A123 racing / B&D VPX 1100 mAh CBA Graphs
OK this is thread number ?? on these cells but they sure have sparked a lot of interest as many have been waiting on them for close to a year.
Update: These cells are steel not aluminum and are easy to solder. The polarity is the same as normal cells reversed from the A123 racing 2300 mAh cells. 12-10-07 Official A123 Racing specs. http://www.elektromodely.sk/A123/APR18650M1_2007-05.pdf DeWalt 18V with the 1100 mAh cells http://www.rcgroups.com/forums/showp...92&postcount=1 Added: 12-25-07 Merry Christmas -- Seasons Greetings. Nice photos of pack disassembly here: http://www.rcgroups.com/forums/showp...76&postcount=1 Snip: Quote:
My weights: 2cell pack as purchased 123 gr. / 4.34 oz. 1 cell with 2 1/2" 14 ga. leads and APP connectors 48.6 gr. / 1.71 oz. 3S pack with 6" 14 ga. leads APP connector and PQ balancing leads. 137.7 gr. / 4.86oz. 4S with 6" 14ga. leads ,Deans Ultra and PQ balancing leads 6.4oz. Cells are .715" dia X 2.535 long , not counting tabs. I have a single and a 3 cell which I will be testing. Graphs will be posted as soon as possible. Let the fun / torture begin. First CBA at 6 A / capacity 940 mAh Second graph with 6,9 & 11.9A discharges Next up single cell. Hint : Remove the Label from the pack and it is obvious how to open them. I opened top (contact) end and just pulled cells right out. Official A123 announcement here: http://www.rcuniverse.com/forum/fb.asp?m=6614191 Snip: Quote:
11-26-07 Added 4S A123 100 / Thunder Power PL 3S1320 Graph Single cell discharges of each also on same graph 11-27-07 Time for a little more abuse. 4S charged on balance Pro HD at approx. 8A 10 min. charges and 8A Discharges but only to 11.2 volts. 12-31-07 Another thread where a 4S 1100 pack is receiving addational abuse. http://www.rcgroups.com/forums/showthread.php?t=793209 Charles
A123 1100 mAh single cell Receiver / Servos Flight pac
Single cell graphs and photos of 3S pack.
Added: single cell discharges at 1,2 and 3A. For the benefit of those who have a difficult time reading graphs. Third attachment : Fully charged cells no-load voltages were 3.46 --3.51. This is where a A123 cell ends up after a full charge to 3.6-3.65 volts per cell. 1 amp. load applied and voltage dropped to 3.3 per cell which would be 6.6volts for a 2 cell (receiver / servos) pack. Voltage held between 3.2 and 3.1 per cell 6.4 - 6.2 volts for a 2 cell pack for most of the cells capacity or approx. 850 mAh. As per the note on graph the actual cell voltages were approx. 0.1 v greater at the cells terminals. There was a 0.1 volts drop in the tap leads and associated connectors.This drop should be similiar to what can be expected in an aircraft with normal receiver / servo wiring. Charles
I can post the times howerever a close guess is easy.
6A/1.1(nonimal capacity)=5.45 C . 60 min./5.45=11.00 min. 9A/1.1=8.18C ,60/8.18= 7.33 min. Here is a link I posted long ago on how to read a CBA Graph. http://www.rcgroups.com/forums/showp...89&postcount=2 Actual times for a single cell discharges ,graph not yet posted. @6A 9:43 @9A 6:38 @12A 4:59 Charles |
Tucson, AZ
Joined May 2004
I just picked up a dozen Li-FeP04 1200mah cells from hobbycity.com. They claim to be the same as A123 cells but I don't think so, and here's why. I am using a Thunder Power 1010C charger with version 2.3A firmware, making it "A123" capable. For those cells, it has worked fine and I get a full charge on the cells, no problem - not so with the 1200's...
According to their data sheet, they ship with a 50% charge, and peak charge voltage is 3.9 volts. Right out of the box, I attempted to charge each cell individually, and they all only accepted 45-120mah? "Hmmm, maybe they came fully charged", I thought to myself..."let's see how much I can take out of them". I set the discharge cutoff to 2.5 volts and a 1.2 amp discharge. Each cell only gave me 550-650mah before reaching 2.5 volts??? So here's the question - does any hobby-related company make a digital readout charger capable of charging any lithium-iron phosphate battery, having and adjustable peak voltage detection? In looking around, I have found li-fe batteries rated at anywhere from 3.0 to 3.3 volts, nominal, and 3.6 to 4.0 volts peaked, so they all obviously have different charging requirements. I really don't think I just got a set of bunk cells, I just need a charger that will fully charge them! Another interesting observation with these cells is that the positive and negative side of the battery is the same as a Ni-cd, whereas the A123's are reversed... Here is a link to where I found the batteries: http://www.hobbycity.com/hobbycity/s...8&ParentCat=85 And here is my only luck in finding higher v/cell chargers so far: http://www.batteryspace.com/index.as...OD&ProdID=3286 |
Bodywerks there are several Threads on the copy cat cells. One such is here
http://www.rcgroups.com/forums/showthread.php?t=767379 It would be nice if this Thread stayed on actual A123 Racing cells. Charles |
| Thread Tools | |
| CBA Irate 1100 mAh @6A | everydayflyer | Batteries and Chargers | 0 | Feb 14, 2005 09:09 PM |
| 1100 mAh NiMH Sanyo Battery Packs FOR SALE | SoulShell | Aircraft - Electric - Airplanes (FS/W) | 0 | Jul 12, 2002 01:57 PM |
| 1100 MAH NICD for Sorpio Spitfire | Blair | Electric Plane Talk | 0 | Jan 30, 2002 09:39 AM |
| new 1100 Mah NICD | gouang | High Performance | 14 | Jan 13, 2002 11:41 PM |
| JR XP8103 heli radio(DT) with Ch36 PCM module and Ch 36 rx crystal, 1100 mah battery | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 6 | Dec 01, 2001 11:28 PM |
