Hoofddorp, Netherlands
Joined Sep 2004
Converting TowerPro 25A type 2 ESC's from PWM to TWI/I2C control
@All, This is intended as a conversion manual, not as a dicussion thread. For those who want a version with the pics more full size, and printable, the manual is availabel as a 1.8MB PDF file.
Introduction Multirotor platforms such as the Mikrokopter (http://www.mikrokopter.de/), Big Quaddro (http://www.tt-tronix.de/), or UAVP (http://www.uavp.de/) require a very high rate of updating motor throttle settings. Most commercial ESCs are not capable of accepting PPM (PWM) pulses at a rate of more than about 150/sec. Multicopters are more stable if rates of approx. 300/sec can be ensured. This has led to the design of several ESCs which use the Two Wire Interface (TWI or I2C) between the microcontroler based avionics of these systems and the speed controlers. Best known example are the Holger speed controlers (see http://www.mikrokopter.de/). Originally these were limited to 5A continous, 10A peak power. Current versions can handle 10A continuous and 20A peak power. Their price is vey reasonable. However, some users have found the manual assembly with SMD parts difficult. So far only YGE (http://www.yge.de/) offers commercial ESCs which have a TWI/I2C interface at power outputs up to 30A (YGE30i ESC). These can be integrated into the UAVP system, but use a slightly different software interface than the Mikrokopter (e.g. YGE throttle values 0..120, MK throttle values 0..255), and thus require changes to the MK software before they can be used. Another approach to developiong TWI/I2C capable and affordable ESCs has been pioneered by Quax (Bernhard Konze) and several others, based on conversion of low priced commercial ESCs from PWM to TWI/I2C control. One of the most popular conversions has been the Arkai or TowerPro 17A ESC. TowerPro also offer a 25A ESC which is very similar to the 17A. Attached the schematic of the 25A type 2 (as adapted from the schematic for the 17A; there may be some minor differences with the actual ESC such as the number of BEC regulators). Here a pictorial guide to converting a TowerPro 25A ESC type 2 (marketed since approx. Sept 2007) from normal PWM control to control via the TWI/I2C interface. |
Joined Sep 2004
TowerPro 17A and 25A ESC types, conversion guides, and firmware files
Note that this guide is for the newer type 2 ESCs which came to market from approx. September 2007 onwards. The older type 1 version had a slightly different layout, but in other respect were similar. Externally, in their yellow heatshrink, they are identical unless your recognize the different pattern of bulges due to the different location of voltage regulators on the processor side. A conversion guide for the TowerPro 17A ESCs, which have an identical layout and for which the same conversion applies can be found here: http://home.versanet.de/~b-konze/low...18a_regler.htm (in German but with pics, so probably reasonably understandable, certainly if held next to this guide). http://home.versanet.de/~b-konze/low...18a_regler.htm is also the location were the firmware files needed for the conversion of both the type 1 17A and 25A, and the type 2 25A ESCs can be found. At this time the most current version of the ZIP file with source code and the compiled HEX files is: http://home.versanet.de/~b-konze/low...10_i2c_r07.zip. Please note that there are some other ZIP files there for several other types of ESCs. You need the correct file. Using an incorrect file may damage the ESC or motor !!! So again for the TowerPro 25A type 1 and type 2 ESCs you need a file 17a410_i2c_r##.zip (## denoting the version number) for controling them over the TWI/I2C interface. Other interesting files could be the 17a410_ppm_r##.zip, which allows to resinstal PWM based control. |
Joined Sep 2004
Tools and materials needed for the conversion
To perform the conversion of these ESCs you need the following:
| Thread Tools | |
| 2 Electro Fusion Motors & CC esc's from Coronas for sale | mthomson | Aircraft - Electric - Airplanes (FS/W) | 7 | Mar 18, 2004 06:13 AM |
| FS- FMA M5 dual conv Rx and 2 esc's- all NIB | Etonic | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 17, 2003 01:27 PM |
| How do I hook 2 esc's into 1 receiver ? | Al P | Power Systems | 2 | Aug 30, 2002 05:38 PM |
| EBAY Brushless Motor & 2 ESC's | S Anastasio | Aircraft - Electric - Airplanes (FS/W) | 0 | Aug 12, 2002 06:41 AM |
| WTB: 2 Hitec Feather Recievers and 2 ESC's | Ryan Nau | Aircraft - Electric - Airplanes (FS/W) | 6 | Jul 03, 2002 07:13 PM |
