Old Oct 29, 2007, 10:11 PM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Build Log
A Prototype Albatros DII by Peter Rake
A couple of months ago, Peter asked would I be interested in another prototype build but asked me if I had any preferences. After a few suggestions, an early Albatros fighter was chosen as it had some features which I'd never tackled before - notably a plywood skin to the fuselage!
This early Albatros had fairly flat sides to the fuselage and the ply panel lines looked as though they could be replicated with a little care so I agreed to give it a go.
The DII model had wings of similar size and standard inter-plane struts unlike the V struts of later variants. I was also attracted to the 'ear' radiators mounted on the fuse sides. This meant that there were no radiator hoses to disguise servo leads to the upper wing so with a big sigh, Peter designed the ailerons (top wing only) with control cables as per the original and a central fuselage-mounted servo. Sounds like fun
Other minor departures from Peter's 'standard' designs are optional scale airfoil sections on the tail surfaces. These are quite pronounced on the Albatros family and should look good.
Charlie and Vicki at Manzano produced a box full of bits as shown in the photos - 10 sheets of balsa of various thicknesses, 3 sheets of bass and assorted ply bits. It all looks yummy
The model is about 42" span and will stand around 13" high - it should fit in most cars assembled. I would imagine the weight to be 24-26oz - the 1/64 ply skin will not be the lightest construction.
Sadly, the DII was never given the wild decor of the DV aircraft - mostly a plain varnished fuselage and fin with pale blue undersides and camoflaged upper surfaces. Some had interesting personal or group motifs on the fuse sides.
There will be a short delay before starting as I've recently sold our second car and now have half a garage to set up as a workspace More storage and accessibility will be most appreciated. BTW - it was Liz's car that I (we) sold
Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Old Oct 29, 2007, 10:20 PM
Wolpertinger is online now
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
The world can never have too many Albatri! I'm looking forward to seeing how she comes together. I think the DII will likely be the better flying airplane compared with the D.III/V because of the wing area. And a varnished ply fuse has a charm all its own.
Wolpertinger is online now Find More Posts by Wolpertinger
Old Oct 29, 2007, 10:27 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Don't worry, there's a DIII in the works too
Pat, Yummy? Never heard balsa and ply bits referred to this way
charlie
portablevcb is offline Find More Posts by portablevcb
Old Oct 30, 2007, 12:02 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
You cant understand a 'yummy' model kit? - Charlie you're losing your boyhood romanticism - I will too when I grow up
Pat
Old Oct 30, 2007, 03:01 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Pat,
Come on mate, own up, the DII only came about because you needed something on which to mount a dummy water cooled, in-line engine.
Just as you mentioned the aileron linkage, something that has been bothering me because of the need for a central servo, I was struck by the idea of a servo in each lower wing. It could go in the same bay the cables exit from, but would require very short output arms. Probably why I discounted it in the first place, but it could be made to work.
For those worried about setting up this system, conventional upper wing mounted servos are also shown. Late DIIs even had a wing mounted radiator, providing you with a coolant hose to disguise the extension lead.
Of course, it's all very well talking about these things, there's a long way to go before we get to them and only time will tell if I got the bits right in the first place.
I know the M1c has visited the flying field, but was that just a 'show and tell' type affair, or did it see air time? Or is there a more sinister reason for the lack of a flight report? I always get twitchy when a design approaches flying. Yes, more twitchy than normal.
BTW, what's growing up?
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Oct 30, 2007, 03:10 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Fear not Peter - the M1c was on a PR mission! It actually got a few of the 'models only come out of coloured boxes' brigade talking about early aircraft and cable-operated control runs etc. It only got a beat around the pit area to show that a hand-made prop does work
About my only reservation with it is that rather narrow UC on my rough field - but I imagine it will be airborne quickly. A video ofthe Shuttleworth machine showed it wobbling a bit too.
As soon as it is finished and photographed, it will fly. I have a mortal fear of destroying a prototype build before it is finished so........
Growing up? - I hope it never happens.
Pat (in 3rd childhood (at least))
Old Oct 30, 2007, 05:30 AM
floss is offline
Find More Posts by floss
floss's Avatar
Auckland, New Zealand
Joined Sep 2005
Seems that the Albatros is getting some attention lately, I'll be watching eagerly not only because its always been one of my favourites but also because I'm building a scratch DIII. WS is 38" and target weight is around 26oz with a 3S 2250mah onboard.
Steve
floss is offline Find More Posts by floss
Old Oct 30, 2007, 04:16 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Looks good Steve. You seem to be using very light balsa sheeting - 1mm?
Peter's design does not sheet the tail surfaces but I am tempted to sheet the fin as it is varnished but even .4mm ply may be too heavy at the tail end so balsa is an alternative.
Are the various metal struts plain aluminium tube or is the steel wire reinforcing - I apologise for so many questions but not point reinventing wheels
Pat
Old Oct 30, 2007, 05:50 PM
floss is offline
floss's Avatar
Joined Sep 2005
Pat
The sheeting is indeed 1mm and the oval section aluminium LG struts have a carbon fibre rod through them. The cabane stuts are just aluminium with fibreglass board fittings. It will be fully rigged with the tiny braided steel rope that I used on the pull/pull system so strength wing-wise will not be a problem. The balsa tail is solid.
Steve
Old Oct 31, 2007, 03:15 AM
fooesboy is offline
Find More Posts by fooesboy
Registered Abuser
fooesboy's Avatar
Hamilton, New Zealand
Joined Oct 2005
Pat
Hi Pat,
This will be a built that I will follow with great interest.
On my aerodromerc Albatross I have sheeted the tail with 1mm balsa, but I have found it to be a little too soft. When sanding the sides smooth the balsa bends in between the frame and cross braces. If I was doing it again I think I would use 1.5mm balsa and sand down. I would also use thinner balsa for making the frame , I didn't do this and it looks a little odd with the rudder being thinner by 2mm, but I am not going to change it because I think (hope) that it will not be noticeable when the aircraft is complete.
There is no need to wish you luck with this build, your work is truly amazing, instead I wish you "viel spass" (lots of fun)
Chris
fooesboy is offline Find More Posts by fooesboy
Old Oct 31, 2007, 03:28 AM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Chris - thanks for the info. I will weigh some 1/64 ply and compare with balsa. The balsa would need grain filler etc so I might get away with that little bit of heavier ply!
Yes - I intend to have fun and Vielen Dank für das Kompliment
Pat (Kiwi living in Oz trying to speak German on an American site to a Swiss!)
PS My mother's father was Swiss (Utiger)
Old Oct 31, 2007, 06:10 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I did this once = 1/64" ply about the same as 1/8" SOFT balsa.
Old Oct 31, 2007, 11:06 AM
Martin Irvine is online now
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
I found the same as Vint. Different sources of ply will vary in weight a bit but if you think 6-8lb 1/8" balsa, you'll be pretty close.
Martin
Martin Irvine is online now Find More Posts by Martin Irvine
Old Oct 31, 2007, 01:28 PM
Redbaron25 is offline
Find More Posts by Redbaron25
North East England
Joined Feb 2004
Pat - I remember you saying you are (or were) a ship modeller, so that ply skin should pose little problem for you (just don't paint a waterline along it...). In case you don't already have it, I have the Signal Publication 'Albatros Scouts', with some good detail pics and sketches of the D11, such as radiators, control runs, etc. Just yell if you need anything!
Looking forward to this one.
Steve
Redbaron25 is offline Find More Posts by Redbaron25
Old Oct 31, 2007, 03:22 PM
a.k.a Maltone
Pat Lynch's Avatar
Joined Jan 2005
Fin Musings
Only thinking out loud here - given that 1/64 ply is a lot tougher than Litespan or 1mm balsa skin, it may be possible to minimise the internal framing to cut the weight.
I may make two fins and compare. I could do that now before I start building - I would really like the fin to be of the same texture/finish as the bare fuse.
Unless anyone can find a DII reference with a painted fin - I havent seen one.
Of course it is also possible to "stick-to-the-plan" and then try and match the painted fin to the fuselage
Steve - I've already made some test runs to see if CA could be used - it would make skinning so much easier. Thin CA soaks straight through the ply and onto fingers but the medium variety works fine. Just have to be careful not to get any on the surface - makes the staining look awful!
Pat
Last edited by Pat Lynch; Oct 31, 2007 at 03:33 PM. Reason: not sure what a 'pinted fin' was!
Build Log 36" SPAD XIII - By Peter Rake SKY KING Scale Kit/Scratch Built 387 Oct 21, 2012 12:43 AM
Build Log Ryan's Daughter - a low-wing sport model by Peter Rake Pat Lynch Sport Planes 147 Apr 23, 2010 01:24 PM
Build Log Nieuport IV for IPS (designed by Peter Rake) BaZsiX Scale Kit/Scratch Built 56 Jun 24, 2007 03:00 PM
Fokker D VII by Peter Rake Ian Easton Scale Kit/Scratch Built 158 Dec 21, 2005 11:06 AM
Goupy Biplane by Peter Rake pburress Scale Kit/Scratch Built 10 Jan 15, 2005 02:08 AM
