Old Nov 02, 2007, 01:00 PM
Chrono is offline
Find More Posts by Chrono
aeronautic freak
Chrono's Avatar
Lima, Perú
Joined Mar 2007
Question
Balsa Painting Basics
Hello!!!
I have two questions for you people. What techniques and materials can I use to paint (airbrush) balsa (like a fuselage) and obtain a glossy shiny finish (like that of a car paint)? I'm currently painting the fuselage of my sailplane and the wood grain of the balsa still shows through the painting.
The second question is: is there any kind of iron-on fabric of light weight that can be painted?
Thx!!
Chrono is offline Find More Posts by Chrono
Old Nov 02, 2007, 01:51 PM
mode1 is offline
Find More Posts by mode1
mode1's Avatar
Southwest Missouri
Joined Oct 2002
You are going to have to add a lot of weight to the wood to get a 'car paint' type of finish. Lots of wood sealer, primer and such.
Can cover the wood with a tissue first to help seal the wood but would still add weight and work.
Many of the plastic type coverings can be painted. When I flew glow and covered wood airplanes with MonoKote I painted large areas with Acrylic Enamel.
I masked the area to be painted, cleaned the area with grease/wax remover, lacquer thinner, or similar. Scuffed the area with Grey (fine) scuff pad (available at auto paint and body supply shops), re-cleaned, tacked and sprayed. Two light coats are better than one heavy coat.
From what you said I would think covering with a light weight iron-on and then a light coat of paint would be close to what you want.
Otherwise, unless someone here has a better suggestion, only way I know of would be the tissue over wood, sealer, primer, paint, clear-coat route.
mode1 is offline Find More Posts by mode1
Old Nov 03, 2007, 08:36 PM
Lost_Dawg is online now
Find More Posts by Lost_Dawg
S.E. Michigan
Joined Feb 2006
In my experience Mode 1 is pretty much right on. I have done it exactly the way he says and you will get the result you want but it's a lot of work and it's certainly not the lightest way to go. One big thing to remember is that paints are usually shrinking for a good while after you apply them. Don't even think of doing more than one coat in a day and guys who are looking for that knock 'em dead custom car type paint wait a week or more between coats when they get down to the nitty gritty.
Lost_Dawg is online now Find More Posts by Lost_Dawg
Old Nov 06, 2007, 08:25 AM
Chrono is offline
aeronautic freak
Chrono's Avatar
Lima, Perú
Joined Mar 2007
Wow, that sound like a lot of work. As for the weight, I don't think that suits a sailplane then. But maybe the technique would work in a glow plane, just adding a little more power.
I'll wait for the next time I build a glow plane to test the technique. The rule of waiting a day between coats also applies to wood sealer? also, how many coats of wood sealer/lacquer are necessary before primer so that wood grain doesn't show through?
My last question is about the fabric... do you know if coverite fabric can be painted? I think it comes pre-painted, I'm looking for one fabric covering that doesn't, so I can apply custom paint.
Thanks a lot for your replies.
Discussion UK based balsa painting newbie seeks advice arukum17 The Builders Workshop 8 May 10, 2007 09:47 PM
Balsa painting question louisd Parkflyers 3 Mar 02, 2005 04:29 AM
