This thread is privately moderated by IwantaJet, who may elect to delete unwanted replies.
Old Oct 28, 2007, 02:10 AM
IwantaJet is offline
Find More Posts by IwantaJet
Laughs at his own jokes.
IwantaJet's Avatar
Missoula, Montana, United States
Joined Feb 2002
Flew the Renny today. The first flight went fine with a nice climbout and smooth sailing around looking for lift and a smooth landing right at my feet. Checked all controls, throttled up and away she went again.
After about 10 sec she rolled over and power dived at the ground. I got control and climbed a bit more, then killed the motor and tried to glide in to land. She was all over the sky, dropping first one wing then the other. It was all I could do to keep her level, much less turn back. I tried to power up when she got close to the trees but no response from the motor. She then dropped out of the sky and crashed.
I think this is what happened last time too. I thought it was a low battery then as it was after 4 or 5 climbouts but this happened on the second flight on a full battery. I guess it was a radio problem, probably with the Berg receiver.
Damage is heavy but may be fixable. The tail feathers came loose and one of the mounting holes in the fuse is cracked. The tip came off the left wing. The servo broke loose from the right wing. There is some rib damage at the trailing edge of the left wing. It needs a careful inspection but I think the spars are ok. I don't know about the motor and mount yet.
IwantaJet is offline Find More Posts by IwantaJet
configuring ph 10 pixie 7 Lightnin' Bug Castle Creations 3 Jul 21, 2004 06:38 PM
Phoenix 10 and Eclipse 7 problems kscbob1 Castle Creations 5 Apr 09, 2004 12:32 AM
10-7 or 10-4.7??? Kelly Ghan 3D Flying 5 Feb 24, 2004 10:34 PM
What is involved in changeing your SkyScooter to a 10-4.7 slow flyer prop? shredder Foamies (Kits) 3 Apr 22, 2001 03:51 PM
