Old Oct 28, 2007, 03:04 AM
seande is offline
Find More Posts by seande
Joined Oct 2007
How to match esc to motor
I'm new to this site and new to rc modeling, I was hoping you all could answer a question for me.
I'm assembling my second plane, an E-Flite mini showtime. I bought the 480 motor for it and the guy at the hobby shop recomended a 25 amp ESC. Reading more on my own I've seen a 40 amp ESC recommended. (I'm going to use an 11x7 prop.) My question is will this 25 amp work? Am I risking damaging the motor? Would the 40 amp be better? What factors determine which ESC for a given motor?
seande is offline Find More Posts by seande
Old Oct 28, 2007, 03:40 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Welcome to the forum
First thing, using a larger ESC than necessary will not harm the motor. It will cost more, and weigh more, but will probably run cooler and may also have a larger BEC in it (the Battery Eliminator Circuit, which supplies 5v for your receiver).
Obviously, you have to get a brushless ESC for a brushless motor, or a brushed ESC for a brushed motor. They cannot be mixed. Then you normally choose an ESC which is rated for a bit more current than the motor is rated for. I usually go for 15% to 25% more than the motor rating -- maybe more if my ESC is going to be placed where it won't get good cooling.
I can't see the amps rating for the eflight 480, but they rate it at 275 watts which would be 25 amps with a 3S LiPo (watts = volts x amps). So, in my opinion, a 25A ESC is too small -- I personally would go for 30 amps or more.
I can't comment on the suitability of the 11x7 prop because I'm not familiar with that motor. But you are aware, aren't you, that all else being equal it's the prop size that determines how many amps the motor is going to draw? So ideally you need to be able to measure the actual current whenever you try a new motor/prop combo so that you can be sure it's not overloading the motor. Most people here use a wattmeter like the ones here http://www3.towerhobbies.com/cgi-bin...eter&search=Go
abenn is offline Find More Posts by abenn
Discussion motor-battery-ESC How to match a combo NoThreat Beginner Training Area (Aircraft-Electric) 16 Jun 27, 2007 02:34 AM
How to attach the ESC to the motor? MikeTwain Beginner Training Area (Aircraft-Electric) 9 May 12, 2005 01:07 PM
How to Match Battery/Motor? nil8r Batteries and Chargers 2 Dec 23, 2004 07:55 PM
How to connect brushless motor to esc? bradpaul Electric Heli Talk 4 Jan 11, 2002 09:21 AM
How to solder ESC to motor smithrl Electric Plane Talk 4 Jul 24, 2001 10:29 PM
