Old Nov 03, 2007, 09:43 AM
magee8578 is offline
Find More Posts by magee8578
United States, CO, Evergreen
Joined Jul 2007
Question
Right hand vs Left hand for DLG lauch?
I am justing starting out in DLG. I am right handed. Should I train myself to launch with the left hand?
Are there any good websites teaching dlg launch technique?
magee8578 is offline Find More Posts by magee8578
Old Nov 03, 2007, 10:26 AM
Jeff Winder is offline
Find More Posts by Jeff Winder
aka Mr.Side-Winder
Jeff Winder's Avatar
United States, OH, Cincinnati
Joined Jun 2007
Typical DHL launch setup
If your 'right' handed, you will want to throw with your right hand, and hold the TX in your left during launch.
Most people setup a launch preset,(usually a tad of up elevator), on the TX that is triggered on a momentary switch accessible with the hand that is holding the TX during launch.
After launch, you will have plenty of time to get your launch hand back on the stick to arc the plane over at the apex of the throw.
Hope this helps,
Jeff
Jeff Winder is offline Find More Posts by Jeff Winder
Old Nov 03, 2007, 12:43 PM
got2soar is offline
Find More Posts by got2soar
Bruce Davidson
got2soar's Avatar
Louisville, KY
Joined Jun 2005
There are advantages to launching and catching left handed. As you make your approach to catch you can fly the plane right into your hand. On launch you can fly the plane immediatly and this will help you put the plane exactly where you want it more efficiently.
Of curse this does not help if your launch suffers because you are trying things wrong handed. I have tried launching wrong handed and it just felt (and looked) bad.
Bruce Davidson
got2soar is offline Find More Posts by got2soar
Old Nov 03, 2007, 01:02 PM
Richard S is offline
Find More Posts by Richard S
Stream Team Models - Pilot
Richard S's Avatar
Milton Keynes, UK
Joined Oct 2005
If you have a look on youtube, you will find plenty of examples of launch techniques.
Everyone has their own take on whats good and whats not.... the only thing everyone agree's on is a straight arm and not trying to "flick" your wrist at launch.
Be aware of tip-strikes too.
If you are right handed, its almost certain that you will launch with your right hand.
I agree with Bruce about being able to control you model when catching/launching... I solve the problem by flying mode1, and mixing my rudder stick to control the ailerons when landing.
Richard S is offline Find More Posts by Richard S
Old Nov 03, 2007, 01:56 PM
ydevriendt is offline
Find More Posts by ydevriendt
ydevriendt's Avatar
COSMOPOLITAN
Joined Oct 2005
There's a pretty good DVD available from Paul Naton at www.carbonart.com
featuring some of the best lefthanders like Bruce from Kentucky, and Joe W.
Another excellent lefthander - Jens Kleinert - can be found at www.pcm.at putting his Fireworks on orbit.
But if you're righthanded, why would you want to throw with your left hand?
Cheers,
Yves
Lefthanded ;-)))
ydevriendt is offline Find More Posts by ydevriendt
Old Nov 03, 2007, 02:09 PM
ntommyn is offline
Find More Posts by ntommyn
aspirin addict
france
Joined May 2006
perhaps he wants to launch lower....
ntommyn is offline Find More Posts by ntommyn
Old Nov 06, 2007, 10:10 PM
Vulture is offline
Find More Posts by Vulture
Looking for lift...
Milford, NJ
Joined Mar 2005
Bruce Davidson
Bruce,
If I remember correctly, you always launch wrong handed. Of course I wish I could launch as well right handed. Or something even close.
Doug
Vulture is offline Find More Posts by Vulture
Old Nov 07, 2007, 11:09 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
When I was a novice at DLG, I had this thought too - "If I'm right handed, how will I fly the plane through the launch phase if I've jsut used it to throw the model?". What I didn't realise was just how little there is to do on the Tx if you have the model setup well - a smidgen of preset is all that's required, and if you don't want to you don't even have to have that (with careful setup).
On the flip side, until you've worked out your best technique and got it familar enough to be in "muscle memory", there's absolutely loads to remember on the launch - hand, wrist, arm and feet positions, weight distribution, arm angle, etc etc. As a result throwing with your "wrong" arm is going to make a difficult thing even trickier IMHO (plus that arm is likely to be less strong to start with).
Matt
most of whose throws look wrong, even using the right arm!
MattyB is offline Find More Posts by MattyB
Old Nov 07, 2007, 11:17 PM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
Due to the Coriolis effect, there is some advantage to throwing left handed in the northern hemisphere and right handed if you live down under.
Of course if you live down under you have to throw standing on your head.
John Gallagher is offline Find More Posts by John Gallagher
Discussion Right handers... hand launching with left hand? psycho_klown66 Parkflyers 30 Jul 11, 2007 05:25 PM
Hand launch balsa plane for school project Terry W Fuel Plane Talk 6 Oct 28, 2002 01:17 AM
