Old Oct 29, 2007, 11:32 AM
geekdisk is offline
Find More Posts by geekdisk
FPV Heli Flyer
Joined Mar 2007
Wood main blade for T-rex 600 -Where to find??
I'm having a heck of a time finding a source of 600mm wood main blades for the T-rex 600. I also welcome opionions and suggestions on wich to get/avoid. I have heard the Thunder Tiger are not efficient, but I don't know for sure.
If anyone has any sources of 600mm wood main blades please post them.
Here is what I've found limited as it is;
HeliDirect.com Esmart 19.99 http://www.helidirect.com/product_in...oducts_id=2571
HeliProz.com Mavrikk 18.99 http://www.heliproz.com/prodinfo.asp?number=803415
HeliProz.com Thunder Tiger 27.99 http://www.heliproz.com/prodinfo.asp?number=132250
geekdisk is offline Find More Posts by geekdisk
Old Oct 29, 2007, 12:22 PM
nieves50 is offline
Find More Posts by nieves50
nananabooboo!!
nieves50's Avatar
United States, OK, Oklahoma City
Joined Mar 2003
I hope you're not trying to do any demanding manuevers with wood blades.....
nieves50 is offline Find More Posts by nieves50
Old Oct 29, 2007, 04:56 PM
muda is offline
Find More Posts by muda
muda's Avatar
Lt
Joined Mar 2006
http://www.helikraft.com/Thunder+Tig...-+50+size.html
muda is offline Find More Posts by muda
Old Oct 29, 2007, 10:35 PM
syclic is offline
Find More Posts by syclic
Joined Jan 2006
I have used these on a number of different 50 helis.
http://www.heli-world.com/detail.aspx?ID=734
They work very well. I also like that the blade covering is already removed at the root for better adhesion of the blade roots when you glue them there. I also like the blade roots they come with as their securing screws are also not on the same thrust line (makes them stronger).
Every set I have used were well balanced and without any warp. Not like a number of other woodies I have tried over the years.
syclic is offline Find More Posts by syclic
Old Oct 29, 2007, 11:10 PM
ScaleBrad is offline
Find More Posts by ScaleBrad
115 inches of 'hog
ScaleBrad's Avatar
United States, FL, Orlando
Joined Aug 2004
The problem I see is that wood blades have a maximum safe RPM of about 1800...While the TREX and other electrics run higher head speeds (2000+) so basically you are trying to run glow blades on an electric heli in my opinion. Not so safe I think.....Why are you wanting woodies anyways??
ScaleBrad is offline Find More Posts by ScaleBrad
Old Oct 30, 2007, 08:06 AM
geekdisk is offline
FPV Heli Flyer
Joined Mar 2007
Why woodies on T-rex 600 and where to find (?)
I want to use wood blades on my T-rex 600 electric for economic reasons. The cheapest non wood blades cost $50 where wood blades run $15-$20. I'm just getting better at forward flight and am sure crashes are in my future.
I have probably 50 flights on t-rex 450's and plenty of sim time, I have zero experience on the t-rex 600.
Folks have said that wood blades on t-rex 600 is bad, others say it's good and also cheaper.
Still looking for more opinions on the subject and blade recomendations.
-John
Old Oct 30, 2007, 01:53 PM
syclic is offline
Joined Jan 2006
The head speed and endurance (how long it will fly on a given battery pack) of an electric is directly related to the KV spec of the motor and the motor pinion selected. (see the info on KC's sticky at the top of this forum)
There are many people that fly electrics at rotor speeds a lot less then 2100. What the 2100 head speed gives (relative to 1800 or 1600 or 1400) is faster cyclic acceleration...a plus for Extreme 3D but not necessary for sport 3D, sport aerobatics, scale flight or initial training. In fact, the lower head speeds are usually much better in these situations.
I have flown my electric Swifts (16 & 550E) at head speeds ranging from 1450 to 2300. It all depends on what you want to do with the heli. Using the same battery pack at 1450 will deliver almost 3 times more flight time then gearing it for 2300!
For geekdisk's type of flying, depending on the pinion he selects, he can easily gear his Align 600 for a comfortable head speed for his wood blades (e.g. 1650 to 1850).
As for safety - If you search the net (sights like Run Ryder and Heli Freaks), you will find there has been a BIG issue with the Align composite blades (not woodies) throwing their weights in flight and destroying helis. So blade design is also an issue here, where woodies can prove more safe then composites. P.S. Over the years, I have also found some woodies that fly better then some composites.
Another note on head speeds, is that one can also have a type of head design that may require a 2100 head speed to deliver the same cyclic response as another design does at 1800. A lot depends on the design and how it is configured.
Old Oct 30, 2007, 02:02 PM
Wheelhaus is offline
Find More Posts by Wheelhaus
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
I completely agree with syclic. Gear down the headspeed so woodies will be safe, and as an added benefit, the flight times will be longer.
The easiest way to do this would be to use a smaller pinion so you can stay in the motor's powerband, but it will spin the head slower. The second method is to just get a lower Kv motor.
Wheelhaus is offline Find More Posts by Wheelhaus
Discussion 14t pinion for the T-Rex 600 188t Main gear nicco Electric Heli Talk 0 Dec 30, 2006 02:56 PM
Discussion Biggest blade for T-Rex PetruSoroaga Mini Helis 6 Sep 07, 2006 04:25 PM
Discussion Digital Servos for the T-Rex 600? Lv2Fly Electric Heli Talk 8 Aug 20, 2006 01:37 PM
Sold 315 mm Fiber Blade for T-Rex SFS75 Aircraft - Electric - Helis (FS/W) 2 Mar 10, 2006 02:53 PM
MicroHeli CF Main Frame for T-REX update -mH Mini Helis 9 Apr 25, 2005 06:22 PM
