Old Dec 09, 2002, 10:56 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
big prop, gear drive v. small prop, direct drive
"What is achieved with the two options listed. My goal is to slow down a Partenavia, I have trouble slowing it down on final.
Wayne"
In a light FMA Razor, an APC 12 X 10 E prop on an 801G (3.3:1 box) slows the plane very nicely. Landing "deadstick", the big prop overrides the ESP brake and freewheels, producing a lot of drag. Just be careful to keep the nose pointed down some, so you don't stall.
- Jube
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Dec 10, 2002, 09:02 AM
Joined Jan 2002
Turn off "brake"......
"The brake is not there to slow you down, but will actually speed you up due to the lack of "windmill"-effect.
Once brake is off, your approach will slow down, no matter what prop you use. If still an issue, go for a larger prop geared prop as mentioned before." - Pullin'
You're right, if the prop isn't big enough to overcome the brake. If it is, the prop will freewheel anyway, but the brake will slow it down and increase the drag on the airplane.
So, try it with the brake on, and, if the prop stops, turn the brake off.
- Jube
Old Jan 25, 2008, 03:46 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
When you need some thing really slow down, GWS IPS even give you more gear ratio choice!
http://www.gwsus.com/english/product.../ips-dx2bb.htm
http://www.gwsus.com/english/product...owersystem.htm
GWS4CEO is offline Find More Posts by GWS4CEO
Discussion AXI Mini AC1215/16 & 4.75 x 4.75 APC prop (direct drive) divebudd Power Systems 3 Jul 09, 2007 02:48 PM
Cool 6x3 vrs a 5x4 prop direct drive speed 400 6 volts Rhondas Power Systems 6 Mar 14, 2005 09:23 AM
go brushless big prop direct drive motor sirdirk007 Power Systems 1 Jan 29, 2005 01:30 PM
Why small prop & direct drive on Zagi's? Solcat Foamies (Kits) 4 Apr 22, 2004 06:38 PM
Direct drive small prop vs. geared big prop? TEM Parkflyers 1 Sep 14, 2003 06:39 AM
