Old Dec 15, 2013, 09:08 PM
Mopower71 is offline
Find More Posts by Mopower71
Corsir Crasher
Mopower71's Avatar
United States, NY, Poughkeepsie
Joined Oct 2011
Thanks.
so you just glued the rudder straight and don't use it,even to ground steer?
i ended up using tape to fix the rudder hinge as it was coming apart
Mopower71 is offline Find More Posts by Mopower71
Old Dec 15, 2013, 10:04 PM
Grouser is offline
Find More Posts by Grouser
Grouser's Avatar
United States, TN, Memphis
Joined Dec 2012
I never used the landing gear, so the tail wheel was the least of my concerns.
Check post #4167.
Grouser is offline Find More Posts by Grouser
Old Dec 16, 2013, 12:44 PM
Grouser is offline
Grouser's Avatar
Joined Dec 2012
Description:
Yo, Mo?
I did manage to fetch it out. It appears serviceable. PM me your address.
Grouser
Old Dec 16, 2013, 01:08 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
That's the piece . thanks for fetching it out. i appreciate this very much.
Norm
Old Jan 04, 2014, 08:00 PM
TwostrokeTimmy is offline
Find More Posts by TwostrokeTimmy
United States, WI, Baldwin
Joined Jan 2013
HK Corsair Tail Wheel Prob
Hey guy's, Anyone ever find a solution to the tail wheel misalignment issue on this bird? After finally fitting the rudder wire through the tiny grommet, the tail wheel is not even close to being lined up with the rudder. I'm stumped!! Please help!
TwostrokeTimmy is offline Find More Posts by TwostrokeTimmy
Old Jan 05, 2014, 04:55 PM
Grouser is offline
Grouser's Avatar
Joined Dec 2012
Timmy
I never installed the main landing gear, and actually tore off the tail wheel!
Check back through the photos. I seem to think you're not the only one with this problem.
Old Jan 05, 2014, 05:00 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
I'm confused.
If you check the rudder servo for center, BEFORE installing the rudder, you will be very close. You may need to bend the rudder wire a little to make up any diffs, but it won't be much.
With tail wheel and rudder surface eyeball-lined-up, only thing left that you might need is a touch of rudder trim.
PikeStaff is online now Find More Posts by PikeStaff
Old Jan 09, 2014, 04:51 AM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
NIB kit UK, 50. Need to sell it .
Matt
Matt Halton is offline Find More Posts by Matt Halton
Old Jun 03, 2014, 01:47 PM
Spoonman606 is offline
Find More Posts by Spoonman606
Spoon
Spoonman606's Avatar
United States, KY, Louisville
Joined Jun 2014
New ART-Tech/New to the forum
I recently snagged up one of these birds since everyone raves about how much fun they are to fly, AND because they are going away quickly. As I am a long time static modeler I will be doing a repaint/refit and installing some carbon fiber reinforcing. Will post pics as soon as I get it from the Fed-Ex truck.
I've read through 95% of the forum here and picked up a few great tips. I will be adding an Orange RS3X rx, and maybe a 25a speed controller. The stock SC seems to work just fine, and I am waiting to get exact measurements of the battery bay before I do too much cutting/battery planing.
Nice to post and not lurk for a change!
Spoonman606 is offline Find More Posts by Spoonman606
Old Jun 03, 2014, 02:03 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
Welcome, Spoons! :D
Congrats on your addition. It really is a fabulous little plane, and will look even better after you're done putting your skills to it. Flying is where it is just the best, tho; it flies so willingly and easily that I'm sometimes a little surprised how much we all love to do mods to it. I'm certainly guilty of that, and the plane continues to fly superbly in spite of it.
Not the best choice on a windy (+6 mph) day, but it'll do it. In smooth still air, low passes will make the hair on your neck stand right up. This is a great airplane.
Old Jun 03, 2014, 03:11 PM
Grouser is offline
Grouser's Avatar
Joined Dec 2012
Gyro Orange
Spoonman,
I too used the RS3X. The Orange instructions say to keep it at the center of gravity with one of the antenna pointing straight ahead. By following these instructions, that meant that the antenna was almost touching the ESC. I had two brown outs resulting in trips through the corn field to fetch the little bird out. I gave up the RS3X for a regular Rx which could be placed in a better location. Since then no trouble. It is carrying more glue now though................
The ArtTech is light and loves to fly that way. ANY weight you add will detract from the fun.
Grouser
Old Jun 03, 2014, 03:12 PM
Spoon
Joined Jun 2014
Thats what I have gathered from both here and a few other sources. Hopefully the carbon fiber reinforcement will give it a tad bit more weight, but not too much so as she can't perform what I want her to perform (scale warbird flight, not aerobatics).
I really think the only upgrade I will make is possibly the speed controller, and of course the paint. I am a stickler for authenticity, or at least plausibility, thus the Navy/Marine combo has to go! I'm thinking of doing a Skyboss replica. I have seen a metric ton of Lucybelle's, and Kepford's, and solid blue Korean era birds, but I have not seen anyone (at least on the Art-Tech) do the blue/white Checkered Skyboss. I may fail miserably, but thats my plan.
Old Jun 03, 2014, 03:44 PM
Spoon
Joined Jun 2014
Thank you grouser for the info, wish I knew that prior to buying the RS3X.
However I remember a post in this thread that showed moving the ESC up into the engine bay for better cooling. That may be a possibility since it would put a space/foam between the ESC and the RX. Plus, I intend to stay with the 1300 (or 1500mah at max) battery, thus I should be ok with the weight distribution which would factor in the added weight of the little carbon fiber rods. for the tail/rudder etc..
Old Sep 29, 2014, 12:18 AM
VC10 is offline
Find More Posts by VC10
Excessive Airframe Hours
VC10's Avatar
Australia, QLD, Margate
Joined Jul 2012
Hi All,
My HK Corsair arrived to day so it's straight in to the shed when I get home. Any tips for set up as there doesn't seem to be any info included in the box? I've had a wander around this thread but I'm still in the dark over where the COG should be. I'll be flying with a 1300 bat.
VC10 is offline Find More Posts by VC10
Old Sep 29, 2014, 08:18 AM
nom is online now
nom
Find More Posts by nom
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
I balance mine near the servo wires in the wings. The mods I recommend are making a cut out from the top of the battery hatch to be able to change batteries from the top and reinforcing the vertical stabilizer. The battery hatch on the bottom is a pain and the vertical stab is really flimsy. This is a really nice little flier, not too fast but extremely nimble but the foam is brittle and it will be thrown around on windy days because it is so light.
nom is online now Find More Posts by nom
FS: ALFA F4-U Corsair w/HS-55 servos & props dawnron1 Aircraft - Electric - Airplanes (FS/W) 6 Jun 04, 2004 08:26 AM
FS: NIB Flying Styro F4-U Corsair - $30 Hooters Driver Aircraft - Electric - Airplanes (FS/W) 3 Apr 25, 2004 12:27 PM
Hangar 9 F4-U Corsair ARF? GordonTarling Scale Kit/Scratch Built 30 Jan 17, 2004 11:08 AM
FS- New GWS F4-U corsair and ESC Etonic Aircraft - Electric - Airplanes (FS/W) 1 Dec 30, 2003 10:23 AM
New F4-u corsair video on Bungy... Bernard Parkflyers 17 Jan 01, 2003 04:31 PM
