Old Oct 30, 2007, 09:16 AM
Heritic is offline
Find More Posts by Heritic
Portchester Nr Portsmouth, Hampshire UK
Joined Nov 2006
DX7 Throttle cut if bad signal lo radio power
I have just bought a DX7 and after a Futaba 6XH, quite a lot to learn before I do flight trials.
Anyway, most things sorted BUT:-
Can I programme the throttle to cut if Raido power or signal lost.
Heritic
Heritic is offline Find More Posts by Heritic
Old Oct 30, 2007, 09:19 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
You can't make one NOT cut the throttle. However, you MUST rebind after programming the TX for this to work correctly with a gas or glow model, or with one of those rare ESCs that need the throttle channel reversed.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Oct 30, 2007, 12:29 PM
colecaz is offline
Find More Posts by colecaz
I need a bigger hangar
Phoenix, AZ
Joined Jan 2007
The biggest point of confusion in programming the DX7 is that it needs to be rebound (re-binded??) several times as programming progresses. The first time is to bind it to the model number you are going to use. Then after trimming and servo installation. The most critical one is the final one and that establishes the position of all control surfaces and throttle when power is applied to the receiver and before the rx has time to acquire the tx. Set the default stick positions before turning on the tx for the last bind you intend to do and those become the default rx power up positions.
Loss of signal then causes the rx to hold the last stick positions and cut the throttle to the position at last binding.
As an aside, the BR6100 goes to the bind position of all sticks at loss of signal. That's the only difference between it and an AR6100
colecaz is offline Find More Posts by colecaz
Old Nov 01, 2007, 07:47 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
It does not "Cut"the throttle, the throttle will go to the position of the throttle stick at the time of the last binding. If you binded the rx to the tx with the throttle stick at full power, it will go to that setting.
So it is wiser to rebind the rx to the tx after everything is set to the proper trims.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Nov 01, 2007, 08:05 PM
Joined Jun 2006
Yes, I knew that... could have written it up more clearly I suppose.
Help! Spektrum Dx7 Throttle Cut misplacedtexan Radios 2 Sep 27, 2007 06:21 AM
Discussion DX7 throttle cut function. bigandy Radios 2 Jul 27, 2007 02:08 AM
Discussion DX7 Throttle cut in Airplane mode localbuyer Radios 3 Jul 25, 2007 11:50 PM
Discussion Spekrum DX7- programming in idle down and throttle cut attesi Radios 1 Jan 27, 2007 03:10 PM
Pixie20P cut-off and throttle range with a Hitec Focus 3 radio. EGB Castle Creations 1 Apr 23, 2004 05:09 PM
