Old Nov 06, 2007, 10:03 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Noob Lipo Charging questions!
I have a cheap lipo charger like this: https://www.unitedhobbies.com/UNITED...idProduct=2055 , a 2S 850 mAh lipo and a 3S 860 mAh lipo.
I usually charge the batteries at .5 amp and it seems to take forever. The last time I charged the 3S 860 it took about 3 hours. Does that seem to be reasonable? I hear about charging at the field, but 3 hours is a long time between flights unless you had several chargers going at the same time.
I charge at the lowest rate as I have read that the battery will last longer if you charge it at a low rate. I did by mistake charge it at 1 amp and it was much quicker, but will that rate damage the battery?
Sorry for the beginner questions.
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Nov 06, 2007, 10:22 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Ray, it won't damage the pack but it can shorten it's life some. If you are new at this your packs will have a higher chance of termination due to crashing before you surpass 100+ cycles.
The math on the time is correct. I would expect a bit under 3 hours at .5 but the charger may be off some and actually be charging at .4, not .5.
Rick
rampman is offline Find More Posts by rampman
Old Nov 08, 2007, 10:40 AM
Out the Window
Joined Jul 2004
Rick, thanks for the quick answer!
Discussion Noob LiPo lifetime questions twillis Batteries and Chargers 6 May 13, 2007 04:24 PM
Help! Basic BCX LiPo Charging Questions Rodono Coaxial Helicopters 2 Jan 31, 2006 03:55 PM
Couple Of Lipo Charging Questions flyingflipper Batteries and Chargers 8 Jun 08, 2005 06:11 PM
Lipo Charging-Questions fuzzyhead Batteries and Chargers 4 Feb 08, 2005 08:38 PM
Lipo charging questions! Help! KC10Chief Batteries and Chargers 4 Jan 02, 2004 07:40 AM
