Old Dec 09, 2002, 12:23 PM
YVR is offline
YVR
Find More Posts by YVR
YVR
Sean in YVR (Vancouver)
YVR's Avatar
Vancouver, BC
Joined Sep 2001
Pulling to canopy in knife-edge?
The model in question is a Super Mini Diablotin - it doesn't seem to really like knife edge, but will sustain it at or near WOT with a lot of rudder input. As I've been stretching out the KE runs, however, I've noticed it pulls towards the canopy - ie the flight path is sort of banana shaped. Is this typical? Can someone more experienced than I explain why this happens, and how (if) I can correct it? Thanks!
Sean
YVR is offline Find More Posts by YVR
Old Dec 09, 2002, 01:02 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Sean,
Yes, it is a trait of the Mini D (pulling toward canopy in KE). Gary Wright discussed this in one of his posts about why he shaped the E3D's canopy and rear deck the way he did (function over form). If you have a radio that allows mixing, you can probably compensate that way. I can't KE mine (I'm a mere mortal), but Gary flew it at this year's Sizzle in MD .....and he was able to KE it fine.
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Dec 09, 2002, 01:10 PM
YVR is offline
YVR
YVR
YVR's Avatar
Vancouver, BC
Joined Sep 2001
Hmmm. So would I mix in a bit of down elevator with rudder?
Old Dec 09, 2002, 01:17 PM
Ed Lyerly's Avatar
Joined Apr 2001
Sean,
I have not done it, so can't say for sure. Perhaps someone who has can offer some input here ?
Ed
Old Dec 09, 2002, 01:34 PM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
I'm an aerobatic novice and I was just wondering if the plane does pull a little in one direction and a little control is needed to offset it, isn't that part of the whole aerobatic experience instead of having the radio do the work? So if you add a little down elevator does it fly straight in the KE?
Kelvin
kelvin is offline Find More Posts by kelvin
Old Dec 09, 2002, 02:08 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
I'm still dialing in my E3D and it was pulling towards the canopy on KE. In the online maual, Gary suggests that one could dial in some "down" in the ailerons to counter some of the pitching tendancy.
Most of my aerobatic planes have been pretty neutral on the KE requiring only opposite aileron to counter roll coupling, with minor adjustments on the elevator to keep it going in a straight line. You can dial in computer mixes but you'll want it as a certain "flight mode" (ie when you want to do KE) rather than a constant mix. I like to manually tune the plane before I start adding mixes, but sometimes you can only go so far.
Troy is offline Find More Posts by Troy
Old Dec 09, 2002, 03:35 PM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Just getting the plane to fly straight and level by fiddling with the trim tabs is not enough if you plan on doing anything above and beyond flying straight and level. There are a whole series of tests you can go through to trim a plane for aerobatics. One such trim chart is posted on the Great Planes website.
I believe the pulling-toward-the-canopy behavior is indicative of a slightly negative wing incidence. Drooping both ailerons slightly has the same basic effect as increasing the wing's incidence, but the proper way is to shim up the wing until the plane flies correctly, then sand the wing saddle to match.
mkirsch1 is offline Find More Posts by mkirsch1
Old Dec 09, 2002, 06:19 PM
Bob P is offline
Find More Posts by Bob P
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
Most models display some sort of interaction between the conrtrol axes. Simple to fix. Set up a free mixer on the TX with rudder as the driver and elevator as the slave. Mix in down elevator with rudder, it will have to be set in each direction. Then go fly and adjust to get neutral trim with rudder in knife edge.
You will probably find that the model rolls with rudder so simply set up another mixer with rudder as the driver and aileron as slave.
Trimming a model to make it neutral like this allows you to concentrate on getting your aerobatics just right without having to worry about interaction between the controls. Imagine trying to fly a nice slow roll with the model tucking in and changing roll rate when you apply rudder to maintain the line!! With mixing easy, well sort of.
Bob
Bob P is offline Find More Posts by Bob P
Old Dec 09, 2002, 06:46 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
With the E3D, the wing is permanently fixed so you end up dropping the ailerons for incidence trimming. Other than that, one should fix the incidence however they can.
Old Dec 10, 2002, 01:13 AM
kmashima is offline
Find More Posts by kmashima
kmashima's Avatar
San Jose, California, United States
Joined Feb 2002
If the Mini Diablotin is anything like the Super, which I believe it is, then KE is generally hard. So you should feel good about being able to KE at all.
If you have a Tx where you can dial in the flaperon amount, you can fiddle with it in flight to get it right. It's usually a pretty small amount.
But if your plane is basically tracking well and NOT roll coupling, which is the biggest problem on Diablotins (E3D don't have this problem as much), then I would just steer with the elevator since it acts as your rudder. You need to learn to do this anyway because you may want to KE circle or KE across the field and come back by turning. It's a fun thing to do.
Make sure you crank up your expo to 100% so you can have fine control.
-- Kyle
kmashima is offline Find More Posts by kmashima
Old Dec 10, 2002, 02:17 AM
YVR is offline
YVR
YVR
YVR's Avatar
Vancouver, BC
Joined Sep 2001
Lots of good feedback - thanks all. I would say the "pulling to canopy" tendency is more pronounced than any roll coupling effect.
mkirsch1 - I looked at the GP website and couldn't see the chart you made reference to - if you have a link I'd appreciate it.
Based on the input here, I think I'll try playing with my flaperon settings - I was wanting to do that anyway to set up an "up ailerons" switch to work on parachutes/harriers, so I'll also program a slight "down ailerons" setting for KE and see how that works. And, of course, start trying to steer with the elevator!
Sean
Old Dec 10, 2002, 03:23 AM
kris1 is offline
Find More Posts by kris1
kris1's Avatar
South Devon UK
Joined Aug 2002
The aircraft pulling to the canopy could also be due to too much dihedral, or the tail plane being too low on the Fuz. I found with my Seduction FS, that moving the CofG further forward, from the rearward CofG, reduced the tendency to pull to the canopy. It also made the plane much nicer to fly better low speed handling. The flat spins are not so flat, so I now cople the flaps to elevator to get round this..
I tend not to set-up mixing for KE, preferring to fly the plane, as the plane will have different flight characteristics for normal flight with mixing. I have set them on a switch, but keep forgetting to switch it when I need it.
Cheers
Kris
kris1 is offline Find More Posts by kris1
Old Dec 10, 2002, 08:58 AM
kelvin is offline
Joined Jan 2002
I would sure like one of you guys to fly my E3D. It flys with very little trim changes but I bet if someone experienced in aerobatics flew it they would probably suggest a lot of small changes to make it fly better and probably easier.
How did you guys learn all this stuff? I basically set up the plane to fly level hands off then proceed from there.
Kelvin
Old Dec 10, 2002, 11:17 AM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
Kelvin
The Local Club
The wingtips on the Diablotin also slow the rolls down and cause it to do that in knife edge. If you remove the tips and leave them flat like on the E3D it will roll better and knife edge better. It is known on fub-flys that the flat tip is better, seems everyone removes them on the magics, Laser 3d's and other popular ones.
Steve H. is offline Find More Posts by Steve H.
Old Dec 10, 2002, 11:20 AM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
Kelvin
Kelvin,
All the books in the world won't make you a better pilot, it all just comes down to practice, and lots of it.
Like Kris said it really can also depend on your CG. The E3D has a sweet spot on her CG where KE and hovering are very easy. I've found it to be about 1/2" behind the spar. Anything else and you will find that you need to do a lot of compensating in the roll axis, and some on your elevator (currently rudder if in KE)
Oh, you mentioned you trim it to fly straight and level, I started laughing when I read this (not at you, at myself) because one day I took off and just flew some circles, and I found that my E3D was out of trim. I never realized it in a summer of flying, just because I was never flying straight and level long enough. (I've since trimmed it.)
Paul Susbauer is offline Find More Posts by Paul Susbauer
Discussion Knife Edge:Plane Pulls to Canopy VictoryRoll-91 Electric Plane Talk 9 Apr 20, 2007 07:31 PM
Please explain - Depron Edge pulls hard to canopy in KE Bill Germanson 3D Flying 5 Jul 17, 2004 06:24 PM
Diablotin Mini Knife Edge Roll Coupling Matt Fritz Sport Planes 17 May 09, 2002 12:19 PM
Another knife-edge qn stuartaw Competition Aerobatics 7 Feb 19, 2002 10:43 AM
What's the best way to enter a knife-edge? Ben74 Competition Aerobatics 3 Jan 26, 2002 10:25 AM
