Old Nov 10, 2007, 01:57 PM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Originally Posted by MarkJayne
And here's the power setup. Feigao B40-10S brushless with a Carbon Graupner 13x7 folder. The carbon's a little much, but my LHS didn't have any other in that size. It'll add a little bling to her I suppose. This motor has stacks of power on a 3s, so I may end up using a 2s.
Mark
Mark .... how is that motor mounted ? ......
hobie14 is offline Find More Posts by hobie14
Old Nov 10, 2007, 02:18 PM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
I'll make a balsa platform first, then it'll be glued on using Hysol, I'll strap a cable tie around for piece of mind. I've done this with my Twinjet, seems to work well.
Mark
MarkJayne is offline Find More Posts by MarkJayne
Old Nov 10, 2007, 03:35 PM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Mark
Do you have a web link for that adhesive Mark? .....
Old Nov 10, 2007, 03:49 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Here's a link http://www.ellsworth.com/display/pro...35&Tab=Vendors
Its the Hysol 9462.
I like using this on motors because it doesn't get affected by heat, and it holds extremely well.
Mark
Old Nov 10, 2007, 04:26 PM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Its the Hysol 9462.
Mark
Many thanks .... will Bookmark ....
Old Nov 10, 2007, 04:37 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Ditto. Thanks Mark!
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Nov 10, 2007, 07:00 PM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Oooooo! I lost my breath when I saw the price. Must be some really good glue! Anyway, Mark, your plane is looking wonderful. I can't wait for the flying viedo.
quailbird is offline Find More Posts by quailbird
Old Nov 10, 2007, 08:06 PM
Murocflyer's Avatar
Joined Nov 2005
Glad to see it wan't just me. Actually I did a little more digging and it costs just under $10 for the two-part kit.
Frank
Old Nov 11, 2007, 01:30 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Motor and ESC now in place. I've also placed some 2mm carbon rods along the elevator and ailerons. This has worked well and has stopped any flex that occurred further down from the control horn.
I've used my Jeti 70 ESC. The Feigao motor has stacks of power and pulls around 45Amps on a 3s 3700mAh.
Mark
Old Nov 11, 2007, 01:33 PM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Looking great! Keep up the good work
13x7 and 45A .... this thing will go like a bat outta the hot place!
David
Hogster is offline Find More Posts by Hogster
Old Nov 12, 2007, 12:00 PM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Mark is that a simple Velcro mount for the ESC? ....
If so what do you glue the Velcro pieces with.... Epoxy?
I ordered the 2300Kv Brushless and want to mount the ESC the same way ....
Old Nov 12, 2007, 01:49 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
I just cut a flat platform out, then stick some velcro down, and put a couple of spots of CA around the edge, this just stops it from lifting if you remove the ESC.
Mark
Old Nov 12, 2007, 02:06 PM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Mark
O-Key-Doke .... will do that too ....
Old Nov 13, 2007, 12:47 PM
Guntars is offline
Find More Posts by Guntars
Latvia
Joined Oct 2006
What is the increase in wing aria?
Guntars is offline Find More Posts by Guntars
Old Nov 13, 2007, 01:10 PM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Originally Posted by Guntars
What is the increase in wing area?
About this much by the look of it .....
Discussion My new F3P work-in-progress Doug Cronkhite Indoor Pattern/F3P 13 Jan 19, 2008 09:16 PM
Building my new AP ship the “Troll” patrickegan Aerial Photography 18 Nov 21, 2004 09:00 PM
My new AP ship candidate. KeithLuneau Aerial Photography 14 Oct 23, 2004 09:54 PM
My new GWS Spitfire - work in progress mattski GWS (Grand Wing Servo) 2 Sep 07, 2003 05:50 PM
