Dec 14, 2002, 02:30 AM
Mostly in Norman, OK
Joined May 2002
I'll move over a thread I started earlier ... consolidated everything.
For the Pinnacle, variable charge rate from 200mA to 5A, you can select Charge, Discharge, Dischage-then-charge, or direct trickle routines. Trickle is set at 150mA though.
There's a 3 position slider switch that lets you display V, I or mAH on the LCD panel, during it will flash between the curent reading and the cell count. Cell count is done automatically, and so far I haven't had a problem. Dischage is done to .9V per cell and from what I've seen looks to be a 4ohm load. There's also a fan that's on all the time - can be noisy in a quite room. I seems better at charging packs that I get false peaking on the GWS charger.
Couple of unanswered Q's:
* No mention of charging time-out
* it's 28V at the output - you should be able to charge more than 14 cell packs?
Also available is the Apex, a basic peak charger with 3 charge rates, 400, 750, 1500mAh for 6 or 7 cell pack. Has a nice super-brite blue LED and loud beeper to announce end of charge. Kinda expensive though a $34+
