Joined Nov 2009
I started tracing the pcb, and found the SDA pin used after all.
![]() I fact, it looks like its the same layout as an Mystery 30A (bl-17a), just without the external crystal. Nevertheless, modding it to i2c should be easier then the Mystery 30A if it if possible to change ADC4 (SDA, pin 28) to ADC6 (pin 19) in the port definitions. I propose the following: Do you know which parameter to change in the asm to make it work on the internal oszillator? I read a bit into it, comparing it to the tp-18a source (without knowing much about assembler), and found that the internal oszillator needs to be calibrated, and some timings changed (halfed). I'm unsure about the POWER_RANGE and MIN_DUTY vars... ? I found the ESC on ebay: http://cgi.ebay.de/2X-10A-Brushless-...ht_2638wt_1165 12€ for two including shipping... I just read out the original fuses with ponyprog: Any more info needed?
Brasil, RS, Porto Alegre
Joined Aug 2008
the internal oscilator is configured in fuse bits.
the fuses on the picture are configured to internal . to make the mod i need full schematic. Quote:
Joined Aug 2008
well, use the firmware for tp17 and use the fuse that you sended .
Joined Aug 2008
The internal osc is 8mhz and the code is for 8mhz ! so you not need to modify anything.
when you write the code on microcontroller you need use a ponyprog script that configure the osc call byte. the script os the e2s file that came with hex code. regards. |
Joined May 2007
Overheating Mystery (BL-17) diagnosed
Hi,
It appears that the overheating on these really cheap ESCs is due to shoot-through on the H bridges (cheaper or larger FETs always have higher gate capacitance, therefore take longer to switch on or off). Adding a nop just before each "switch on" of the FETs removes this specific problem. However, it obviously causes timing issues at higher speeds. Does anyone have any better solution? |
ATMega on Turnigy Plush30 locked
Hello all,
I am converting 4 Turnigy Plush 30A for my mikrokopter and yesteray evening I made a mistake when programming fuses bits on one of them. The result is that the ATMega doen't answer anymore to my USBasp programmer (I use AVR Burn-O-Mat). I read on forum that this can be solved by high voltage programmming (via parallel programmer as STK500) or adding external clock on XTAL1. As I don't have any access to a PC with parallel port but just USB ports, I planned to go on the second option. If I undertand the way oscillator work, 3 pins are actives on these : - VCC - 5V - GND - Signal So the only thing to do is give 5V and Ground from ISP to the oscillator and connect signal to XTAL1. Does anyone have tried this ? Am I right ? ![]() Thank-you
Joined Aug 2008
With external cristall you solve this problem !
MN
Joined Mar 2009
Turnigy
I have just received a 25a and a 30a Turnigy Plush ESCs for converting to IC2. Did you get some of your Turnigy Plush 25a ESCs to work? What software did you use. Any information would be a great help.
Thank you Larry Quote:
Finally my MK seems to fly well
Hello all, as today I seem to have finally a nice flying mikrokopter, I want to share how I did it.
First of all, I first modified Tower Pro 25A : 2 TP25A type 1 + 2 TP25A type 2 from the first order from Hobbycity. As the result was not good, I ordered 2 more TP25A and luckely, I received 2 TP 25A type 2. The MK with 4 TP25A type 2 I2C modified wasn't flying better than the first try (TP25A type 1 mixed with TP25A type 2). As the MK behaviour was some shaking and pumping, I thougth it was some bad gyro setting so I tried almost every setting on gyro with no big improvement. The mikrokopter wasn't still flyable ![]() At this step, I was about to give up but some nice poeple on this forum (thanx guys ), told me to give some more tries. And as I was thinking that the problem was TP25A firmware (old 17A firmware) and I saw Arthur P. post about simple Turnigy Plush 30A mod, I decided to order 4 Turnigy Plush 30A for my last try.This week-end, I successfully modified 3 out of 4 ESC as one got blocked when programming (I will thry to add external oscillator to unblock it). As I was quite excited to test theses new ESC, I set up the 3 Turnigy Plush (front, back, right) and a tower pro 25A type 2 (left). I started the MK and the behaviour was as with TP 25A ![]() Then I had an idea !!! The MK was very responsive to all axes incuding altitude even if I was on beginner setting so I modified the max gas value from 240 to 130 and tried this setting. The result has been very good : I have been able to fly the MK on my living room (I have only 2m x 2m free to fly). The I increased max gas until I got again bad behaviour : I stopped at 140. The only drawback I noticed is that rudder isn't responsive at all. I think I will have to increase rudder setting under Kopter Tool to correct that. So for all those like me that have trouble setting up well their MK with modified I2C ESC, just try to play with min gas (motor don't start) and max gas (mk is pumping, too sensitive or shaking). It worked for me ![]() Now, I have 10 working I2C modified ESC (1 Tower Pro 17A, 2 Tower Pro 25A type 1, 4 Tower Pro 25A type 2 and 3 Turnigy Plush 30A) ... Maybe I will sell the unused one or build an hexa or octocopter ![]() Next step, I will try to unblock my fourth Turnigy Plush 30A with external oscillator as agressiva confirmed it should work. And in the mean time, I will do a test fly with the mikrokopter outside
| Thread Tools | |
| 2 Electro Fusion Motors & CC esc's from Coronas for sale | mthomson | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 18, 2004 06:13 AM |
| FS- FMA M5 dual conv Rx and 2 esc's- all NIB | Etonic | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 17, 2003 01:27 PM |
| How do I hook 2 esc's into 1 receiver ? | Al P | Power Systems | 2 | Aug 30, 2002 05:38 PM |
| EBAY Brushless Motor & 2 ESC's | S Anastasio | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 12, 2002 06:41 AM |
| WTB: 2 Hitec Feather Recievers and 2 ESC's | Ryan Nau | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 03, 2002 07:13 PM |
