Old Nov 04, 2007, 06:36 AM
Old Pilot is offline
Find More Posts by Old Pilot
old pilot
Australia, NSW, Mona Vale
Joined May 2001
I use an Aeronaut folder 52mm centrepiece, with 10 x 7 blades and a 2" Radio-Active spinner. Works fine. I did use the brake at first, but found that when I turned the brake off the prop continued to spin after closing the throttle. This had the effect of slowing the plane down on the approach and shortening that long glide. Worked for me.
Cheers Paddy.
Old Pilot is offline Find More Posts by Old Pilot
Old Nov 04, 2007, 12:53 PM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Originally Posted by Old Pilot
Very Attractive Plane!
Are those retracts?
mike early is offline Find More Posts by mike early
Old Nov 04, 2007, 02:10 PM
Flyer88 is offline
Find More Posts by Flyer88
UK
Joined Sep 2006
Originally Posted by MarkJayne
Tell me your joking
Mark
Many years ago, I read an RAF Accident Report Bulletin about an Avro Anson forced landing where the undercarriage had failed to lower. On the Anson, a small area of the tyre protruded through the undercarriage doors, and the pilot amazingly landed successfully on the tyres with the undercart fully retracted - BUT he also cut the engines and used the starter motor to crank the twin-bladed props horizontal before touchdown and the only damage was a broken aerial. The article included a photo of the Anson sitting on the tarmac on its retracted undercarriage, and the undamaged props horizontal.
Some pilot eh!
Flyer88 is offline Find More Posts by Flyer88
Folding or non-folding on Ripmax Spitfire Giz Power Systems 35 May 04, 2004 04:42 PM
Wind-milling Prop or Stopped Prop? Slow Riser Power Systems 47 Jan 12, 2004 07:56 PM
IPS motor breakin= Prop or no Prop? jayboy Parkflyers 13 Mar 25, 2002 10:56 AM
Big prop-low rpm or small prop-high rpm Ninjak2k Power Systems 10 Feb 13, 2002 04:28 PM
Folding Prop or Fixed??? atckirk Beginner Training Area (Aircraft-Electric) 3 May 30, 2001 09:06 AM
