Old Oct 29, 2007, 09:56 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Vacuum forming over high density urethane foam-safe or toxic gas release?
I was given a chunk of high density urethane foam, greenish grey in color, really dense, by a guy with a cnc machine. He said he used to vacuum form parts over it and that it didn't deform from the high temperatures. I've read various times over the years that you can't hot wire this stuff because it releases toxic gases (cyanide?) when heated or burned. I'm wondering if this stuff will release harmfull gases at vacuum forming temperatures (I assume no higher than say 400 degrees).
Anyone?
Wanting to vacuum form a canopy for my scratchbuilt F/A-22 over in the edf forum and don't have time to carve a plug out of balsa or jellutong.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Nov 07, 2007, 05:29 PM
DLD is offline
DLD
Find More Posts by DLD
DLD
David Layne
Tracy, Ca
Joined Jun 2004
With most foam, some sort of toxic gas is released when it is heated to melting temperatures. If kept below melting, the problem should minimized. I can't say that I have specific experience with vacuum forming over urethane foam, but if you do the job in a well ventilated area, it shouldn't be a problem. The worst thing that could happen would be your plug melting, and you'd have to re-carve it.
You might try something a friend of mine used to do. He carved a canopy plug undersize from foam. then he would apply plaster of paris to it, shape it, apply epoxy to the surface, let it saok in, then wipe off the excess. He would apply epoxy this way several times, and it would develop a very smooth finish. Vacuum forming could be done right over it. It worked well, and the plaster of paris is easy to work. Just a suggestion.
DLD
DLD is offline Find More Posts by DLD
Old Nov 07, 2007, 10:50 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
There aren't too many Poly-U foams that can do over 300F but since it is seeing only a flash of heat rather than a soak in heat it may survive just long enough. If he says it worked for him without deformation than maybe it is good enough. If you were going to do many parts I'd say don't do it because the heat would build as more parts were made from it. If it works and the master suvives, you could make a casting out of one of the lexan parts and go from there.
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Yippee! GWS A10 Brushless version by high density helmet foam GWS4CEO Slope 2 Dec 06, 2011 11:01 AM
Question Can you put epoxy or Gorilla Glue over foam-safe CA? Spackles94 Electric Plane Talk 5 Aug 12, 2007 06:58 AM
high density foam in UK Stik The Builders Workshop 7 Nov 13, 2005 02:25 PM
Slowstick Repairs: Epoxy or Foam Safe CA? kizzy Beginner Training Area (Aircraft-Electric) 7 Nov 13, 2005 12:09 PM
Where to buy high density white foam? Summer Foamies (Kits) 3 Jul 21, 2003 12:43 PM
