Old Oct 27, 2007, 10:18 AM
RickSkid is offline
Find More Posts by RickSkid
Lincoln
Joined Oct 2007
Multiplex Easy glider Electric - Spoilers/Braking
Hi Everyone,
I'm new to the forum so please be gentle! I have had the Easy Glider Electric for a few months now and have learn't to fly using it and the FMS sim. My radio gear is the Multiplex Cockpit SX and a Multiplex Rx7 reciever, so there are plenty of bells and whistles available on the Rc tx that are not used yet.
So far I have really enjoyed myself she flies like a dream, apart from the odd C of G snags. My question if anyone can help is - Is there a crow braking or spoiler facility available on the model, can the ailerons be programmed to both go up or down together to dump lift on finals as I'm having a problem with overshooting on landings because she just floats along at about a meter above the deck and doesn't take nicely to too much down elevator at that stage of flight (the mud accumilated on my spinner testifies to this).
If there is a facility can anyone talk me through it , does the elevator have to be mixed in up or down to compensate? I would like to learn how to carry out landings using this method as I have just bought a Graupner Junior Sport Plus with aileron spoilers and would like to practice on the Glider EE before I move up a grade to the Junior Sport.
Hope someone can help
Cheers for now Rick.
RickSkid is offline Find More Posts by RickSkid
Old Oct 27, 2007, 10:35 AM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
..... does the elevator have to be mixed in up or down to compensate?
Rick:
Yes, the addition of spoilerons (both ailerons going up to act as spoilers) helps a great deal in shortening your landings. Crow (ailerons up and flap down) requires separate ailerons and flaps which unless you have added flaps to your EZG, are not there to supply that function.
Adding spoilerons to ailerons is a function of your computer Tx rather than the plane. Most computer radios have that function built in. Try looking in the instructions under mixes or spoilerons.
It is helpful to also program in some elevator compensation so the plane stays level as the lift is killed. You can compensate with the stick, but it is much nicer to have the Tx do it for you. The direction of the compensation is not the same for all planes, but AFAICR, the EZG needs some up elevator as you apply the spoilerons. I have a great deal of spoiler movement as compared to ailerion movement programmed in to my EZG so it kills lots of lift, but the plane then tends to be hard to turn when the spoiler function is full on as there is not much movement left for the aileron function. I compensated for this by using reverse differential when in landing mode so it turns easier.
Be aware that spoilerons only kill the lift, they do not reduce the speed like flaps do. Don't try to make the ailerons both go down to make flaperons since it will make the plane prone to tip-stalling and it will crash.
Sorry I can't help you program that that specific Tx. Try going to the Radio or Vendor forum and ask in the thread that is devoted to your Tx.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Oct 27, 2007, 10:54 AM
RickSkid is offline
Lincoln
Joined Oct 2007
Thanks Foam Crusher that is a great help, I'll go and have a look see if there is a Cockpit SX forum
Cheers
Rick
Article Multiplex Easy Glider Electric ARF Review Michael Heer Electric Sailplanes 59 Aug 09, 2011 02:22 PM
Discussion Multiplex Easy glider Electric - Spoilers/Braking RickSkid Foamies (Kits) 2 Oct 27, 2007 10:22 AM
Multiplex Easy Glider Electric Sherwood Electric Sailplanes 55 Apr 23, 2007 11:08 PM
multiplex easy glider electric and futaba 6exas farmera Radios 1 Dec 18, 2005 08:02 AM
For Sale Multiplex Easy Glider Electric PLATINUM Aircraft - Electric - Airplanes (FS/W) 16 Sep 09, 2005 05:05 PM
