| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Shark Bait - A cool little 18" plane
I've been trying for quite a while now to make a plane in the 18" range.
So after several failed designs I finally nailed down a good one. I'm still new to alot of this so it took some trial and error. Its a simple build and a good flyer. I did the maiden flight yesterday and was going to shoot some video today but it was too windy. I'll post some tomorrow hopefully. I used most parts from United Hobbies: 24g 1700kv motor Loong-Max 500 maH 2 cell (Will try a 3 cell tomorrow too) 3.4 g servos (x3) TowerPro 12A ESC GWS 6 channel rx but you only need a 4 channel Total weight ready to fly was 5.66 oz but you may be able to cut it to 5 oz if you go easy on the hot melt glue. I had to spread the electronics out a bit acroos the fuse to get better balance. The plans are a 72 dpi bitmap. I'll make a better one if there is interest. Enjoy! |
#2 |
4EverYoung-Got Toys!
Yes, there is interest. I need a couple indoor flyers for this Sunday. I have no idea how to print a 72dpi bitmap to scale (is posted as a jpeg to add to my confusion), but will fool with it if you don't have a tiled pdf up by this evening. Looks good and easy, thanks Chris.
-Don |
#3 |
Yep, I'm gonna need help with this one Chris. Opened in Paint and printed, gave me two sheets, your inch scale on my sheets came out 1"= 0.383". I don't know much about working with images.
#4 |
Build 2 Bounce!
That's a nice little model you've got there Chris, I like the paintjob too
Lakota, i've done a quick tile of the Jpeg for you to get you started. Chris if you want to send me the original file then i can produce a better tiled version if you'd like me to. Si. |
#5 |
Cool! Love to see a video of it..
Kim |
#6 |
Postcards from the Purple Edge
Are you building with FFF or EPP?
#7 |
Thanks for the quicky plans Si. I actually started down the road
to this design after messing around with your Sumo. I gave making some plans a shot. Hopefully they're cool. I put a 28x18 border around them for a guide. tuppertn, I built it with the Blue FFF (DOW protection board III) I was trying for a small plane with the most common materials. I also wanted it to be able to take mild crashes. You can probably loose the 2 vertical skewers to save some weight. They are mainly there to help prevent the tail from cracking off. Here's the new plans... Chris |
#8 |
It might also be worth mentioning that I put a spot of glue in the corners
where the nose meets the leading wing edge. It seems to help prevent cracks from developing in those areas. |
#9 |
Foamie Guy
a simple radius might help prevent stress cracking in that area...
#10 |
NICE!
You saved me some work. I was going to try and profile a toonracer. This is perfect for what I was hoping for. I wonder if the little 10g outrunner and a light 2cell will fly it. Might be able to cut the weight down to under 4oz. |
#11 |
gpw, good idea. I'll try that on the next one.
Dritch, I tried one of those little silver motors with a 7 inch prop on my first attempt (with a slightly different body). It did fly just not as good. It felt too under powered. Maybe with 2mm depron and a Thunder Power 480mah it would go better. ? |
#12 |
The Dude Abides
Flat wing? Would a tiny KFM give it a bit of "pop?"
#13 |
I like it. I want to build a plane this size.
#14 |
Chris. I'm thinking some sanding, a tiny 2cell, and some sub 6gr servo's should get it light enough. Maybe it won't hover, but might be able to keep it in halfcourt.
#15 |
Dritch, "as is" she'll fly pretty slow and I'm sure it will fly with the 10g motor.
But your right it likely struggle to hover and you'll just have to keep her moving a little faster. Maybe try a kf step like Beemus mentioned (inplace of the mid supports ?). I may do this on my next one. The way she flys now on a 2S is slightly weak on loops. It wants to tip over unless you power through. Dives pretty quick due to the nose weight. However, before I first trimmed out the rudder I was able to do a few hands-off flat ovals around our park. I was surprised because it was a little windy and its a small plane. I was expecting it to be twitchy. I can't wait to give a 3S a go today. I know the extra weight will cut into the slow flying some but the extra power should make it a rocket. |
| Thread Tools | |
| Sold Cool little electric plane of unknown origin. | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 8 | Oct 23, 2006 11:49 AM |
| Cool 3DX-based plane | Dezynco | Foamies (Kits) | 3 | Nov 30, 2003 07:58 AM |
| Who makes those cool little RX Antennas? | Helicool | Foamies (Kits) | 21 | Mar 09, 2003 01:46 PM |
| Cool little kids sub (Sea Tiger) | slowflyer | Submarines | 4 | Aug 03, 2002 12:52 PM |
| Anyone Flown a Tee Bee or Little Bee Plane??? | Tim Seidenstricker | Parkflyers | 1 | Sep 12, 2001 06:04 PM |
