Old Nov 05, 2007, 04:26 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Question
Adding Servo Wire Length
I see servo wire for sale at the LHS and online sites but what is the best way and what is max lenght before running into interference issues. I realize each install is different and a number of factors come into play... but I'm planning on Bipe with ailerons rather short in the top wings only out at the tips.. I would like to have the servos out in the tips for a direct connection. I'm trying to stay away from using extensions with plugs at both ends as it seems like more points of failure.
Thermalin is offline Find More Posts by Thermalin
Old Nov 05, 2007, 05:53 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Go for it. Lots of modelers (me included) prefer soldered in extensions. Maximum length? Probably no rule a person can quote - do it and check. No idea what size servos you are using or how long the run, but some of the available servo wire is a bit wimpy - I prefer 22 AWG.
Bill
ebill3 is offline Find More Posts by ebill3
Old Nov 05, 2007, 07:30 PM
chrisf testpilot is offline
Find More Posts by chrisf testpilot
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
Use twisted wire and solder them and it shouldnt be an issue. If it is it will be due to ignition noise or something else.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Nov 05, 2007, 10:59 PM
Thermalin's Avatar
Joined Jan 2005
So... would I clip the wire mid length between servo and plug.. insert my extra "run" in the middle? any special type solder... is some better for electrical work, etc...
This is for the proctor nieuport 17.. approx 53" span but woulid need to run the servos off a Y harness up to the upper wing. Was going with hitec HS-81's when the time comes.. plenty of power and small to preserve the scale appearance.
Test Pilot... the thicker the wire the better i presume? I assume dont go thicker than what is already there?
Twisted is better than straight?
thanks.. Mike
Old Nov 06, 2007, 12:11 AM
ebill3 is offline
ebill3's Avatar
Use rosin core electrical solder - 60/40 (60% tin/40% lead); 63/37 is better. Radio Shack has both.
For that short of a span and those servos, 24 AWG is fine. You can always use larger wire (smaller AWG number), but ought not use smaller wire.
Twisting helps prevent common mode interference but most commonly available servo wire is flat ribbon and doesn't lend itself to easy twisting. For a 26" run, I'd use the flat ribbon cable.
Bill
Old Nov 06, 2007, 10:05 AM
Thermalin's Avatar
Joined Jan 2005
Bill
Great... thanks.
Old Nov 06, 2007, 12:02 PM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
I just had an extension come loose. Might have been because the plane fell 15' out of a tree nose down onto pavement, can't be sure. Soldering in the wire is a good idea, maybe I'll do it for this plane.
Unterhausen is offline Find More Posts by Unterhausen
Old Nov 06, 2007, 12:37 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Yes, soldered in extensions are far superior to plug in extensions. Yes, use as large or larger wire than the original servo wireing. It is doubtful that twisting the wires will help in any way other than to make the run a little neater phyically. Twisting is only needed when in high AC field and common mode signals would get you in trouble, things that do not exist in your model. Your biggest problem will be any losses in the power leads if you have high current (digital) servos and even then it is doubtful that that will be a problem.
Rodney is offline Find More Posts by Rodney
Old Nov 06, 2007, 03:44 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Thermalin
So... would I clip the wire mid length between servo and plug.. insert my extra "run" in the middle? any special type solder... is some better for electrical work, etc... This is for the proctor nieuport 17.. approx 53" span but woulid need to run the servos off a Y harness up to the upper wing. Was going with hitec HS-81's when the time comes.. plenty of power and small to preserve the scale appearance. Test Pilot... the thicker the wire the better i presume? I assume dont go thicker than what is already there?
Twisted is better than straight? thanks.. Mike
1. Available from your LHS 3 Colour Servo Lead Wire 50FT (15.24M) . Recommend attaching new lead direct to servo board and adding the original lead to the end of the extension. Only one join and original plug is retained.
2. The Nieuport 17 is to big and heavy for HS-81 servos. Whilst powerfull, they are designed for use in easy flying gliders and many EP models, the gears are to thin and will quickly strip if used for ailerons in that Nieuport 17. HS-81MG specifications = 1/2A or throtttle when used with GP models.
Refer to 101 - Servo FAQ & picking the right servo for the job As a minimum, suggest use of HS-85MG+ specifications. or HS-125MG specifications, preferably HS-225 specifications.
3. Extension leads were always twisted in the days of AM systems but not required for typical FM instalations except where digital servos are being used and which also use heavy duty leads. A flat lead may be twisted if using either AM RC system or Digital servos by clamping one end in a vise and grip other end in a drill chuck. For such short leads, should not be necessary, but a Ferrite Filter / RF Choke could be included close to RX. examples:
Ferrite filter (RF Choke)
Snap Shut Ferrite Chokes
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Nov 06, 2007, 08:52 PM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
If I can find some the right length, I use plug-in extensions in a hybrid role:
I remove the pins and sockets from the plastic housings on the ends of the wires to be joined, slip some small heat-shrink tubing on the wires, plug them together, sweat some solder into the joints, and then insulate each joint with the heat shrink.
I don't think there's any real advantage to doing it this way versus just splicing the wires together except it's a lot faster and you end up with a nice joint.
Pete
PGR is online now Find More Posts by PGR
Old Dec 02, 2007, 03:59 PM
Drachenstein is offline
Find More Posts by Drachenstein
Drachenstein's Avatar
Madetswil, Switzerland
Joined Jul 2006
How to insulate soldered connections for wire extentions?
Hi there
Just a stupid question: after soldering the three wires of a servo extention, how do you insulate it?
Do you use three separate heat shrink tubes, one for each wire? When I tried this the plastic insulation of the servo wire wanted to melt before the tubes really shrinked
Are there maybe any better techniques for insulating the soldered parts?
Thanks for your hints - Wolfgang
Drachenstein is offline Find More Posts by Drachenstein
Old Dec 02, 2007, 04:07 PM
ebill3 is offline
ebill3's Avatar
Yes, three separate shrink tubes. I use regular heat shrink and hot air and the insulation does not melt.
Bill
Discussion Servo wire length? dustn Slope 12 Sep 13, 2006 01:41 PM
Maximum servo wire length. oilman Radios 1 Nov 26, 2004 08:41 AM
Hitec 555 - Anyone have trouble cutting antenna wire length? Sal C Power Systems 19 Sep 16, 2001 03:30 PM
Long run servo wire torroidal etc. Where to find. Gman2 Power Systems 3 Sep 07, 2001 04:05 PM
