Go Back   RC Groups > Aircraft - Exotic and Special Interest > Free Flight
Old Nov 06, 2007, 10:23 PM   #16
peter_ashland's Avatar
Here is a quick prototype of the panel. I used tape on the vents and just cut the scallops.
It looks like it should have no problems staying shut or opening. The seam should keep it working fine and it does not look leaky.
  • Name: img218.jpg
  • Name: img219.jpg
peter_ashland is offline Find More Posts by peter_ashland   Reply With Quote
Old Nov 07, 2007, 09:41 AM   #17
CPR (Crash, Pickup, Repair)
catman529's Avatar
assuming that the 2nd picture is an inside view, your vent looks great. You could do a large one for the top as well.
Pulling the vent open won't collapse the balloon, it will just make a small indentation. Just pull enough to get the vent open without pulling it shut
catman529 is offline Find More Posts by catman529   Reply With Quote
Old Nov 11, 2007, 09:39 PM   #18
I am afraid it does in my limited indoor test. The extra material and rope cause the balloon to fold over that spot when the balloon is weakly inflated. But it looks like this may only be a problem when the balloon is on the ground. I will tie the valve control rope to an elastic attached to the balloon to support it for the ground teather test. It should be OK.
The servo control of the ballast is going well. I hacked a servo into a drive motor and made a candy bar style dispenser. I will drop envelopes with a couple ounces of birdseed. The tops of the envelopes will be open so hopefully the seed will just dump out on the way down. But I may just tie the bottoms of the envelops to a string on the balloon or even a streamer for effect.
The valve control will be a hacked servo winding the valve rope to open it. I am a little worried about how to spool the valve rope back out if the valve flap doesn't have much tension on it.
I am aching to get out and do the tether tests to verify the ballast weight. I am building the device to carry at least 2 lbs. But I doubt I will need that much birdseed.
  • Name: img265.jpg
Description: The balloon with a little more inflation using a cheap space heater. The balloon with a little more inflation using a cheap space heater. 22.0 KB · Views: 29
  • Name: img266.jpg
Description: Outside of balloon valve. Notice the balloon valve does not seal and the hot air leaks out. Balloon pressure was low. Outside of balloon valve. Notice the balloon valve does not seal and the hot air leaks out. Balloon pressure was low. 19.6 KB · Views: 29
  • Name: img274.jpg
Description: Inside of balloon. Notice the balloon has collapsed on the valve. The balloon temp was very low so the pressure was low. Inside of balloon. Notice the balloon has collapsed on the valve. The balloon temp was very low so the pressure was low. 21.8 KB · Views: 32
  • Name: img276.jpg
Description: Hacked servo driving candy bar style dispenser of envelope filled with 2 oz of birdseed. Servo hack was to replace pot with 2 2.2k resistors to make it a continuous drive. Hacked servo driving candy bar style dispenser of envelope filled with 2 oz of birdseed. Servo hack was to replace pot with 2 2.2k resistors to make it a continuous drive. 21.2 KB · Views: 35
  • Name: img277.jpg
Description: This is a $4 3.7g servo. The resistors need to be matched to the pot better as it is hard to dial in centerpoint for the drive. Put radio rates down to 10% and expo to -50% and they stay put. This is a $4 3.7g servo. The resistors need to be matched to the pot better as it is hard to dial in centerpoint for the drive. Put radio rates down to 10% and expo to -50% and they stay put. 19.3 KB · Views: 31
  • Name: img280.jpg
Description: The drive bar is a spiral of wire on a bamboo skewer. 2 other skewers are uses as support for the envelope. This version did not work well as the wire was from a pen. A spiral notebook wire will be the next try. The drive bar is a spiral of wire on a bamboo skewer. 2 other skewers are uses as support for the envelope. This version did not work well as the wire was from a pen. A spiral notebook wire will be the next try. 21.4 KB · Views: 34
Old Nov 11, 2007, 11:28 PM   #19
Catman529,
I checked out your solar balloon site and built a 6 ft Tetroon based on your instructions. I could only find 0.6 mil bags, so it was a little heavier than recommended. Went out to the park with it this morning and waited for the sun to poke through the clouds. I used a mattress air pump to inflate it (took a while to fill up) and then let it bake in the sun. Unfortunately, the wind was also picking up and would cool the balloon reducing the buoyancy. Eventually, it seemed to be tugging upward and I released it. It climbed 15 feet and drifted across the soccer field, "rolled" over a tree line, and appeared to be lodging itself in another tree line when suddenly it began to rise. The climb rate was slow and I jumped in the car and chased it for a couple of miles. Pretty soon it was above cloud base (1500-2500 ft?) and still climbing. I watched it through binoculars until it vanished in the NW breeze. Overall, a very exciting experience. It would be nice to have a cheap way of tracking these balloons to get some idea of how high and far they go. Next time I might just add some mylar for longer visual tracking.
Steve
mlbco is offline Find More Posts by mlbco   Reply With Quote
Old Nov 12, 2007, 09:41 AM   #20
catman529's Avatar
Don't know what the prob is with your vent, but I just built 2 on my balloon, along with a velcro parachute vent, and they work fine, Maybe I could show you pics - so far all I got is a couple shaky videos. Hope this turns out well. And I don't think your balloon will hold nearly 2 lbs. If this doesn't work out, try the 10-foot tetroon. but I hope you get it all to work soon, cuz I want to see this thing in action
Originally Posted by mlbco
Catman529,
Steve
glad to hear .6 mil bags will fly on such a small balloon! I had one incident in VA where I let go a real tiny balloon (0.5mil) and it went toward the closest mountain. Then it started dropping lower, lower, until I lost sight of it behind the trees. Drat, I thought it was done. Then a couple minutes later, it popped up again and flew up and away till I couldn't see it anymore.
and yeah, I also wish there was a cheap way to track the balloons. best thing I can do is stick a tag on and hope someone finds it, but that doesn't tell me exactly where it flew and how high it went. but someday, I would like to do the whole GPS thing with a big one.
good luck flying
Old Nov 12, 2007, 10:55 AM   #21
Here are some pictures of my balloon before vanishing.
Steve
  • Name: Tetraloon_3.jpg
  • Name: Tetraloon_4.jpg
Old Nov 12, 2007, 07:09 PM   #22
catman529's Avatar
Steve
sweet!
if you want to enter the contest, sign up, you may have a chance of getting a reply someday...since you are in CA and the jetstream moves east, you can release early on a cold morning, and it may get high enough and go halfway across the country...it's possible
Old Nov 14, 2007, 01:29 PM   #23
Here's some pictures of my contest entry solar balloon launch. Notice I added a "payload" to entice whoever finds the balloon into picking it up. Now we'll have to see if anyone ever finds it!
Steve
  • Name: Tet_1.jpg
  • Name: Tet_5.jpg
  • Name: Tet_6.jpg
  • Name: Tet_3.jpg
  • Name: Tet_8.jpg
  • Name: Tet_4.jpg
  • Name: Tet_9.jpg
Old Nov 14, 2007, 05:24 PM   #24
catman529's Avatar
wow, those balloons look great! If anyone finds them, I'll get an email. But I'm not telling anyone if their balloon is found until the end of the contest
I love the pic with the balloon and the 747...hope one doesn't get hit
keep up the good work.
tomorrow will be sunny here but also very windy, the day after though might be a great day for releasing. I'm afraid I release mine too early in the morning and they are ending up in the sea, because I haven't had any returns in a long time...
Old Nov 15, 2007, 09:18 AM   #25
Free Flight rubber flyer
Send a message via AIM to jwfinn
Another alternative would be to put a Walston transmitter on the balloon. Only trouble is that they are pretty expensive. Their long range rocket retrieval transmitter has a range of over 90 miles line of sight and only weighs an ounce.
http://www.walstonretrieval.com/main.htm
Someone with a pilot's license could go out West, launch in the morning, and follow the balloon back. It would take some careful planning to get the right set of conditions so that the balloon would hit strong winds at altitude.
jwfinn is offline Find More Posts by jwfinn   Reply With Quote
Old Nov 16, 2007, 02:41 PM   #26
catman529's Avatar
Site update:
check out the new site design....I finally moved over all the content onto the new template. yes, I made the template
www.solar-balloons.com
Old Nov 19, 2007, 08:25 PM   #27
I made a crude spherical with a 3 ft radius and released it Saturday. Here are some pictures. It flew about 1/2 mile East and then reversed direction as it continued to climb. I lost sight at after 30 minutes.
Steve
  • Name: Sphere_3.JPG
  • Name: Sphere_5.JPG
  • Name: Sphere_7.JPG
Old Nov 19, 2007, 10:16 PM   #28
catman529's Avatar
once again, looks great. even if its crude, it can still fly purty far... hope at least one of those is found
Steve
Old Nov 27, 2007, 11:09 AM   #29
who's going to make one big enough to do some solar balloon jumping ?!??!!! I have thought about giving one try
busta1 is offline Find More Posts by busta1   Reply With Quote
Old Nov 27, 2007, 11:40 AM   #30
I'm too lazy to build a balloon big enough to lift me, but here are some pictures of the biggest balloon I built. I used 20 garbage bags and I think it was 15 feet tall. Does anyone know where to buy 0.7 mil black plastic on large rolls? That's what I need to build big balloons. Taping garbage bags together gets very boring.
Steve
  • Name: Tet_6.jpg
  • Name: Tet_3.jpg
  • Name: Tet_7.jpg
  • Name: Tet_8.jpg
Free flight contest California Condor Aerial Photography 3 May 01, 2005 11:19 AM
Pegas free flight foamie modified to RC leccyflyer Parkflyers 10 Oct 04, 2001 08:43 PM
Newbie - Third incident-free flight with my SKY SCOOTER PRO!! Trent Hare Foamies (Kits) 10 Jun 03, 2001 10:24 PM
Any E-Zoners interested in free-flight scale jets? steve glass Scale Electric Planes 4 May 24, 2001 09:00 PM
Bored? Want to fight?
Join the RCGroups clan!
