Old Aug 23, 2011, 03:38 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I have the Dave Rees plans for the 57" span size. Tried to a fit GWS LPS gear drive in and it won't fit. That was a few years back, I would think a modern 10 gram outrunner would fit in there just fine. Humm, might be time to revisit that one. 6 motors and esc's might be a bit cost prohibitive because my current project list will require the use 8 of the little buggers.
Glenn
glewis is offline Find More Posts by glewis
Old Aug 29, 2011, 02:51 PM
byrocat's Avatar
Aurora, Ontario, Canada
Joined Mar 2002
Glenn
Glen, how about dropping back a bit on the technology front and go with brushed motors? One of the maestros in the TEMAC/EMFSO (Toronto Electric Model Aircraft Club/ Electric Model Flyers of Southern Ontario) likes to use brushed motors on multi-engined projects. One of two ESCs, one or two batteries, more fiddly on setup and configuration, but a lot cheaper.
byrocat is offline Find More Posts by byrocat
Old Aug 29, 2011, 03:47 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I agree, brushed motors is the way to go and is where I started. Used eight N20's on my Hercules with a single esc and it works great.
I need to spin a 6" prop and figured the LPS would be the way to go.
There just isn't enough room in the wing for the gearbox even with a long shaft extension. Was going to enlarge the plan to fit the gearboxes and that's where the project died.
Glenn
Old Sep 01, 2011, 05:15 AM
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
BTW, John's plane is covered with brown paper and a mix of 50/50 water and white (Elmers) glue. It was painted using standard acrylic paints. He also mentioned that it flies very well sort of like a big trainer and now it needs a bit of touching up from all the flights for the brown paper is starting to look a bit ragged now.
Actually, it's not looking too bad at all for a 15 year model!
It's now on it's 3rd set of batteries (now Lipo's of course) but it still runs the original speed 400 brushed motors with MFA gearboxes. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Oct 07, 2011, 12:45 AM
Castle Rock, Washington
Joined Jul 2002
Flew Mine Today
It is from John's plans, 110 inches, 14 lb 12 oz ready to fly. I put 4 flights on it today and it flies great!
cobra72 is offline Find More Posts by cobra72
Old Oct 07, 2011, 11:43 AM
Joined Jul 2002
B-36 Third flight video
Here is a link to video of the third flight.
B-36 Model third test flight (3 min 4 sec)
Old Oct 08, 2011, 04:30 PM
byrocat's Avatar
Joined Mar 2002
Cobra72, can you post some particulars about the power system that you're using?
I don't think that it was flying at a scale speed, considering that most of the film that I've seen has it more of a lumbering behemoth while yours looked to be doing a lot higher speed. Have you tried throttling back or at what throttle position were you flying at once you got off of the ground?
BTW, I found John Considine's design on the Traplet website: http://shop.traplet.com/product.aspx?c=997
Considering what British Post charge for overseas parcels ostage, it might be easier to coordinate with friends/family in the UK to receive the package and hold it for another friend/family member to pick up. LEarned this lesson with a kit too big for the suitcase -- cost almost as much to mail it home than the buy it in the first place. (Read: And I thought that CVanada Post was pricey!!!!)
Old Oct 08, 2011, 10:04 PM
Joined Jul 2002
Speed
I will get the details about the power system after tomorrows flying session. It takes off about half throttle and I pulled the power back right away. I am getting 250 watts per motor at full throttle. I agree the video looks fast, more so than when you see it in person.
Alan
Old Oct 08, 2011, 10:56 PM
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
Congratulations Alan on a job well done!
It's a bit of a thrill seeing someone else building something from my plans .
I hope yours gets to celebrate it's 15th birthday as well!
Surprisingly mine has proved to be the most reliable & maintenance free model I have ever built. The only repairs I have done with all it's flying has been to tighten a motor pinion, replace a chipped prop & repair a broken noseleg steering arm. - John.
Old Oct 10, 2011, 01:04 PM
Joined Jul 2002
Power System
I am using HP Motors 28/14/06 from Hobby People, Balsa Products BP 45A Esc's with no BEC in them and 8 x 6 APC Thin Electric props. I have the ESC's in groups of two powered by XPS 4000 Mah 40C 11.1 volt Lipoly's. At full throttle I have 250 watts per motor. I have the two out board motors set up so I can have differential thrust tied into the rudder if I turn the mix on, but I have not used it yet.
John, Thank You! It is a great design and flies so smooth, no bad habits that I have found. I hope mine lasts just like yours has. I am planning on putting it away for the winter while I add details.
Alan
Old Oct 11, 2011, 02:55 AM
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
Alan, the only bad habit I've noticed with mine is it will drop a wing if you try to turn too tight at very low speeds, there's not a lot of wing chord right out at the tip.
Keep it wide & smooth like the full size & you will never know.
Happy flying! - John.
Old Oct 11, 2011, 09:14 PM
Joined Jul 2002
Thanks for the advice John, I will remember that! I did add washout in tip sections, maybe next time get up high and see what it stalls like.
Alan
Gripen 3view with cross-sections? stegla Scale Electric Planes 4 Jul 11, 2008 12:29 PM
Discussion Source for F-18 Super Hornet 3-view drawing & cross sections? arp67 Pusher Prop Jet Models 1 Jul 19, 2007 07:15 PM
Discussion F-18f Schematics with Cross Sections Needed Pyramesh Pusher Prop Jet Models 3 Mar 22, 2007 06:30 AM
Yippee! I need plans/3 views with cross sections for P-51D Mustang Daniel11 Scale Fuel Planes 3 Sep 01, 2004 04:49 PM
im looking for some good f-16c cross sections... i-fly Power Systems 1 Oct 21, 2001 02:54 PM
