Nov 02, 2007, 10:06 PM
Haralson County GA. USA
BEC operation with input volts below out put volts.
This question came up in the Batteries and Chargers Forum.
As I read / understand the pdf spec. sheets it appears that the regulators DE uses requires input voltage to be output + 1.3V.
Question is what happens if a 6V BEC is being used and input drops to below 6 volts?
Does it just pass the available voltage?
Supply available voltage minus X?
Shuts down and passes zero volts?
With the Spektrum receivers being prong to shutting down at just below 4 volts and the more common usage of A123 and other LiIon high current cells which can have severe voltage drops under heavy loads inquiring minds want / need to know.
Charles
