Old Jan 17, 2012, 06:23 PM
Corsir Crasher
Mopower71's Avatar
United States, NY, Poughkeepsie
Joined Oct 2011
Originally Posted by Dreamcatcher View Post
+1 !
I use hot glue to fasten my servos
On mine, i use foam friendly CA glue to stick the hinge tape when it "go away" like that (or surgical clear tape like "Blenderm")
I used the glue that came with my Airfield plane. It worked fine.
Mopower71 is offline Find More Posts by Mopower71
Old Jan 17, 2012, 07:51 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Originally Posted by MERLIN V16 View Post
I forget where the servos go but remember they are not molded in there . They have to get in there somehow. There is the little hatch on the side to gain access no?
No hatch on the side of mine.
Old Jan 17, 2012, 07:54 PM
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
???????????????? Boy something has changed. OK get the razor out!
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Jan 17, 2012, 08:50 PM
nom
United States, ID, Boise
Joined Mar 2011
I also have a small plastic hatch on the left side of the fuse for the elevator servo. The rudder servo should be right underneath the plastic vertical stab that you screwed on. At least that's how it is on my bird and I bought my bird last June.
nom is offline Find More Posts by nom
Old Jan 17, 2012, 08:51 PM
Stubacca
stughagen78's Avatar
Garland, TX
Joined Aug 2009
There should be a hatch
OK, so there should be a plastic cover glued over the elevator servo, you should be able to find this cover/hatch by following the push rod attached to the elevator back to the fuse the hatch is right there where the push rod go's into the fuse. Mine was painted the same color as fuse and blended in very well. Let me know if you don't find it, I'd love to see a picture of that area.
Stu
stughagen78 is offline Find More Posts by stughagen78
Old Jan 18, 2012, 11:27 AM
me, right now.
hooligan russ's Avatar
United States, NC, Clayton
Joined Nov 2009
Stu
+1, or just take the vertical stabilizer off and its right there.
hooligan russ is offline Find More Posts by hooligan russ
Old Jan 18, 2012, 03:11 PM
MERLIN V16's Avatar
Joined Jan 2005
MOPOWER
Are you sure you got the Art_Tech and not another Corsair from Hobby King?
Old Jan 18, 2012, 08:05 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
The hatch is there, I didn't see it before.
That probably would have made getting the rudder servo wire through the fuselage easier.
Here's a picture of the access and a picture of the new pilot.
Old Jan 18, 2012, 08:24 PM
MERLIN V16's Avatar
Joined Jan 2005
OK
Just be careful removing it and there is your servo! Cute Pilot!
Old Jan 20, 2012, 01:18 AM
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
DARNIT Mopower you TOTALLY STOLE my idea of Marvin Martian as pilot, been looking for one that size....I therefore lay personal claim to Chester Cheetah then! But he'll go in the Spitfire...
Brent Slensker is offline Find More Posts by Brent Slensker
Old Jan 20, 2012, 07:32 AM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
I found marvin in the kids toys. He was on top of a pen. I haven't seen a chester cheeta anywhere
Old Jan 20, 2012, 07:36 AM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
I had to mount marvin on a block of wood to get him high enough. The cg falls in right where I was told it should be. Guess it was a bit nose heavy. That empty cockpit was bugging me.
Old Jan 20, 2012, 07:48 AM
nom
Joined Mar 2011
I agree an empty cockpit looks wrong, nice touch with Marvin the Martian!
Old Jan 20, 2012, 09:39 AM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Now if the weather would cooperate I could go test it. Been very windy, cold, and now snow. Might have to buy a new plane to put together while I wait for spring. Any sugestions on a nice warbird? I have my eye on the dynam t 28 trojan. Would like to add flaps to it if I get it.
Old Jan 20, 2012, 07:08 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Another shot of Marvin piloting his Corsair.
You can see he is manning the stick.
FS: ALFA F4-U Corsair w/HS-55 servos & props dawnron1 Aircraft - Electric - Airplanes (FS/W) 6 Jun 04, 2004 08:26 AM
FS: NIB Flying Styro F4-U Corsair - $30 Hooters Driver Aircraft - Electric - Airplanes (FS/W) 3 Apr 25, 2004 12:27 PM
Hangar 9 F4-U Corsair ARF? GordonTarling Scale Electric Planes 30 Jan 17, 2004 11:08 AM
FS- New GWS F4-U corsair and ESC Etonic Aircraft - Electric - Airplanes (FS/W) 1 Dec 30, 2003 10:23 AM
New F4-u corsair video on Bungy... Bernard Parkflyers 17 Jan 01, 2003 04:31 PM
