Old Nov 06, 2007, 06:05 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
New Product
Aluminum Alfa Fan Rotor Plug for 3 and 5 blade Alfa Fans
Good news for all you Alfa EDF users. I have a large batch of precision CNC machined aluminum plugs for the Alfa 3 and 5 blade rotors. The bore is reamed for very tight tolerance which gives a no slop slip fit on 3mm shafts. This adapter is meant to secured by a small drop of green Loctite (or equivalent). A press fit was not used do the possibility of bending the motor shaft during installation. To remove the loctited plug off the shaft, all you need to do is thread in a longer 3mm screw while holding the shaft to keep it from rotating. The plug will come right off.
http://donsrc.com/cart/index.php?act...d&productId=51
TIP: Before installing, rinse the shaft end and plug off with some alcohol to remove any oils or grease. Place a drop of green loctite on the shaft end, and then push the plug on. Wipe away any excess Loctite, then place under a desktop lamp to warm it up a little, it will help cure the Loctite much faster.
Includes 3mm fan screw.
Don
The Don is offline Find More Posts by The Don
Old Nov 06, 2007, 10:31 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Nice. I have a friend also with the alfa fan and we will probably order a couple. I'll need to speak to him about it, so give me a couple days.
kahloq is offline Find More Posts by kahloq
Old Nov 06, 2007, 10:34 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
No problem. I have 500 of them
Old Nov 07, 2007, 05:36 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
The best way ?
I would clean with Alcohol and then take a tooth pick, put a drop of Locktight on it. Then slide the tooth pick into the rotor hole, ONLY. Wipe any excess Locktite off the hub hole area. This will coat the shaft of the motor very well. There is no possibility that the Locktite can be scrapped up on the shaft as it slides into the rotor hole. If loctite does build up on the shaft, the danger of Locktite going into the front bearing is very high.
Always put any glues into the holes, never on the shaft.
I know this first hand.
cyclops2 is offline Find More Posts by cyclops2
Old Nov 08, 2007, 12:43 AM
Bill Covert is offline
Find More Posts by Bill Covert
Bill Covert's Avatar
Grove City, PA
Joined Sep 2007
One thing I've found that helps increse grip with gears (or hubs in this case) is to file a few marks on the shaft, where the Loctite and gear will be assembled together. Don't marr the heck out of the shaft as its not necessary, but just file a few marks with the edge of a file.
Bill Covert is offline Find More Posts by Bill Covert
Found Alfa fan rotor plug for 2mm motor gliders Aircraft - Electric - Jets (FS/W) 2 Oct 13, 2007 09:13 PM
Motor system for 3.5-4lbs plane. Napolean B. Power Systems 8 Aug 10, 2004 06:06 PM
Wanted: Brushless Direct Drive motor and controller for 3-5 lb plane. War Bird Radio Aircraft - Electric - Airplanes (FS/W) 1 Mar 08, 2004 09:58 PM
FS: GWS Spinners for 3- and 4-Blade props. GoEFlight Aircraft - Electric - Airplanes (FS/W) 0 Nov 19, 2002 09:48 PM
FS: GWS Spinners for 3- and 4-Blade Props GoEFlight Vendor Talk 0 Nov 19, 2002 09:46 PM
