This thread is privately moderated by superdave42, who may elect to delete unwanted replies.
Old Oct 29, 2007, 09:40 AM
superdave42 is offline
Find More Posts by superdave42
Designer
superdave42's Avatar
morgan hill california
Joined May 2004
Y-Flyer concept
I've been keeping an eye on these quad and Y type UFO crafts, ?I think they are pretty neat machines.
the other night I had an idea for an ultra responsive 3D capable Y-flyer.
basically 3 complete hornet heli tail booms driven off a single main gear and single motor, all fully collective pitch with possible 3 blade rotors.
here are some very simple concept pictures for now.
this will be able to be controlled via standard 120 ccpm mixing :-)
David
superdave42 is offline Find More Posts by superdave42
Old Oct 29, 2007, 01:04 PM
StarmanDXE is offline
Find More Posts by StarmanDXE
Advanced Learner
StarmanDXE's Avatar
United States, NC, Charlotte
Joined Dec 2006
Huh. Looks cool!
So, why the 4th servo?
StarmanDXE is offline Find More Posts by StarmanDXE
Old Oct 29, 2007, 01:13 PM
Designer
Joined May 2004
:-) thanks,
it is only a very simple concept model currently, had to get the idea out of my head first.
3 servos are for changin the pitch on the 3 booms, the 4th servo is to rotate the 3rd boom for yaw control.
Old Oct 29, 2007, 03:32 PM
Advanced Learner
StarmanDXE's Avatar
Joined Dec 2006
Ah! Tricky!
This idea sounds pretty sweet! Think it can fly well without some sort of computerized help?
Old Oct 29, 2007, 03:36 PM
Designer
Joined May 2004
Originally Posted by StarmanDXE
Ah! Tricky!
it should fly like a standard ccpm CP helicopter :-) it WILL NOT self level !!.
but since it is CCPM and you could use the FS8 and Co-pilot system to make it self level ;-) My goal is to make this work with mostly off the shelf pre-made helicopter parts, just need 2-3 custom parts to make it work, plus the chassis plates of course.
Old Oct 29, 2007, 04:36 PM
Advanced Learner
StarmanDXE's Avatar
Joined Dec 2006
Sounds awesome!
Any idea what it's gunna cost you in the end?
(Also, you could make different sized ones just using different heli size tail booms )
Old Oct 29, 2007, 06:00 PM
Designer
Joined May 2004
Sounds awesome!
not sure baout costs yet, gonna buy 3 hornet 2 kits though to start with.
as far as using diffrent sized booms, well this is a mechanical "system" and each compnonent in the system to needs to be sized accordingly, but sure you could design a much larger base and use 90 size nitro heli tails with torque tubes and 105mm blades and...... hehe.
I want to build a nice light CP flying machine first.
Old Oct 31, 2007, 12:17 PM
Designer
Joined May 2004
Last night I decided to add a 4th tail boom, but it will still be a Y-Flyer, the 4th boom will make it truly acrobatic. I will make a new model as soon as I can get a chance.
1. CCPM 120 control
2. Standard Rudder control
3. 4 Servos
4. 3 Gyros
5. CSM Cyclock device
6. Spektrum AR6100 RX
7. Battery un-determined
8. Single outrunner motor running in Govenor mode
This platform will allow ANY acrobatic move that a real 3D helicopter can do
Dave
Old Oct 31, 2007, 12:23 PM
Advanced Learner
StarmanDXE's Avatar
Joined Dec 2006
So, what's the 4th boom for?
Also, 3 gyros? Wowzers!
And what's a "CSM Cyclock" device?
Old Oct 31, 2007, 12:33 PM
Designer
Joined May 2004
4th boom is for insane 3D acrobatic control of this platform ;-)
CSM Cyclock http://www.rcmodels.org/csm/cyclock1.htm
and yes 3 gyros, 1 for elevator, 1 for aileron 1 for yaw. and this craft can be flown from any 4 channel TX because of the Cyclock device
Old Oct 31, 2007, 12:42 PM
Advanced Learner
StarmanDXE's Avatar
Joined Dec 2006
"Insane 3D acrobatic control," eh? So, will it just be sticking out from one of the sides, then? And will it control yaw?
Man, that's a lot of electronics. Gunna make it expensive... Can you fly it without all of that stuff?
Old Oct 31, 2007, 12:51 PM
Designer
Joined May 2004
expensive ? lots of electronics ? I take offense to that take a look at the $1,000 + X-3D Quad ufo flyer in the multi rotor threads, that is expensive and has a LOT of electonrics, more specifically it has 4 Brushless motors, 4 custom high end Electronic speed controls, 3 gyros, etc......
this has 1 motor, 1 normal speed control, 2 cheap Rate gyros, 1 Heading Hold gyro, and 4 digital servos, 1 RX and 1 Cyclock.
I am building a very high performance machine. possibly it will get copied in china and mass produce with low quallity parts and e cheap, lol who knows,
just one of my very many crazy ideas..
Old Oct 31, 2007, 01:01 PM
Advanced Learner
StarmanDXE's Avatar
Joined Dec 2006
I thought you were just doing this for fun Didn't realize it was your job or something...
Just wondering if there was a cheaper way to go about doing it. But, I guess, as you said, the rate gyros will be cheap. Guess I'll have to wait and see
Old Oct 31, 2007, 01:25 PM
Designer
Joined May 2004
Yeah you're right, just something for fun hehe, my main initiative is to make it less expensive then the X-3d that is out right now.
I just get overly excited sometimes
Old Oct 31, 2007, 02:57 PM
Designer
Joined May 2004
Hmm I found a concept drawing of my new Acrobatic UFO platform.
Discussion High Lift Slow Flyer Concept Hughbert Foamies (Scratchbuilt) 7 Apr 25, 2007 04:16 PM
