RC TX - 2 months ago i have found some interestin buildlog about someone who build his own TX. But i can't find the link.. Does anyone remember?
My goal will be to create custom TX - the main idea is to make it small, but yet robust - something you can put in your bag together with some small model (car/boat/plane .. whatever )
I will be probably using an old ps2 controler as a base and standart hitec tx modules as signal transmitters. Lipos should drive the whole thing..
kakao is offline Find More Posts by kakao
Old Nov 08, 2007, 06:43 AM
Iflyj3 is offline
Find More Posts by Iflyj3
Dan Thompson (MP8K developer)
Iflyj3's Avatar
USA, KY, Paris
Joined Dec 2002
Try these sites http://mstar2k.com
http://groups.yahoo.com/group/mp8k/
Iflyj3 is offline Find More Posts by Iflyj3
Old Nov 08, 2007, 06:52 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
Originally Posted by Iflyj3
That's not it..
The guy was using sticks from some ps controler and the housing was clear plastic...
Old Nov 08, 2007, 09:17 AM
blanchjd is offline
Find More Posts by blanchjd
Snohomish, WA
Joined Jun 2007
Actually, those links are half of what you are looking for. You are probably talking about Village Idiot's custom Microstar build documented here:
http://www.rcgroups.com/forums/showthread.php?t=692649
blanchjd is offline Find More Posts by blanchjd
Old Nov 08, 2007, 09:29 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
In the lost but not forgotten area of my workbench.
You should note that a standard PS2 controller is too small to house the Microstar controller board. I just shaped mine close to the same because it fits in my hands.
If you want something small and extremely durable, I would suggest a standard pizza box style. If you made it out of 1/8 polycarbonate (thicker than mine) it would be nearly indestructable.
Alps makes the sticks that I'm using, and they have a few styles to choose from.
village_idiot is offline Find More Posts by village_idiot
Old Nov 08, 2007, 01:07 PM
radio freak is offline
Find More Posts by radio freak
United States, NJ
Joined Dec 2006
koichi's 4 channel tx also uses a ps2 controller.
radio freak is offline Find More Posts by radio freak
Old Nov 11, 2007, 04:17 PM
andrewm1973 is offline
Find More Posts by andrewm1973
Brisbane
Joined Aug 2006
The Kotchi ones are IR not RF are they not ?
andrewm1973 is offline Find More Posts by andrewm1973
Old Nov 11, 2007, 04:51 PM
chwory is offline
Find More Posts by chwory
Joined Jun 2005
8 ch. computer controled coder & HF modul
chwory is offline Find More Posts by chwory
Old Nov 22, 2007, 05:36 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
Yes that's it :)
That is exactly what i meant!
Old Nov 22, 2007, 06:12 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
Hmm..
What i'm planing to do is to create my own microprocesor board that fit's inside.. Meanwhile i have dificulties to figure out which batereis will fit inside of the tx. I'm planing to use LiPo's as this will be by default a travel TX so i don't have to care about the bateries.
Old Nov 22, 2007, 11:25 AM
Inciting Riots
Joined Dec 2006
You could fit some 3s 500mah packs in the stock PS2 grips and run them as a 2p configuration to get the run time up. If you use surface mounted components, then you might be able to fit everything except the display for the microstar into a standard PS2 controller. Part of the reason the Microstar is so "big" is because he had to make it so that mere mortals could put it together. If you used all surface mounted components I think you should be able to make it much smaller. You can get the programmed MCU from Gordon pretty cheap, or write your own. Recently (the last 2 or 3 months) there was a post from someone that reprogrammed a cheapo Chinese TX to do al lot of different things. This cheapo TX used an Atmel AVR, and he gave the code for his new programming. That would give you a good start on a scratch design using the AVR. Programming tools for AVR are cheap and plentiful, and the free AVR Studio and GCC compiler make it a cheap way to get started.
Old Nov 30, 2007, 06:28 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
Yop
I have already started to code the program for the AVR (mega16 for the start) to generate the PWM pulses that go to the TX module. A/D conversion is working properly now but i have bit dificulties to set the timers to produce the right PWM in 10bit mode. I have not much time but i'm actualy making some progress.. I think i will publish the whole thing under some GPL later. But that mostly depends on how much time i will get for the hobby this winter .
The first thing to do is to make the output of the device valid for the TX-PC interface and try it as RC joystick. As first simple joy with 2 sticks + some buttons, later i will add trims / v-mix, if possible some memories(presets),
The TX should be a simple one - i mostly want it to fly my delta wing and have it as a small model pack in the back of my car. Won't be possible to fly something seriously with such small sticks as they are not so precise. Making it a Hi-Tec TX is not the main deal.
About the surface mounted components - i think i will use them but i don't have to as the PCB will be fairly simple - there will be max 20 components ( without sticks and switches) in this TX. The display is not the highest priority as well but is possible for shure.
Old Nov 30, 2007, 09:32 AM
Inciting Riots
Joined Dec 2006
I bet you can get help on the PWM over at AVR Freaks. I know there is a bunch of code for different RC related things.
Old Dec 01, 2007, 07:34 AM
mem is offline
mem
Find More Posts by mem
mem
mem's Avatar
London, UK
Joined Nov 2005
Here are the settings I have used with the 16 bit timer on the atmega168 for this kind of app. There are lots of other ways of doing what you want. Hope this helps get you going.
TCCR1A = _BV(WGM10) | _BV(WGM11); // to set Timer 1 for phase-correct 10-bit PWM.
TCCR1A |= _BV(COM1A1); //Clear OC1A on compare match when up-counting, sets OC1A on compare match when down-counting.
TCCR1B = _BV(WGM13) | _BV(WGM12) | _BV(CS11); // div 8 clock prescaler (.5us ticks with 16mhz clock
TIMSK1 = _BV(OCIE1A); //Enable output compare interrupt for timer 1
With an 8 mhz clock, set OCR1A to the pulse width in microseconds in the interrupt handler, with a 16mhz clock, multiply the value by two. The TIMER1_COMPA_vect will be called each time the count matures and you will need to load in the values for each successive channel interleaved with a short inter-channel delay. Searching on google for TIMER1_COMPA_vect should bring up examples of how the interrupt is used.
If you use this technique, read up on how to safely access 16 bit register values in interrupt handlers.
I would be interested to see how your project progresses, please let us know how you are getting on.
mem is offline Find More Posts by mem
Old Dec 03, 2007, 03:03 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
Thanx alot, i will try this configuration next time i get to dev .. i will report later. The project will be compiled using CodeVision AVR, i will post source codes later
Home made plane flies!! Jeremy_D Parkflyers 4 Jan 02, 2008 09:00 AM
Discussion home made micro rc's countrycat16 Scratchbuilt Indoor and Micro Models 3 Jan 18, 2007 07:51 PM
Home made oleo legs...... Doc Watson Power Systems 5 Jun 09, 2001 07:37 PM
home made carbon fiber ? mjse Electric Plane Talk 2 May 26, 2001 07:55 AM
home made carbon fiber ? mjse Parkflyers 0 May 25, 2001 03:42 PM
