Old Nov 01, 2007, 10:34 AM
BatteryJockey is online now
Find More Posts by BatteryJockey
BatteryJockey's Avatar
United States, OH, Lewis Center
Joined Mar 2002
I do not remember where I got this picture from but I have had it fior a while. The plane is call a Torcman. Maybe someone know something about it or you can start searching.
Gilbert
BatteryJockey is online now Find More Posts by BatteryJockey
Old Nov 01, 2007, 10:40 AM
atjurhs is online now
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
Search on a plane called "Yoda"
It is a very well designed/engineered open-bay flying wing comming out of Germany. Many times I have drooled over one of these. The one shown here has a motor, instead of a tow hook, just to make launching easier. But a tow hook version is an option, just more difficult to launch.
atjurhs is online now Find More Posts by atjurhs
Old Nov 02, 2007, 11:46 AM
FlattyFlier is online now
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
Does anyone know of the Boomer or the Alula's performance in flat field thermaling?
FlattyFlier is online now Find More Posts by FlattyFlier
Old Nov 02, 2007, 12:05 PM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Yoda
http://www.aff-cnc.de/aff/eng/tailless.html
Taborca
http://www.glide.net.au/on-the-wing4/177-Taborca.pdf
Curtis Suter is offline Find More Posts by Curtis Suter
Old Nov 02, 2007, 12:27 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Gilbert
Torcman is the name of the motor used. Plane is "Taborca"...:
http://www.let-us-fly.com/html/taborca.html
WimH is offline Find More Posts by WimH
Old Nov 02, 2007, 12:42 PM
WimH is offline
WimH's Avatar
Joined Dec 2001
Here's the "zeze" , holds its own with "normal" F5F models and thermals as well or better...:
http://franz-josef-ney-online.de/f5f_2007.htm
Old Nov 02, 2007, 01:03 PM
rdwoebke is online now
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
I don't know much about those two, but do know a lot about the Red Herring.
Red Herring is a good thermalling glider, but of course you won't see the performance that you would out of say an XP or a Taboo.
I suspect, that with Boomer, Herring, etc. that you will get about 40 seconds of "no thermal" flight from a hand launch.
I have thermalled my Herrings quite a bit. I don't fly them as much as I used to, but I used to consider a 60 second flight a good flight and had many 2-3 minute flights. My longest Herring thermal flight was a bit over 10 minutes but have had probably a dozen 5 minute + flights.
Ryan
rdwoebke is online now Find More Posts by rdwoebke
Old Nov 02, 2007, 06:57 PM
skyborne98 is offline
Find More Posts by skyborne98
Colton Or.
Joined Apr 2002
Zagi THL will thermal, but be careful with high starts. If you over pull the high start, it will induce flutter and possibly break the center foam... You may not see the damage, but each high start there after will just make it worse.... I had some 200 flights out of mine before i had to give it up to the trash... Its really a great way to launch on a high start and get introduced cheaply to soaring
skyborne98 is offline Find More Posts by skyborne98
Old Nov 03, 2007, 02:07 AM
dlrepp is offline
Find More Posts by dlrepp
Brea, CA
Joined Feb 2007
Hand lauanch wing
Go to the "dream-flight.com" website and check out the Alula.
It is a DLG which will also fly in very light slope lift. Discus launches to 50-60 ft are possible and the AUW is 4-6 oz's. It's also pretty aerobatic if you're so inclined.
Don
dlrepp is offline Find More Posts by dlrepp
Old Nov 03, 2007, 06:32 AM
ursus is offline
Find More Posts by ursus
Joined Sep 2005
Medea
Hello
check this
http://www.jensn.de/modellbau21.html
Urs
ursus is offline Find More Posts by ursus
Old Nov 03, 2007, 08:11 PM
Jim Deck is offline
Find More Posts by Jim Deck
Jim Deck's Avatar
Valparaiso, IN
Joined Apr 2005
Medea
Wow!! That is one beautiful built-up wing. Is it a kit? Could you give us some specifications like wingspan etc.?
Jim Deck is offline Find More Posts by Jim Deck
Old Nov 04, 2007, 12:56 AM
Accu157 is offline
Find More Posts by Accu157
Joined Aug 2004
Any one of the nice birds from B2 Streamlines would be excellent. It'd be an easy build too because there are no little pieces to fiddle around with. I've personally found that the bigger the bird the easier it is to build in my opinion (generally, I'm yet to build a truly complex model). Sometimes it just takes more time. Very few people have them, they're easy to see (big), fly unexpectedly well, ... reading your first post I think you'd absolutely love one of those.
Accu157 is offline Find More Posts by Accu157
Old Nov 04, 2007, 01:28 AM
Bernd Brunner is offline
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
Medea: more pics here
http://www.ig-nurfluegel.ch/helmut_seiffert.htm
And look at this site: http://www.ig-nurfluegel.ch/
Bernd
ps. but still no specs..
Bernd Brunner is offline Find More Posts by Bernd Brunner
Old Nov 04, 2007, 10:10 AM
ursus is offline
Joined Sep 2005
Medea
Hi Jim
there is not a lot to say.
Wingspan is 200cm.
Best is, if you download the plan http://www.jensn.de/downloads/Medea.zip
Included are some PDF's, DXF and DWG files.
I have actually a Medea on my building board . Hope to get it finished till spring. A BOt is also waiting for the finishing stuff
Urs
Old Nov 04, 2007, 01:42 PM
dare to thermal
Mannheim, Germany
Joined May 2004
Urs,
do you know what airfoil is used on the Medea?
Bernd
Discussion Are there any showtime 4D plans out there? lil_chinky_b0i The Builders Workshop 0 Jan 07, 2007 11:50 AM
are there any good g3 planes out there? 102511 Simulators 1 Oct 19, 2005 11:35 PM
are there any realistic flying games for the PC out there?? EABiker Simulators 6 Oct 07, 2003 05:52 PM
Are there any '600' sized 'zagis' out there? Peter W Foamies (Kits) 2 Nov 28, 2001 01:34 PM
Are there any WINGO fan pages out there? exempt Foamies (Kits) 3 Jul 16, 2001 06:17 PM
